First Gear Shift Difficuties
RAC68
Hi All,
A good Healey friend is having difficulty shifting into 1st gear and indicated that the shifter seems to move further to the left (towards reverse) then the line between first and second. If he moves the gear shift more to the right to place it back into the first/second line, the shifter goes easily (as easy as a Healey standard can) into first and from first to second gears. What could be happening or warn that is allowing the shifter to move more to the left and how can he correct/adjust it? He has already replace the busing on the bottom of the shift ball.
Thanks,
Ray(64BJ8P1)
Bob_Spidell
I'd say there's something wrong in the 1st/2nd shift fork, but you'd expect that to affect both gears. The only thing I can think of is the set pin that secures the fork may be loose--if so, he has a potential major problem--but, again, I would expect that to affect shifting into second as well. If he has a centershift box (you didn't specify), it would be worth pulling the top cover for a look.
I've seen instances where people didn't properly safety wire the set pin--just making a loop through the pin--that, at best, would only keep the pin from falling into the gears if it worked loose. Safety wiring has specific requirements in order to be effective, I tried to follow those rules (and I used threadlock suspenders to go with the belt):
RAC68
RAC68
Hi Steve,
The transmission is a center shifter in a 1966 BJ8. Since entering into reverse requires a slap to the left of the shift lever, where is this spring mechanism located and is there an adjustment?
I did go thought my transmission in detain and wired the fork bolts and replaced all bearings. I did know how all worked back then (mid 1980s) but didn't know enough to understand I should have put goop on the through-case transmission bolts like those fixing the bell housing.
Thanks Steve,
Ray(64BJ8P1)
Ray(64BJ8P1)
Bob_Spidell
You can see the spring-loaded reverse lockout plunger at the bottom left of the picture I posted (depending on how your browser orients the photo). There isn't an adjustment, per se, but I suppose you could shim the spring.
S Gear Shift Lever Travel Austin Healey 13
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
TR3MT TR2/3/3A Hot Gear Shift Lever Triumph 12
S TR2/3/3A Gear shift knob Triumph 8
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
KVH General Tech Gear Shift Sticks Triumph 6
J TR2/3/3A such strange thread on gear shift knob Triumph 12
Rob Glasgow Wanted Austin Healey Gear Shift Lever Austin Healey Classifieds 2
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Michael Oritt Gear shift lever modifiacation [No Healey Content] Austin Healey 7
wangdango BJ8 gear shift consol restoration... Austin Healey 9
tinman58 TR5/TR250 Funny sounds from gear shift Triumph 4
Rut 5 speed gear shift lever Spridgets 28
Rut MGB MGB OD gear shift lever MG 0
6 Gear Shift Lever Spridgets 3
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
KVH TR4/4A Top Gear Shift Mechanism Triumph 4
T TR4/4A Second gear hard to shift into on first try Triumph 10
af3683 TR2/3/3A TR3 Original Gear Shift Knob Triumph 16
mdw BJ8 gear shift thread Austin Healey 7
T TR2/3/3A TR3B gear shift lever Triumph 6
C Gear shift patten on a Super 7? Other British Cars 6
brgrmyster GTG6 Gear Shift Lever Inner Ferrule? Triumph 0
S Gear Shift Freezes Between Shifts Jaguar 1
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
andrea $ SPEED SIDE SHIFT GEAR BOX Unknow spare piece Austin Healey 3
PAUL161 Gear Shift Lever Thread Size? MG 28
A New!!! Gear Shift Knobs for 5 Speed Transmission Triumph 1
jerrybny Gear Shift Triumph 4
R gear shift stick movement in 3rd gear question Spridgets 46
Tinkerman TR2/3/3A TR3 A Gear shift question Triumph 3
davidk Gear Shift Lever Vibration Triumph 4
Tinkerman Gear shift lever threads Triumph 21
jpr28056 Gear shift lever twisting Spridgets 10
JPSmit Gear Shift threads and trivia question Spridgets 1
SCguy TR4/4A TR4 gear shift knob Triumph 13
gsalt57tr3 Gear shift knob idea Triumph 7
Dave Richards Gear shift Surround Trim Austin Healey 6
jjbunn Confused about gear stick/shift knobs MG 14
kyreb1862 Gear Shift Knob Removal MG 7
RSMTR8 Wedge TR8 Gear Shift Knob Triumph 7
Tinkerman TR2/3/3A TR-3, Pitting on gear shift lever ball. Triumph 2
Frank C. Gear Shift Boot Installation Austin Healey 18
MrPandy TR6 Question about TR6 gear shift knob Triumph 15
G Transmission will not shift into any gear Spridgets 2
S Gear Shift Knob Jaguar 3
J 73 Gear shift knob MG 0
L T-Series Gear box servicing cap. MG 5
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
