Cut down windshield
Rut
I meant to post this awhile back, but better late than never. I ended up going with 1/4” polycarbonate and it was easy to work and the edges polished out nicely.
Rut
Stan Kowznofski
I'm just curious, how are you going to get that thru inspection or is this not a road going car? In PA you'd never get away with the short windshield or the polycarbonate.
Rut
Rut
Stan,
No inspections in Alabama outside of vin verification when you buy your tag. No titles either and the vintage tags are a one time purchase for the life of ownership. I have titles for all of my LBCs, but the license issuer never wants to see them, much less record them. I don’t think you even need to have a windshield to get a tag.
Rut
Now you need to make some wiper post covers.
Boink
Bronze
Or some really dinky wipers. :wink-new:
Nice job on the screen... sort of a continuous Brooklands thing.
Rut
Rut
wiper post covers or itty bitty wipers...hmmmmm, new project!
Rut
mxp01
Rut:
I've seen these for sale - pretty pricey. Did you do this yourself? If yes, can you explain how you did it?
Rut
Rut
Rut:
It was a lot easier than I thought it would be! I posted a want ad in the BST forums for a complete windshield frame and found one for $50. I cleaned it up and cut the frame and uprights at the height I wanted and drilled/tapped a new mounting hole just below where the original center hole was located. I ordered a windshield gasket from Moss which was the most expensive part of the project and a 1/4” thick piece of 12”x48” Lexan via the internet. I used a template I made from my old windshield and cut the Lexan with a jigsaw/polycarbonate blade and finished the shape with a mounted disc sander. I used 80 grit sandpaper on a 12” long piece of 1x2 to finish the shape and make everything straight and true followed by progressively finer sandpaper down to 3000 grit w/d which left a nice polished edge. It was a fun project and I’m going to modify the height of the frame and uprights to give it a more finished look. The Lexan is tough and flexible, very easy to bend and insert into the rubber windshield gasket. Probably about $150 total in the project.
Good luck, Rut
mxp01
Thanks for the instructions. I think I might try the same thing. Can you tell us what you are thinking when you say you want to modify the uprights to give it a more finished look.
Rut
Rut
looking at my 2nd picture you can see that I cut the frame and uprights off at the same angle in relation to the body of the car. While the angle is not the big issue to me, I think it would look much better if the frame and uprights were cut off lower and some type of cap or filler made to finish the top edge. It could be something as simple as a piece of 3/8” thick plate welded to the uprights and shaped. Thoughts?
Rut
Rhodyspit75
I like the look and what you’ve done overall but I do agree that the uprights need to be finished off. Looking at then from the front I would recommend a radius similar to the windshield. Form a cap out of maybe 1/8 inch aluminum and have it welded in and then finish and polish it.
Rut
Rut
I didn’t know Bugeye guy had one and I like the shorter uprights, but I almost had heart failure after seeing the price! I think I’ll cut mine a little lower and tig some caps on, then grind them into a more pleasant shape.
Thanks for the input, Rut
PAUL161
If you plan on tagging the car, check your state regs, I know for a fact some states will not approve that mod, because overall size might not meet their inspection specs, including wiper area. Good luck. PJ
Rut
Rut
Paul,
Alabama does inspections for vin numbers and that’s about it. No title, just a bill of sale for a tag and the vintage tags are good for as long as you own the car...I think it’s a $25 one time fee. I don’t think you even need a windshield!
Rut
Mk3Sprite
Rut, Looks cool, why not remove the wiper motor, wheel boxes and squirters and fill the holes with a blanking plate? cheers David.
Jim_Gruber
Because it rains in Alabama and while this may be OK for local cruising, if Rut wants to make it to the AH Conclave next year in Crystal River, FL, he may want to have a complete windshield. Or in FL, Bikini Tops are being seen. Let in the air but keeps the sun off of your head. There were two in appearance at the Tampa All Brits Show this past weekend.
Rut
Rut
This was just a fun project and I have the original full windshield with new glass, rubber, and anodizing. I pulled out my top yesterday and gave it a good cleaning and inspection and will roll it back up on the frame where it will live in the car. This is a fair weather car that never gets driven enough although it’s the most fun. The MGB ‘driver’ gets the most use since it’s built to keep up with modern traffic and I can get in and out of it relatively easy. I’ve got a bad back, need a new right hip and all the things common to getting older, but I’m just like Billy Joel and his Cadillac, AC, AC, ac. The TR4A is the next easiest to get in and out of, but it needs new aluminum steering rack mounts (which are sitting on the shelf) to be fun. One of these days...
Rut
JPSmit
gorgeous cars gorgeous shop!
K TR2/3/3A A cut down side curtain for Fall driving? Triumph 7
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
BN6 BJ8 Outrigger Cut Out For Exhaust Austin Healey 3
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
69MGC MGC Cut out the Rust! MG 9
D cut-off switch Austin Healey 20
W TR2/3/3A Why a PO cut these holes in rear floor? Also, question re dealing with captive nuts Triumph 6
CJD TR2/3/3A Cut away TR3 Triumph 6
Boink Moss Healey Cut-out... I'll ask... Austin Healey 2
Boink Cut-away B series engine... MG 6
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
BobMunch MGB The MGB Cut-away, Heritage Motor Centre Museum MG 11
J Windshield question pt.2: Why not cut the frame? Spridgets 9
Boink Battery cut-off switch options... or??? Spridgets 10
K TR2/3/3A TR3 Cut Off Side Curtain. Triumph 18
D battery cut off switch Austin Healey 29
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
Tinkerman Battery cut-off switch installation Triumph 22
AUSMHLY fuel cut off Austin Healey 23
vping T-Series Adding a battery cut off switch. MG 16
G To cut or not to cut Austin Healey 3
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
Ouagabambou Cut, torn steering inner tube [+ photograph] Austin Healey 22
T TR6 What year TR6 cut over to Type-J O/D? Triumph 3
roofman Looks like Dale made the cut! Triumph 13
B T-Series cut off switch in MGB? MG 7
T What year cut-over to the 1500? Spridgets 13
jmwuva05 Fuel pump cut off switch Spridgets 6
R Cut off switch wire Austin Healey 2
jlaird First cut on trophies for Lake of the Ozarks Spridgets 32
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
J TR6 Inertia cut out [off] switch TR6 Triumph 9
TR6oldtimer Fuzzy door seals to cut or not, buy new or keep Triumph 12
T What do you guys use to cut floor pan sheet metal? Triumph 7
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
tahoe healey fuel pump cut off switch post Austin Healey 21
T Cut/Splice Spark Plug Wires?? Triumph 13
S Battary cut off switch Austin Healey 1
R6MGS T-Series Late MGB fuel cut off switch MG 5
A dash light cut off switch Austin Healey 9
jlaird Bat, cut off switch Spridgets 7
S TR2/3/3A TR3 Turn Signal Auto Cut-Off Triumph 5
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
G Fuel cut-off valve MG 5
A Battery cut off switch Austin Healey 15
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
