TR4/4A door seal channels
shoopal
Hi all
I tried using the TR6 door seals which don't require the channels but they are thicker and the doors don't close properly. So I want to use the original style but the channels above the rocker panel and up the sides have rotted away. I have the replacement strips but I am not clear how to bend them so that they don't crimp up but fit along the inside curve of the door frames at the bottom. A check with Moss 802-060 tells me it only comes as a straight piece and their notes say "it can be difficult to bend them" Maybe I can install them in small sections or make relief cuts to enable them to be bent?
Any good tips?
Al Shoop
KVH
I think any body shop with a stretcher/shrinker machine can do that. My friend has two of them and something called an English Wheel and he’d curve those in 30 seconds. Being somewhat tubular and small may be an issue but I doubt it. (Harbor Freight used to carry a cheap one but I’ve no idea if it would work)
KVH
And here’s from HF, assuming tariffs haven’t made them scarce:
Use these metal shrinker and stretcher tools to recreate compound curves. ... Great for auto body trim work, and door panel edging, this metal shrinker and stretcher set is designed to create radius bends and contours in sheet metal. Hardened steel jaws have powerful force to curve and ...
M TR4/4A TR4 Door Seal channels Triumph 4
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Bayless Door seal question Spridgets 3
D Door Seal Fit Austin Healey 18
chicken BJ7 Door Seal Austin Healey 5
chicken Inner Door Seal Trim Position Austin Healey 6
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
B BT7 Door Seal Installation Austin Healey 13
S TR2/3/3A door seal windlace Triumph 8
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Got_All_4 TR2/3/3A What is this door seal for Triumph 15
R TR2/3/3A Door bottom seal Triumph 10
R TR2/3/3A Door seal Triumph 2
bugedd Door seal replacement Spridgets 11
S door glass inner seal Austin Healey 6
W TR6 fuzzy rubber door seal Triumph 3
vette Door Seal Austin Healey 4
W Fender > Door Seal Austin Healey 8
Jeepster Door to window brush seal Austin Healey 0
H TR4/4A Furflex door seal Triumph 3
B TR2/3/3A TR3b lower door seal question Triumph 3
H TR4/4A Outer door waist seal Triumph 5
Lbp TR2/3/3A Furflex Door Seal - Where does it go? Triumph 3
NutmegCT Source for rubber door seal material? Restoration & Tools 9
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
B BJ8 door seal attachement point. Austin Healey 4
B '72 XJ6 Door Seal Installation Jaguar 2
TR4nut TR2/3/3A TR3A door seal question Triumph 7
B door seal material an suppliers Austin Healey 2
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
Stinger TR4/4A TR4A Door Waist Seal Tool Triumph 8
F Replace 1500 Door Fuzzy Weather Seal Triumph 3
MadRiver BT7 Fuzzy Door Seal Install Question Austin Healey 1
CJD TR2/3/3A TR3 Rear Door Seal? Triumph 2
chicken Door brush and rubber seal Austin Healey 2
I Bugeye door seal help please Spridgets 8
D BJ8 Door Seal Orientation Austin Healey 6
V Another door seal question. Spridgets 5
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
P BT7 Door seal Austin Healey 15
R BJ-7 Furflex door seal installation. Austin Healey 1
Newkie General Tech How to Install Door seal-furflex MG 14
G BN6 door seal clips - how many? Austin Healey 2
I TR6 TR6 window door pull/window seal help Triumph 6
A Door/Trunk Seal Spridgets 5
NutmegCT TR2/3/3A TR3A door "draft seal" Triumph 3
R BJ& front fender/door seal. Is there one? Austin Healey 2
J Door seal color. Austin Healey 8
JPSmit rubber door seal question Other Cars 2
