1962 center shift gearbox cover
  • Thread starter Deleted member 21878
  • Start date
i would like to recover the vinyl on the tunnel at the gear shift. this is a center shift gearbox.
at first glance it looks easy to do... but then it looks like it could be easy to wrinkle. i wondered if there is a video or pictures or some instructions on the best way to do this.
Thanks
TL
Healey Nut
Fairly easy to do as 90% of the vinyl isnt even seen once the tunnel is in place with shift grommet and console in place .
Cut a small hole maybe two inch dimeter in a piece of vinyl then lots of slits around its circumference once its glued in place to wrap inside the cover .
thanks. my old one is made a little different. not sure i can get a proper pattern from it.
so do you wrap the sides and leave a seam in the front? then push it over at the top and cut out for the hole?
Healey Nut
Cut an oversized piece of fabric .
Cut a 2” hole in it (centred ) and glue it to the flat top portion . Now cut slits in it 3/4” apart around the circumference and fold/wrap them into the hole to glue them down .
LET IT DRY !!!!
Now apply more spray on contact glue and use the oversize amount to pull /stretch (carefully) down the sides .
LET IT DRY !!!!!
cut off the excess .
Done .
made an attempt today to cover this piece. did not go as easily as i hoped. guess i don't have the talent or something.
tried cutting the hole and the slits, then gluing the top. let it sit and then clamped it. but i could not get the sides down without wrinkles. tried everything i could think of.
so i ended up cutting a slit at the front. worked the back on and then around to the front. as i did, i just tried to work it over the top and keep the wrinkles under the boot. of course it leaves a seam in the front but you can not really see it once in... unless you really look.
i expect i will replace this piece again when i actually do the interior... maybe next year... to get the color right. Mine is painted to the color it is now. by then hopefully i can figure out how to do it better.
couple of pics:
first off the attempt at doing the top first.
cutting the slits.
clamped
wrapped. still had a few wrinkles to work out. have left clamps on them tonight.
this is what i pulled off which is why i did not have a pattern. think mine looked better than this one anyway. it had open seams all over. guess the guy had no more of a clue than i did.
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
CJ Burton MGB-GT Installing Seat Covers for 1962 - 1967 MGB GT MG 0
G 1962 TR3A inner plate # Triumph 8
C MGA R/H tail lamp removal on a 1962 MG 5
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
S For Sale MG MGB Factory Parts Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
S For Sale Triumph TR2/TR3/TR3A/TR3B Workshop on CCD/ROMManual – 1953 - 1962 Models Triumph Classifieds 0
S For Sale MG Midget Workshop Manual on CD/ROM - 1962 - 1974 Models MG Classifieds 0
S For Sale MGA Factory Workshop Manuals on CD/ROM - All Models 1955 - 1962 MG Classifieds 0
S For Sale MG MGB Factory Workshop Manual on CD/ROM - 1962 - 1976 Models MG Classifieds 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Spridgets Classified 0
S For Sale Austin Healey Sprite and MG Midget Factory Workshop Manual on CD/ROM – 1962 - 1974 Austin Healey Classifieds 0
H Estimating a Singer Gazelle IIIC from 1962 Other British Cars 3
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
CLB62 1962 Austin Healey BT7 Mk II Austin Healey 15
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
LarryK General TR 1962 Herald Convertible Triumph 10
R Sprite Bonnet Badge 1962 Square Body Spridgets 1
O Wanted 1962 tr4 seat rails Triumph Classifieds 0
S 1962 BT7 transmission shift rail bumber in bell housing Austin Healey 1
C For Sale 1962 Triumph TR3A Triumph Classifieds 3
P 1962 Sprite in Venice, FL Spridgets 0
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
S My dads 1962 Mk2 Austin Healy finally seeing light since 1981. Austin Healey 4
R 1962 barn find Triumph 9
R 1962 Barn Find Restoration & Tools 7
6 Spitfire 1962 Spitfire, Hood parts &installation info Triumph 7
6 Hood parts and installation instructions for 1962 Triumph 1
Anthony_S Post-War Other 1962 Herald Triumph 4
Marvin Gruber 1962 OTS XKE Jaguar 11
F Road & Track 3000 road test- November 1962 Austin Healey 8
me61ic 1962 BT7 for sale in NY Austin Healey 0
C 1962 Austin-Healey BT7 value? Austin Healey 17
V 1962 BN7 Price Austin Healey 4
J AH 1962 - Putting on Front Fenders Austin Healey 8
V 1962 E-Type Jaguar 14
D TR4/4A 1962 TR4 - For Sale in Montana Triumph 3
M 1962 AHS ebay Spridgets 3
AUSMHLY Astro hard top for 1962-1968 Healey Austin Healey 7
C I found a 1962 today! Spridgets 4
J 1962 3000 MKII BT7 Water pump replacement Austin Healey 3
af3683 TR2/3/3A TR3B - Register it as a 1962 or 1963? Triumph 19
C 1961-1962 Sprite, What chasis and Frame? Spridgets 4
C Austin Healey Chasis/Frame for 1962 Austin Healey 4
