TR2/3/3A wood next to the door on a tr3
sp53
I never could figure out what and why that strip or piece of paper/wood was used for next to the door on a tr3. I first thought it was a nailing strip, but why a nailer--- most all the other vinyl is screwed to the sheet metal with cup washers? Was it to make a finish weld on the B side?Plus that little piece of stuff is basically floating in this odd shaped channel, so it is not structural. Then I thought the stuff is “oakum,” and when oakum gets wet it swells up and seals. I remember my dad showing me that when I was a kid with pluming, now putting that striped piece of cardboard in that little channel makes senses; it is an oakum door seal, Genius.
TomMull
My memory tells me that it was a nailer for the weather strip but my memory is not all that reliable.
Tom
DavidApp
I think it is intended to hold the fuzzy weather strip in place. The Dog Leg panel screws on in about 3 places down the "B" post.
If you have a trim kit and the dog leg piece comes with a bit of vinyl stapled to the back that is to fill in the gap between the bottom of the dog leg piece and the carpet.
David
charleyf
Having removed several of those pieces, I can say that the purpose is for a tacking strip. I have no idea why they used the stuff that looks like twisted craft paper as a tacking strip. But I have pulled the tacks out and have seen no other function. In the past I have replaced it with wood strips. I will say that the wood is not flexible like the paper getting it into that slot.
CJD
Funny, Steve! We should put oakum all around the cockpit. It's definitely wood, but it's always a weird, twisted, wood.
JohnGone MGB Wood Dashboard Kits MG 1
algot1901 50 Prefect wood roof support / bow Other British Cars 8
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
B Wood Braces, Hardtop Austin Healey 3
NutmegCT Exterior wood finish Restoration & Tools 21
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
L Replacing veneer on wood dashboard Restoration & Tools 14
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
Rut TR4/4A TR4 wood dash Triumph 26
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
R Wanted wood steering wheel Jaguar Classifieds 0
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Gliderman8 General TR Wood rimmed steering wheels Triumph 20
J TR2/3/3A Mystery Wood Triumph 7
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
KVH TR4/4A Refinish Wood Dash Triumph 7
P BN2 new wood steering wheel install Austin Healey 5
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
TomMull TR2/3/3A door wood Triumph 36
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Griz Wood for convertible top Austin Healey 3
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
S TR2/3/3A beach wood- wooden handled screwdrivers Triumph 6
Got_All_4 TR2/3/3A Wood on frmes Triumph 11
J BJ8 Battery Support Wood Block is it 3/4" or 3", ours is 3"? Austin Healey 5
E Singer wood frame help needed. Other British Cars 3
J TR2/3/3A Wood strip in B post. Triumph 3
JimTR4 TR4/4A Does a 4 wood dash fascia fit a 4A? Triumph 2
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
J Wood dash for 60 BN7 Austin Healey 16
Jim_Gruber Wood Steering Wheels Spridgets 26
CJD TR2/3/3A Jacking Without a Wood Block Triumph 12
AHS TR2/3/3A Removing cowl wood? Triumph 7
GBRandy Jaguar XK 120 Dash. Wood or wrapped? Jaguar 4
Lukens TR2/3/3A Wood TR3 dash Triumph 10
J New wood pieces for the doors Triumph 9
hutten Wood steering wheel restoration vendors? Triumph 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
S REPLACEMENT WOOD DASH Triumph 12
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
Stinger TR4/4A TR4A Wood Dash Refinishing Triumph 18
5 Hardtop wood blocks Austin Healey 3
M need wood piece for convt top Austin Healey 1
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
CJD Door Wood Triumph 11
tahoe healey BJ8 wood bow covering Austin Healey 4
jsfbond Wood Bros. Racing Racing 6
memphis Wood Bow to Window Gap Austin Healey 20
