TR2/3/3A how do i fix this hood line?
aaronf30
IMG_20191026_173411.jpgI just got this car back, but my hood looks way off. I cant tell if its bent or just misaligned....how do i fix this?
bobhustead
Looks like the spring in the bonnet lift device is doing too good a job. Take the spring holder portion off and see if the line is better. If so, try a slightly softer spring.Bob
CJD
That's not too bad!
Bob is correct. Make sure the spring is assembled preoperly so it isn't pressing abnormally hard against the bonnet, and the rod is hitting in the slot in the bonnet.
The rubber bumper on the right needs to come up just a hair. You may or may not have to add shims to the dzeus bracket so the fastener still latches easily. The left may need to come down a hair...but maybe not...it's hard to tell from one angle view.
Once the bumpers are set, place towels or some other soft material over the bumpers, and then gently press down on the high area just left of center. You want to over-spring the metal so when released it will stay down, even after closing with the spring pressure. It'll take a good bit of pressure, and maybe some "bouncing" to spring it down. It will, no doubt, take several tries to get it level across the front.
A
aaronf30
I think he used the wrong latch and its laying funny on the car. It looks different than the moss part, and definitely isnt lining up .huge.jpg
HealeyPassion Hood scope chrome gap fix ... Austin Healey 0
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tr6nitjulius General TR DYI don't park on bare concrete fix Triumph 1
T TR6 Carb. Float Chamber Fix Triumph 5
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
W radiator spigot fix Austin Healey 11
Geo Hahn Off Topic Photobucket Fix Triumph 17
K TR2/3/3A Rebuilt steering has creative fix for NA worm bearing! Triumph 4
Scotsman TR4/4A How to fix sagging rear end. Triumph 8
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix...Now with Video! Triumph 43
M_Pied_Lourd TR2/3/3A The Newest Bug to Fix... Triumph 15
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
P MGB Vinyl window scratch/haze fix ? MG 3
S TR2/3/3A green fiberglass fix it stuff Triumph 9
Jim_Gruber Need advice on how to fix this one. Spridgets 7
Elva164 Help me fix the Cortina! Lotus 9
W Emergency rotor fix Austin Healey 2
mailbox General Tech Fix, replace or rewire? Triumph 8
J Finally a fix for the SU pump Austin Healey 5
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Mink TR4/4A Help me fix my reverse lockout... Triumph 3
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
R Smitty Speedometer Cable Fix Austin Healey 1
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
bighealeysource Anyway to fix very slight dent in body without painting ? Restoration & Tools 7
J TR6 looking forgood shop to fix my tr6 Triumph 2
X don't fix it if it ain't broke Spridgets 1
R Fix The Austin 1800 Other British Cars 10
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
H sloppy shock arm fix Austin Healey 4
S How to fix Vapor locking from happening Triumph 42
tinman58 TR2/3/3A Tr3 trans fix Triumph 3
Xte How to fix my new BJ8 SS exhaust system ? Austin Healey 5
regularman What is the permanent fix for rear wheel seals Spridgets 14
regularman I found the fix for the stromberg on the 1500 Spridgets 6
bighealeysource ideas on how to fix dents on frame Austin Healey 15
L Simple fix for leaky tappet cover Austin Healey 0
A Steering Wheel Fix Austin Healey 5
K Brake pedal doesn’t move mcylinder didn't fix Triumph 7
M Weeping fuel pump fix Triumph 41
doughairfield how would you fix this? Triumph 9
M Car goes "click" when trying to start - the fix Spridgets 8
glemon Speedo Fix Triumph 4
