Bonnet belt
Next question, how far back should the belt be on the bonnet? Getting ready to install it, and don’t want to mess it up. Non-louvered hood, BN4.
As always, Thanks in advance!
Bob_Spidell
About 3/4 of the way back from the front edge, if this original 100M is an indication:
longbridgehealey
Thanks Bob. Further than I thought.
Larry
Bob_Spidell
Bear in mind the 100s' bonnets hinge from the front, so for a 6-cyl car you might want it a bit further forward. Since no louvers, I'd lay it out and move it around until it 'looks right,' then sleep on it before drilling any holes. Or, find someone with a Works rally car, and see where the pros placed them.
Keoke
BOB:
I certainly agree with you here good point ole chap
HealeyRick
Here's mine on my BJ7:
I bought the strap from the 100M Registry as it is of much better quality (thicker and of leather) than the ones sold by the usual suspects. I chose the location (18" from the rear of the bonnet to the rear edge of the strap) based on these pictures:
I later had louvers punched in to help with cooling the V8:
longbridgehealey
Thanks Rick, that looks pretty good. The funny thing is mine has been stretched across the hood since I read Bob’s post, and it’s 19 inches from the rear of the bonnet.
HealeyRick
You may have to move it around a bit, also, so the buckles and holes in the strap will line up with the bonnet opening. The other thing to keep in mind is you will probably get some chafing of the paint on the bonnet over time. I've seen people stick flannel and even sheepskin to the underside of the strap to avoid this. I used a 2 in wide strip of XPel: https://www.xpel.com/why-xpel under mine, but I can't say it's been on long enough to give it a complete test.
roscoe
If you are in the US and have access to a Tandy Leather supply store they have leather belts in various lengths, thicknesses and the buckles that are indistinguishable from original. I made mine with the help of an industrial sewing machine at the local parachute loft. I also made the clamping hardware from some aluminum stock. Total cost about 30 dollars.20180206_144743-1024x768.jpg
longbridgehealey
Jon, that looks really nice. Good job!
roscoe
The belts that are pictured are of the " form follows function" school. Minimal and likley more effective at keeping the bonnet from smacking the windshield should the latch fail than a strap in the middle. I'm not really sure why the 100 models were offered with a mid strap that really isn't needed as the bonnet hinges in front so a latch failure isn't so nasty. That being said, nothing looks classier to me than a big old piece of leather on your hood that looks like it actually does something. I did the louvers because they really do keep my feet from getting overtemped, the belt because it just looks so cool.
John Turney
If you have the ridge in your hood, the belt in front makes even more sense. Otherwise the paint will wear off the ridge quickly.
AUSMHLY
As HealeyRick pointed out, placing a strip of the film, aka generic clear bra would address that. If one does not want to see the edges of the film, the installer can clear the entire panel. Some guys clear the entire car.
HealeyRick
From the XPel site I was able to buy a 3' x 2" strip for $5. Installation was easy following their directions. Doing the whole front of the car or bonnet, with all the curves would probably need professional installation. You can see the edges of the film on my car as it extends on either side of the belt. If you really cared, you could probably trim the film so it was narrower that the belt without losing any of the scratch protection.
AUSMHLY
Front of the car, can be done in one piece if you find a qualified installer. I had 4 installers look at my Healey, 3 wanted to make several cuts where the curves are at the headlight. The guy who said he will not make any cuts, was more expensive and as that says goes, you get what you pay for. I used him. Here's some photos. The blue line in the photos is to show that the stop edge of the film is right above it. He applied the film to the aluminum grill slates too, so they wouldn't pit from highway pebbles.
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Bonnet Latch/Release Adjustment Austin Healey 3
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
fmichaels Bonnet hinge holes Spridgets 4
Rhodyspit75 Bonnet gas struts Spridgets 5
L TR2/3/3A Hood / bonnet plinths Triumph 12
C Under boot and under bonnet paint? Austin Healey 7
D TR2/3/3A bonnet safety catch Triumph 4
N For Sale 1971 to 1980 Triumph Spitfire Bonnet Triumph Classifieds 0
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
W Electrics, fuel system, under bonnet temp. Austin Healey 3
H TR4/4A question on TR 4 a chrome bonnet letters Triumph 8
anarchy99 Bonnet / hood fit question... Spridgets 2
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K TR2/3/3A Location of Hood[Bonnet] Louvres on a TR3A? Triumph 1
