tow bar
Any recommendations for tow bars and how best to attach them to a BJ8? With the fires in CA I would like to be able to remove the Healey to safety. We are currently not in jeopardy but we do live in the Tahoe forest and escaped the fire 12 years ago with a friend moving the Healey.
Michael Oritt
I have one and will try to post a pic tomorrow. it is a standard folding bar the ends of which I had modified by having short lengths of round bar welded on which slip into tow eyes that bolt up to the frame left and right. It takes about 5 minutes to deploy and the car tows wonderfully.
Michael Oritt
TH--
I hope these four photos are large enough for you to see how I attach the tow bar to my car.
I bought the tow eyes from DW but there are probably other suppliers whose eyes are the same or similar. I cannot remember where I bought the tow bar but you will find a similar one at Harbor Freight. I modified it by having solid steel bar stock of appropriate diameter to fit the eyes welded onto the ends of the tow bar, with holes drilled in the ends to receive the spring-loaded linch pins. Once the bars are in the tow eyes I set up the light cross bar and rig the safety chain around the anti-roll bar, then hook up to the tow hitch.
I do not tie down the Healey's steering wheel but rather let the car follow along and it tracks perfectly with the front wheels moving to left/right on turns on their own. I DO NOT GO INTO REVERSE!!!
Some time back we had a good--if perhaps inconclusive--discussion about flat-towing our cars at:
https://www.britishcarforum.com/bcf/showthread.php?68049-Towing-a-Healey
Perhaps your post will cause us to revisit the matter, and in any case I hope this helps and that you do not have to make an emergency evacuation .
RAC68
Hi Michael,
Really creative idea. I have nothing to pull my Healey with but I think your bar seems so good that I am thinking of building one so I will be ready when I buy an SUV with a towing setup.
Ray(64BJ8P1)
Michael Oritt
Ray--
You wouldn't need an SUV and could certainly pull the Healey with your family car--maybe even a Moped assuming you found a way to mount a tow ball.
tahoe healey
Very confusing info on not disconnecting the drive shaft. As I probably will not be doing 100 miles I'm thinking to leave the shaft connected. Thanks for all the replays.
TimK
Having flat towed an MGB thousands of miles to races, you need to have a substantially bigger tow vehicle to avoid the towed vehicle overwhelming the tow vehicle if you need to make evasive maneuvers or go around a corner too fast. I learned the hard way. You have to remove the tow bar if you need to back up — not possible while flat towing. I did have a reverse threaded hub nut come loose and almost lost a wheel and axle. Not sure if Healey’s have the left wheel reverse threaded. Reverse threading works when the wheel is under power, but when towed it can unscrew itself.
Michael Oritt
ok maybe not a Moped.
John Turney
.... I did have a reverse threaded hub nut come loose and almost lost a wheel and axle. Not sure if Healey’s have the left wheel reverse threaded. Reverse threading works when the wheel is under power, but when towed it can unscrew itself.
Healeys do have handed knock offs.
Michael Oritt
Tim--
You said: "Reverse threading works when the wheel is under power, but when towed it can unscrew itself."
If this is the case why wouldn't front wheels "unscrew themselves" when a car is driven as they are never under power?
Michael Oritt
Bob--
I understand the concept and was simply inquiring of Tim why he felt that the knockoff's might loosen when a car was being towed.
tahoe healey
In inspection of the tow bars available, I am having trouble visualizing how they attach to the frame using the existing threaded mounting welded nuts. Moss sells the attachments that fit the frame but the commercial tow bars have a different configuration.
Michael Oritt
TH--
If you view the pics in post #3 you'll see that I cut off the ends of the collapsible tow bar and had solid bar stock--probably about 1" diameter--welded to the ends of each leg. The bars slip into the tow eyes from the outside and are secured with lynch pins. I'm not sure how to describe this more clearly but if you like give me a call at 305-793-9467 and I will walk through it with you.
Tr3aguy TR2/3/3A tow bar for TR3? Triumph 1
Jim_Gruber Spridgets and Tow Bar Spridgets 15
S MGB Tow bar on an MGB MG 9
P T-Series Tow bar on a TD? MG 13
I Fitting tow bar. Jaguar 0
60TR3A TR2/3/3A Tow Dolly Triumph 6
D MGA with T9 gearbox on a tow dolly MG 9
AngliaGT Got A New Tow Vehicle Other Cars 5
B Tow Hooks for the Rear of a BJ7 Austin Healey 10
H Tow advice asked Austin Healey 10
drooartz Front tow eye for a Bugeye Spridgets 11
dcoplan Safest way to tow a Bugeye? Spridgets 12
M My First Tow! Spridgets 17
This14u Spitfire Spitfire Tow Tabs Triumph 1
G Perfect TR tow vehicle or parts chaser... Triumph 15
bigjones Tow truck blues - good analysis for you to ponder Spridgets 33
jhorton3 MGB MGB On A Tow Dolly MG 5
jackq Meyers Tow'd Other Cars 2
1 AAA? No way. I need to tow a 60 AH BE Spridgets 9
T TR6 How not to tow a TR6 Triumph 25
tosoutherncars O/T - Tow vehicle question #2 Spridgets 9
tosoutherncars Question - a little OT - Tow vehicles Spridgets 41
zimmy $50 tow kit Spridgets 20
Jim_Gruber Car Dolly's and LBC's /Drive or Tow to the Ozarks Spridgets 37
Scott_Hower Spitfire Spitfire - to tow or not to tow. Triumph 31
tateboys Tow Dolly vs. Flatbed Trailer MG 42
vping MGB-GT Tow Dolly for MGB GT - Is there a clearance issue? MG 15
aeronca65t TR2/3/3A TR-3 Tow Car Triumph 13
T Where do I attach a tow line for emergency tow ? Triumph 6
beaulieu trailer tow lights blink too fast Restoration & Tools 2
G Best Way to tow or haul my new Midget? Spridgets 13
Sherlock Can a motorbike tow a car? Other Cars 9
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
B TR6 Sway bar Triumph 3
AH67AH Badge Bar Austin Healey 1
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
S Sway Bar End Links Austin Healey 15
B TR4/4A Roll Bar Recomendations Triumph 7
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
71TR6 For Sale TR3A Roll Bar for sale Triumph Classifieds 1
steveg TR6 Fixing Twisted Sway Bar Bracket Triumph 2
tahoe healey Sway Bar Bushings Austin Healey 3
T Need an Anti-Tramp Bar? Austin Healey 6
C Front sway bar mounting? Austin Healey 10
mt10flyer TR2/3/3A Revington Roll Bar Triumph 12
FlyingCat Spitfire Anti-Roll Bar Triumph 6
G Rollover Bar BN6 Austin Healey 3
K Mystery badge bar Other Cars 4
G TR2/3/3A Light Bar Triumph 8
