New Member
terrencemc
Hey all, New member here. Southern Indiana. I've had my TR6 for six years now. 1969, royal blue. CC28286L.
Car had been apart before I bought it, previous owner tried turning it into a '73. Has a '70 motor in it. Weber MCHH carbs. 4 speed, no overdrive (and probably on its last legs) transmission. Fixing it as I go along. Finally got the front suspension dialed, but I still think it sits too high. Drove it for five years before checking the rear lever shocks, and found out the right side one was empty. New main wiring harness this year. Starter died on me two weeks ago, new one on the way. Besides the starter, everything works but the backup lamps, and the horn. Bought a new backup switch and it fell apart while I was putting it in, and the horn push slides through the hole in the steering wheel hub and grounds out the horn when it gets hot out.
Something new every day.
Administrator
Boss
Welcome to the fun, Terrence! You've come to the right place to get help (or give it) for your TR!
Hi, and welcome!
DavidApp
Hello Terrencemc
Welcome to the forum.
You will find the Triumph section is very active so you are sure to get plenty of tips, help and advice for your TR6 project.
David
