TR2/3/3A Engine plate question
LionelJrudd
Is the front engine plate completely flat. Mine is slightly bent at the right hand engine mount. (Viewed from the front of the car) Could be damaged from a collision because it looks like the bend extends into the area where the timing cover bolts on. Looks easy enough to press flat if that is how it is supposed to be.
As an aside, someone has previously enlarged the holes fot the engine mounts with an oxy acetylene torch. Had to refill them with the tig, grind back with a flapper disc and redrill the holes.
TR3driver
Great Pumpkin - R.I.P
Yes, I believe it is supposed to be flat.
TomMull
That plate is very vulnerable to bending from even minor impacts. My TR3 had been hit in the front and repaired before I bought it. That plate was not part of the repair even though it was bent more than 10 degrees. I drove it for many years that way and never noticed the bend until I found I was unable to withdraw the steering box.
I found a good used one but I think it could be straightened although I never tried it. I think you can get a new one in aluminum.
Tom
sp53
Yes I believe they are flat also. There is a spot where the timing chain tensioner rides and in that area a grove is often cut. The fix is what you did with the holes in that you fill it in and grind it flat. Plus many times the little hole for the stud that holds the timing tensioner is striped. I think it has like 3 threads and the stud should sit perpendicular to the front plate or it could rub the tensioner uneven. Those tensioners can be fickle and when they act up the repair is a deep dive to fix them.
TR3driver
If you are interested in an aluminum one, email Joe at N197tr4@cs.com I don't know if he still has any available or not, but he got a run of them made a few years back.
L
LionelJrudd
Thanks for the confirmations gentlemen. I will just put the plate on the press and should be able to iron the wrinkle out.
Aluminium sounds nice Randall, but this is definitely low budget work and very little new stuff other than absolutely necessary or what I can repair or fabricate myself is being used.
steveg Rear Engine Plate sealing question Austin Healey 8
R Engine Number Plate Austin Healey 2
FlyingCat Spitfire Engine Back Plate Triumph 2
L First 100 Engine Serial Number Plate Austin Healey 13
R TR6 Engine Plate Gap? Triumph 2
Jim_Gruber Engine Adapter Plate Diagram Spridgets 5
M Attaching Info Plate to Engine Spridgets 1
Rut TR4/4A Engine number and body plate Triumph 5
WillR MGB Rear engine plate MG 8
KVH TR4/4A Front Engine Plate Curve Triumph 4
dklawson Sorry... Urgent Request for Friend - Marina Front Engine Plate Other British Cars 2
dklawson MGB Sorry... Urgent Request for Friend - Marina Front Engine Plate MG 3
Scotsman TR2/3/3A leaking front engine plate Triumph 4
R BN1 & BN2 Engine # Plate Finish Austin Healey 25
mt10flyer TR2/3/3A Front Engine Plate Triumph 8
memphis Engine Side Cover Plate Oil Leak Austin Healey 15
bighealeysource Installing new engine ID plate Austin Healey 7
S MGB MGB engine mounts - "extra" plate? MG 2
Z 100 engine/gearbox adaptor plate Austin Healey 3
vping Aluminum rear engine plate MG 9
Lin Engine number plate Austin Healey 5
L help with engine backing plate MG 3
L replacement engine number plate? MG 6
A Rear engine plate split in two! Spridgets 9
Mickey Richaud Engine ID Plate MG 4
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 3
L Engine ID British Motor Corp 2
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
