Results 1 to 15 of 15
Thread: Windshield difficulties
  1. #1
    Join Date
    May 2012
    Location
    Roberts Creek,BC
    Posts
    174
    Thanks Thanks Given
    6
    Thanks Thanks Received
    Thanked in
    1.. I sheared off the lowest screw holding the windshield frame. I had hoped to attack it from the back by removing the corner bracket but it looks as the the miscreant screw will hold that up.. The flathead screws are pretty rusty to and i have soaked them with penetrant.. Ideas? Experience?
    2. the lower seal is pretty messed up too. Any ideas how to get it off ( and replace it!).
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,295
    Thanks Thanks Given
    6
    26
    Thanked in
    Re: Windshield difficulties
    Slot with a dremel and try a flat blade screwdriver?
    John
    1955 TR2
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,276
    Thanks Thanks Given
    7
    106
    Thanked in
    IMO a hand impact tool is your best bet for the other two; but it may snap them off too. Start out with fairly gentle taps on the tool, and work your way up gradually. You may have to create a custom bit for it. Here's a shot of one I made to get an antique tractor carburetor apart (and it worked great)
    For the broken one, I would probably try to center punch it as close as possible to the center. I'm not certain, but there might be enough hole exposed to use a "transfer punch" to hit center.
    https://kk.org/cooltools/transfer-punche/
    Then drill it out in small steps, stopping either when you can see threads in the hole or there is just a thin shell of the bolt left in the threads. Then break the remainder apart with a dental pick. With luck, you can save the hole.
    If not, it is possible to make, in effect, a thread repair insert. I used a SS bolt in 1/4-28, drilled and tapped to suit (in my case, it was 2BA for a Tenax stud, but I think yours might be 10-32 instead), and held in a split nut so I could cut it off to length. Kind of tricky working with such a small piece, but it came out great.
    Randall
  4. #4
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    174
    Thanks Thanks Given
    8
    Thanked in
    There is such a thing as an "Easy-Out" which is not that easy but usually gets it out.
  5. #5
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,276
    Thanks Thanks Given
    7
    106
    Thanked in
    Not for me. They almost always snap off for me, which leaves a much worse problem. The original bolt is soft enough to drill, but not an easy out!
    Assuming of course that it snapped in the first place because the threads were stuck, rather than being overloaded or over tightened.
  6. #6
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,265
    Thanks Thanks Given
    28
    Thanked in
    I would suggest ordering the kit with the 2 brackets and screws and you will see how short the screws are and how small the bracket is and the shape. I would keep juicing them up and try some of the suggestions. I never thought of a small impact wrench or a drumle – my first thought was a left hand drill bit, but that is like the easy out it could break and give problems.
  7. #7
    Join Date
    May 2012
    Location
    Roberts Creek,BC
    Posts
    174
    Thanks Thanks Given
    6
    Thanked in
    Quote Originally Posted by CJD View Post
    I think that is the first step. Thin Dremel discs are not available in the boonies, but I got some from a Model Railroad friend. Lots of penetrant too, which i shpuld have used in the first place.
    Sceond bet is to drill out the bolt as much as I can without hitting the glass.. Wish me luck!
    And thank you all for the suggestions..
    Dr. Mike
  8. #8
    Join Date
    May 2012
    Location
    Roberts Creek,BC
    Posts
    174
    Thanks Thanks Given
    6
    Thanked in
    lAttempt to sot and turn screw were not successful: a combination of less than perfect eyesight, caution ( about my eyes) and the fact that the dang screw is well and truly stuck. Next is to try to drill it out and clean the threads.
    Cannot loosen the screws holding the corner brace either. Patience! I don't need to change it unless I have to get to the other side of the Screw.
  9. #9
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,295
    Thanks Thanks Given
    6
    26
    Thanked in
    Something I mean to get are left handed drill bits, for just your situation. As you drill out the old bolt there is a much more likely chance of it unscrewing itself if you are drilling CCW. I have not chimed in here as this is about as bad as a broken bolt gets. The frame is brass, and the bolt likely steel, so you are attempting to drill a harder bolt than the surrounding material. There is no "sure fire" way of getting it out.
    Once the dust settles, you are likely to have a very ugly hole, much bigger than the bolt size. At any decent bolt supply store (or Amazon) you will be able to buy an insert to make the hole useable again.
    John
    1955 TR2
  10. #10
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,265
    Thanks Thanks Given
    28
    Thanked in
    I like the left handed drill bits also. What you might try if things fail is a cone shaped dermel bit because all you really need is the cone off the end of the screw ground away and the frame will separate. It is kinda delicate work, but with light magnifier, you should be able to see the screw as it grinds away before you dig into the brass. If you get most the screw head ground away, you should be able to pick around what is left behind and slide the frame over. Or, a cone shaped rotary/dermel file in a drill motor might be easier to control plus I would start small and work up. I would do the CCW drill bit first.
  11. #11
    Join Date
    May 2012
    Location
    Roberts Creek,BC
    Posts
    174
    Thanks Thanks Given
    6
    Thanked in
    Thank you John and?(sp53). Sorry, forgot your name!
    The good news is that the offending screw is brass too, so it should not be too too difficult to get ou. I suspect it is cross threaded (we will never know), and that I will in any case expect an ugly hole. I am worrying about the glass and may indeed have to disassemble the corner, but , of course, the two stubby screws that hold the bracket in are also solid and they too would have to be ground away.
    I have an engineer coming round this morning. He lives just up the road so no problem, and I shall see what he has to say. My go-to machinist is leaving town at the end of the month so I am reluctant to recruit him in the middle of packing. I shall see if I can get a small CCW bit here.
    Getting g a bit chilly outside but the rear lights are coming together: using an LED kit so I can be seen. 2 stripped captive nuts replaced, etc.
  12. #12
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,276
    Thanks Thanks Given
    7
    106
    Thanked in
    Hmm, just for clarity, this is the kind of impact tool I was talking about.
    https://www.amazon.com/Lisle-29200-H.../dp/B0002NYDRG
    It seems to work better for slotted fasteners, I think because the impact both drives the bit into the slot and also puts pressure into the bolt as well as twisting it.
    Mine uses 5/16" hex bits, so a 5/16" Allen wrench makes good stock for grinding your own bits.
  13. #13
    Join Date
    May 2012
    Location
    Roberts Creek,BC
    Posts
    174
    Thanks Thanks Given
    6
    Thanked in
    So the brass screw drilled out quite easily (which is more than can be said for the tooth I had removed today) and there was an intact threaded stub that came out too. The threads are quite visible, but i cannot persuade a screw to enter . I shall get hold of a suitable die to clean them, or taper the hole with my Dremel and a cone. Resting now from the dentist's exertions.
  14. #14
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,580
    Thanks Thanks Given
    6
    Thanked in
    Quote Originally Posted by Dr_Mike View Post
    ... The threads are quite visible, but i cannot persuade a screw to enter . I shall get hold of a suitable die to clean them, or taper the hole with my Dremel and a cone. Resting now from the dentist's exertions.
    Be careful, if it's the screws that I'm thinking of, the threads are most likely BA (British Association). Very similar in size and pitch to UNF, but not the same. Both pitch and thread angles are different. You'll find that a lot of screws smaller that 1/4" on the TR are BA.
    https://britishfasteners.com/threads/
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  15. #15
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,628
    Thanks Thanks Given
    12
    36
    Thanked in
    You can get the screws and the corner bracket if you need that from Moss.
    David
    TR3A TS75524L
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
