Center Gearbox Input shaft bearing
robolab
I disconnected the clutch housing from the center-gearbox and found that there was no spring washer and washer between the input shaft bearing and the housing as described in the service manual (position 3 and 4 in the Moss diagram).
Now I have seen that these two parts are not available at AH Spares and Moss. Instead, AH Spares offers shims of varying thickness. But how do you determine which shims you need to fix the ball bearing between the two housing parts?
vette
Gerd, I don't have any experience with the Healey trans, but with some experience with an MGA trans I remember that the object was to shim so that there was no end float in the shaft. But not really tight.
R
robolab
Many thanks Vette
I downloaded the pages "Rebuilding the MG gearbox" from Mgaguru.com. Although the gearbox is slightly different, most parts of the description are also applicable to the Austin Healey transmission. Also, the description is much more detailed than the AH workshop manual.
R
robolab
Very good videos, thanks for the link.
R
robolab
When disassembling the gearbox for my MKIII / BJ8, I counted 66 bearing needles for the 2nd and 3rd gear bearings.
At all spare parts suppliers, however, only 65 (32 33) needles are always specified for the two bearings.
Does one needle now belong in another position in the gearbox, or are 66 bearing needles used on the BJ8 main shaft?
grimes6
The parts book shows 33 needles for second gear and 32 for third gear . I can't find any other use for the extra needle in the BJ8 gearbox .
Greg
grimes6
From the parts book both the items ( 3 and 4 in your diagram) are actually shims 22b132 and 22b133 .
regards,
Greg
grimes6
The parts book can be accessed via [FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]https://lbcdigital.com/bmc_publications/akd3523/[/FONT]
D 62 center shift gearbox Austin Healey 11
D 1962 center shift gearbox cover Austin Healey 7
timsgolf Center Dash Switch Plate Painting Austin Healey 5
B TR4/4A What is this Steering Wheel Center? Triumph 6
BoyRacer Moss Motors Center Consoles Austin Healey 0
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
WHT Center-Shift Bellhousing Austin Healey 10
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
M TR6 Center cap for wheels Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R Turn Signal Knob goes off center Austin Healey 9
J Nut size for BJ8 center console trim piece Austin Healey 8
AUSMHLY Distributor cap center pin melted Austin Healey 5
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Rut VTO center caps Spridgets 3
glemon TR5/TR250 Steering Self Center Triumph 4
maxwedge5281 steering tight in center position of steering wheel Austin Healey 2
KVH TR4/4A Center Console Recovering Triumph 10
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
L Light for BJ8 Center Dash Panel Austin Healey 17
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Triumph Herrld center bonnet moulding, [chrome strip] Triumph Classifieds 0
55modified Splined mag wheels? Who makes or machines them without center adapter? Austin Healey 5
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
G BJ-7 Center Shift Gear Lever and bush Austin Healey 4
Joe Schlosser Transmission Tailshaft housing off center Spridgets 3
Lukens For Sale Classic center armrest/console for tr2, tr3, tr3a, tr3b, and tr4 Triumph Classifieds 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
A turn signal knocked off center Austin Healey 14
charleyf TR2/3/3A Center main cap engine Triumph 4
Raven62 Superlite wheel center caps Spridgets 0
Lukens TR2/3/3A TR2-3-4 Center armrest Triumph 3
GTP1960 TR2/3/3A Arm rest center console? Triumph 14
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
Bob_Spidell Center shift boot Austin Healey 13
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
Got_All_4 Wedge Can this center console be refurbished Triumph 10
M TR2/3/3A Finding top dead center Triumph 6
maxwedge5281 center shift transmission shifter Austin Healey 3
Boink Center justification on everything now... FORUM Navigation Questions 3
A TR-3A wooden center dash panel photo??? Triumph 3
F Adivce on how to center jets of SU HD6 carbs Austin Healey 3
B TR2/3/3A tr3b center exhaust hanger Triumph 3
P Turning to Top Dead Center Austin Healey 11
Boggsy64 MGB What is the purpose of the center assembly at tranny mount? MG 2
MikeAH100M Center Support for 100 Dashboard Austin Healey 8
Bruce Bowker BN2 center horn button assembly Austin Healey 21
