Boot Liner - BJ8
SteveHall64Healey
Can anyone confirm the material and color of the boot liner/carpet used in BJ8 phase 1? The concours guidelines and two reference books (Clausager and Piggot) state that the BJ8 was finished in black armacord. When I bought my car in 2011, it came with very old black carpet - sufficiently old that I assumed it was original....
Patrick67BJ8
I’ve never seen a carpeted boot except when done by a owner as a substitute to the original material or going for a custom look.
vette
For what its worth I'm pretty sure it is suppose to be black armacord. By BJ7 had black armacord when I bought it and I am still using it. Unfortunately I have no pictures of it at the moment. I am of the same persuasion as Patrick that I have never seen a carpeted boot in any Healey unless it was installed by the owner.
gonzo
No shag carpet here just plain 'ol black armacord. It's also possible the PO carpeted over the original armacord on your car. Worth checking first. If needed, get fitted kit(s) from the usual suppliers and make sure all exposed edges are finished and bound.
S
SteveHall64Healey
Thanks - I have checked under the carpet and definitely no armacord. I am contemplating a kit from Ahead for Healeys. Has anyone used this kit?
dezand
I have used the one from John Skinner in the UK and it worked out quite nice.
Before and after pics, used the instructions from Rich Chrysler
Healey Nut
Both my BJ8 kits came Moss I think , installed by me , not a difficult job but the backing stuff they use is itchy .
I also have a good useable kit if your looking to safe a few $$$$
PM for details .
RAC68
Hi Steve,
As I remember, the boot of the phase 1 BJ8 was finished in Armacord layed (not glued) over the fuel tank and glood on the forward panel and two sided panels. There was a cheap looking piece of leather-grain imprinted cardboard folded around the 2 sides and screwed into the fuel filler housing. An equally cheap looking piece of thin vinyl heat-formed for a battery cover and the base of the spare tire securing rod was covered with a piece of leather-grained vinyl material. All vinyl coverings and other, along with the Armacord coverings and flooring were Black in color.
Hope this helps,
Ray(64BJ8P1)
RTaillieu
Steve, it looks like you're in Ontario.
Call up Autofarm and get the kit from them, (519) 356-2427.
https://autofarm.net/
They are a great bunch and specialize in Healeys.
Best of all the shipping is cheaper. no customs hassles and you pay in CAD.
I bought the kit from them and it went in easily and looks great.
dezand
when I did my new liner, getting the old contact cement off was tough. First I tried solvents, but if was a mess and didn't work very well.
what really did the job was buying this:
https://www.amazon.com/Closed-Rubbe...polyethylene+foam&qid=1573239430&sr=8-11&th=1
and attaching it to this:
https://www.amazon.com/3M-5-Inch-Sa...ords=drill+sander+disc&qid=1573239739&sr=8-12
That took all of it off quite fast. I went through four foam pads to do the entire trunk.
This might work too:
https://www.amazon.com/TCP-Global-R...+drill+adhesive+remover&qid=1573239878&sr=8-5
Rob Glasgow Boot Liner Edge Finish Austin Healey 11
tahoe healey boot liner/spare support Austin Healey 8
tahoe healey boot liner Austin Healey 6
G Wanted Tr4a boot lid Triumph Classifieds 2
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
AUSMHLY Boot Lid Identification Austin Healey 2
J Restoration Progress - Boot Installed Austin Healey 1
B BJ7 Boot Trim Austin Healey 7
B Fitting the Boot Lid Seal Austin Healey 8
chicken Boot Lid Badge Austin Healey 8
F TR2/3/3A Boot floor Triumph 50
steveg TR6 Dealing with Rack Boot Triumph 3
steveg TR6 Steering boot clamp wire - why? Triumph 2
T How do you cover your battery in the boot? Austin Healey 5
S Securing the jack with strap in BJ8 boot Austin Healey 11
Michael Oritt Boot floorboard? Austin Healey 9
C Under boot and under bonnet paint? Austin Healey 7
tahoe healey Leak into boot Austin Healey 17
B TR6 Boot lid thread plates loose in stiffener Triumph 1
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
B Soft Top Boot Cover - BJ7 Austin Healey 5
A BN2 Boot Lid Austin Healey 4
W Gear Lever Boot for BN2 Austin Healey 5
ckeithjordan TR2/3/3A Boot Trim Triumph 3
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
B Dynamat in Boot? Austin Healey 7
S TR4/4A Fascia support and shift rod boot Triumph 0
S TR4/4A Handbrake cable rubber boot at clevis pin end Triumph 1
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
CJD TR2/3/3A Boot Seal Pics Triumph 17
J BJ8 boot rubber strip Austin Healey 9
CJD TR2/3/3A TR2 Boot Strip Triumph 22
K TR4/4A TR4A vinyl top boot cover factory markings??? Triumph 0
K TR4/4A Black marks on a TR4A/TR6 vinyl top boot cover? Triumph 4
Rut TR4/4A Boot and bonnet bodywork. Triumph 4
D boot rubber ??? Austin Healey 2
Rut TR4/4A Parts in boot Triumph 11
SASSAMON TR2/3/3A TR3 Boot Construction Info Wanted Triumph 2
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
R Boot hinge support brackets for BJ8 MKIII Austin Healey 4
T TR2/3/3A Rubber gear shift boot tearing Triumph 14
Tinkerman TR2/3/3A 1960 TR3A Boot rubber seal installation? Triumph 7
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
