Sound proofing recommendations
DerekJ
I know most of you guys over the pond are more concerned about blocking heat rather than sound but I’m hoping somebody has some good suggestions for the latter. My car is relatively stripped out plus it has straight cut gears, a side exhaust, triple Weber’s and a rally cam. The result is a lot of noise which is amplified by the hard top. I know Healey noise is great but I’ve reached the stage where I’d like a quieter cockpit when I’m driving to events.
Dynamat extreme seems to get good reviews. I’ve looked at some videos of theirs which show the product deadening the sound of symbols and doors closing with a thud rather than a tinny sound. I’m no physicist so I don’t know if deadening the resonance of sheet metal is the same as preventing engine and gearbox noise penetrating the cockpit or whether that requires a different product/solution. The gearbox tunnel is fibreglass so is not going to behave the same way as sheet metal.
Look forward to hearing your experiences, comments, ideas and suggestions.
cheers
I just finished installing Kilmat in my BJ8 (after rust-converting and painting the floor pans). This is apparently a Dynamat knock-off that is considerably cheaper, and made in good ol' Russia! Quality was excellent, and 25 sq ft was sufficient to cover the floors, sans the firewall:
I covered the Kilmat with furnace insulation, glued Al surface to Al surface, then put new nylon Cocomats on top (got tired of the rubber floor mats sliding around). I haven't driven the car much but, certainly sound has been deadened as I'm now hearing sounds I didn't before (uh oh). I think doing the firewall, i.e. the inside of the pedal boxes would cut sound even more. I don't know how much of the noise in a Big Healey is due to floorpan resonance and not wind or exhaust--I have a loud one--noise, but is has to help some, and the furnace wrap cuts heat and keeps the Cocomats from sliding around (they have 'nubs' on the bottom):
https://www.homedepot.com/p/UltraTo...er-with-Recycled-Cotton-30000-11406/100656748
MarkP
I went with LizardSkin as they have two products that are applied over each other. The Sound Control is sprayed on and can be applied at a desired thickness. Over that I applied their Ceramic Thermal Insulation for heat management. Another advantage is that the product does not absorb water/liquids vs mats. With interior out I masked off the area and protected areas I didn't want LizardSkin with painters paper. Overspray was minimal to non-existent due to the material itself.
PHulst
Bronze
If you have a lot of spare time you can read all 1725 posts in this thread, but there was an exhaustive testing done a few years ago. Results are in this post:
https://www.diymobileaudio.com/forum/3522882-post1725.html
Unfortunately it appears that the top rated material is now not available, as Sound Deadener Showdown's owner retired.
However, the site still has a lot of information regarding technique and application that I would recommend reading.
I hope that helps.
Add: I did more digging the diymobileaudio forum.
The new recommendation is Dynamat Extreme for the base layer.
vette
I also went with Lizard Skin. Two different products one a heat barrier the other a sound barrier. I'm very happy with the results. My interior stays pretty comfortable and never too hot. When you spray it on it is very wet and you think it will never dry, it is water based. But it drys perfectly.
This what it looks like:
DavidThorn
I am interested in this thread for a different reason.
I am not concerned about noise or sound deadening in my BJ 8 but I would like the doors to shut with a nicer heavy sound rather than the slightly tinny noise I get a present.
I have looked at various products which claim to help but they all talk of how light they are, I would have thought for a nice satisfying clunk some weight would be needed.
Any thoughts ?
David Thorn
HealeyRick
Any thoughts ?
David Thorn
I think you'd be looking for an anti-vibration material for the doors, something like this: https://designengineering.com/boom-mat-vibration-damping-material/ I believe the "thunk" comes from the deadening of the vibration of the outer door skin and it's cured by sticking material to the door. Healeys do have a distinctive sound when the doors shut, but it's certainly nor Mercedes-like.
My BN2 has a very satisfying 'thunk' when you close its doors. I lined the inside with insulation that's like a thin bubble wrap with an aluminized sheet; otherwise, these early cars only have, I believe, a layer of leather or vinyl glued to them. I think any sound-insulating material--LizardSkin, Dynamat, etc.--would work.
N MGB-GT Carpet, sound proofing, and painted bumpers, Oh My! MG 15
DNK Por 15 & Sound Proofing Triumph 9
Patrick67BJ8 Insulation and Sound Deadening Austin Healey 0
M TR6 Clicking sound when accelerating Triumph 11
tr6nitjulius General TR Sound of TR6 Side by Side singing 2gether Triumph 0
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
nichola TR6 Stock exhaust sound... short video Triumph 4
EWD TR6 Sound/Heat Mat installation - 74 TR6 Triumph 14
J TR6 Does this sound ok to you? Triumph 5
EWD TR6 ‘74 TR6 Interior - Padded dash and heat/sound material Triumph 4
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
maxwedge5281 no sound when breaking the christmas bulbs??? Austin Healey 16
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
C A better sound for a Miata? Other Cars 0
GTP1960 TR2/3/3A Loud scraping sound in clutch area Triumph 12
T sound for a bug-eye??? Spridgets 2
W Sound 1966 Sprite rolling chassis Spridgets 0
HealeyRick Alternative Sound Systems Restoration & Tools 2
AN5Sprite F1 Sound Comparison 2013 vs 2014 Racing 2
Boggsy64 MGB Sound deadener MG 4
drambuie No sound affects when breaking those little Christmas lights! Austin Healey 16
M Replacement Sub-Woofer for X308 99 XJ8 with Premium Sound System Jaguar 1
drambuie Getting a better deep throaty sound from my Stainless exhaust Austin Healey 5
JPSmit What is that strange grinding sound in the distance? Spridgets 3
C BJ8 Stainless Steel Exhaust - throaty sound ? Austin Healey 4
KVH Strange Sound Like Compressed Air Escaping Triumph 14
T TR2/3/3A Has anyone put sound deadening in a TR3. Were the results worth it? Triumph 21
P Engine noise ~ Garbage disposer sound Triumph 9
Kleykamp TR2/3/3A clanking sound at idle on TR3 Triumph 17
7 squealing [Humming] sound rear DRUM brakes Other Cars 3
G Undercoating/sound deadening removal Spridgets 5
M Sub-woofer Speaker for 99 XJ8 with Premium Sound Jaguar 1
regularman heard a clicking sound and found the cause Spridgets 6
bugedd The sound of silence Spridgets 9
M exhaust sound different. brith/jap Spridgets 14
T Scraping sound and puddle Triumph 2
T What do these symptoms sound like to you? Triumph 22
Musicman Strange Clicky/Tappy Sound Triumph 6
DNK Out in the Sound... Spotted 3
tr5er sound problems Triumph 13
G Healey Sound Austin Healey 15
RichBall Oh, That Sound Spridgets 19
DNK 'Nother Dreaded Sound Deadening Question Triumph 19
Gundy New video w/ sound Spridgets 22
Superwrench sound deadening Austin Healey 2
7 New Day...New sound...This one sounds awful Triumph 12
BugeyeNJ58 Klunging sound on deacceleration Spridgets 7
