TR6 110A Alternator
Ripper01
My first post for help. I recently purchased a 110A alternator for my TR-6. This is a huge increase over the current Lucas alternator installed. I have seen the posting on the physical alterations possibly needed but do I need to make a major change to the wiring? If so are there any references?
On the VTR forum there was a link that looked promising but ended in a 404 error message- not availible.
Thank you all,
Rip
poolboy
What year ? Is there an Ammeter or Voltmeter in your dash instrument cluster ?
TR3driver
Great Pumpkin - R.I.P
I'd say it also depends on what you plan to do with all that current. But in general, yeah, you're gonna need some wiring improvements. The existing charge path (alternator back to battery) is somewhere around 12 AWG; you're gonna need more like 4 AWG.
Early car with an ammeter; probably the easiest way is to lose the ammeter and convert to a voltmeter. Otherwise you'll have to run new heavy wires to and from the ammeter, plus rig some kind of shunt so only a calibrated fraction of the current actually goes through the meter.
Without the ammeter, you can just run a new heavy wire from the alternator to the starter solenoid (to join with the cable from the battery).
ed_h
Two questions:
What mods to the car require a 110 amp alternator?
Serious upgrades to the wiring will be needed. Are you sure it is worth it?
Ed
Ripper01
Ripper01
I have a 1975 with a voltmeter. A 90 plus amp was recommended to me but does seem pretty big for what I need. Definately want to replace the Lucas alternator with a bigger one. I can still return it for an exchange.
ed_h
The last 18ACR I bought was rated at 60 amps. I think the originals were only around 45.
Ed
Sarastro
Unless you have some specific need for high current, like a high-power audio system, a 55-amp alternator should be more than adequate. That would power all the usual stuff, plus modern upgrades, like driving lights, electronic ignition, a decent radio, and so on. If you do need something on the order of 100A, you are using about the same current as a starter, so wiring has to be sized like a starter, and connections must have large contact area and be bolted together good and tight. It's not a trivial undertaking.
If you don't mind telling us what you're doing, which needs high current, maybe we can make some suggestions.
Ripper01
Ripper01
Good points. I was recommended to replace my alternator with a 100 amp one but the more I researched it, the more work it would be. In fact I just replaced my headlights with LEDs so the draw is even lower now. Will replace the Lucas with a lower amp Bosch or Delco. I want the built in voltage regulator functionality.
I had purchased the high power alt on Amazon and returned it, no problem.
Thank you all for the inputs.
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
J MGC Lucas alternator/regulator MG 3
K TR2/3/3A Revington alternator heat shield. Triumph 0
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
