Results 1 to 7 of 7
Thread: Torque Sticks
Discuss general restoration and car care topics (paint & body, upholstery, woodworking, etc) as well as tools.
  1. #1
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,346
    Thanks Thanks Given
    Thanks Thanks Received
    24
    Thanked in
    Torque Sticks
    I did professional auto repair and diagnosis for probably 40 years according to she who keeps track of that stuff.
    About 20 years ago, the clueless individual ran the stop sign, and my career was over.
    Saturday I helped at a Church sponsored car care Saturday, and saw Torque Sticks for the first time.
    When were these invented, when did they come into use? I can imagine Snap-On with their new stuff to wow the folks in the trenches having them first.
    Interweb reading seems to indicate they work well for some things.
  2. #2
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,490
    Thanks Thanks Given
    8
    135
    Thanked in
    Re: Torque Sticks
    Been around for at least 30 years that I know of. Accuracy is pretty low though, from what I understand. They need to be matched to the impact gun; but impact guns get weaker as they age, etc. And if you pick up a gun with a bigger hammer inside (or longer lever arm), it will put more torque through the stick than it's rating.
    Don't recall where or who offhand, but I'm pretty sure I've seen a note from a major car maker saying a torque wrench is required to tighten lug nuts.
    Randall
  3. #3
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,346
    Thanks Thanks Given
    24
    Thanked in
    Re: Torque Sticks
    20 years ago nobody around here had heard of them.
    Strange.
  4. #4
    Luke Skywalker LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,977
    Thanks Thanks Given
    16
    Thanked in
    Re: Torque Sticks
    Thought about buying a set when I worked for a shop. Matco driver showed me a set, wound up buying a full Snap-On torque wrench set, which I still use today. As TR3driver says, impact guns are accurate for a while and/if you use same exact air pressure each time.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual ,
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  5. #5
    Yoda TOC's Avatar
    Join Date
    Jun 2008
    Location
    Posts
    6,346
    Thanks Thanks Given
    24
    Thanked in
    Re: Torque Sticks
    You read up on them, everybody has a different idea as to how they work. Makes your head hurt.
    Within 20% of marked value, maybe.
    Worth the effort? Nah.
  6. #6
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,920
    Thanks Thanks Given
    14
    51
    Thanked in
    Re: Torque Sticks
    Are they a little better than the Tire shop guy just setting the impact gun to "$" and calling it good.
    I always try to take my wheel to the shop if I need tire work and torque it myself at home with a proper wrench. Have thought of taking the wrench with me and re torquing the nuts on the tire shop forecourt if I have more than one wheel done.
    One thing I have noticed is that my front brake rotors never warp.
    David
    TR3A TS75524L
  7. #7
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    1,977
    Thanks Thanks Given
    16
    Thanked in
    Re: Torque Sticks
    I have watched the tire guys just zap them with impact. At my one store I would torque them before I left and it irritated the manager. I would hold up two fingers and give a thumbs down. Watched an alignment thru the waiting room window as the tech used vice grips to adjust toe-in. Had a pissy fit right there and he had to borrow a wrench. Still had to realign when I got home. 3 degs off. Never have gone back. My shop now is two blocks away and gave me the torque specs and offered wrench to check.
    Larry K
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
