TR2/3/3A Oil? Oil Pressure?
HighAltitudeTR3
Is it ok to run 5W30? My oil pressure is all over the map. It was 60-70 psi @ ~3000 RPM. But then it dropped to like 20 at idle (I run my idle around 1,000RPM). I’m guessing this is from the oil I used. Is this safe? 20psi seems very low, but 70 psi seems good. I can thinken it up with Lucas oil, unless this seems ok. 🤷🏻*♂️
Mickey Richaud
I'm with Andy here. Most British car folks have Castrol 20W50 runnin' through their veins. :wink:
martx-5
Yeah, 20W50 or 10W40 should be fine for the cooler temps in CO. Also, there are concerns by many about the lower amount of ZDDP in modern oils made for cars with O2 sensors, and the effect it has on flat tappet cams such as the Triumph has. You can google that and have enough reading for a month or so. There are oils that have sufficient amounts of ZDDP, so probably best to search them out. I use 20W50 Valvoline VR1 Racing oil. There are ZDDP additives, but better to leave the oil chemistry to the pros. Your oil pressure values are normal. Since the oil pump is spinning at lower speeds at idle, less oil volume and pressure are produced. As RPMs increase, there's an oil pressure relief valve in the system that limits the pressures to between 60-70 PSI. It is adjustable, but yours is where it should be.
CJD
I've been running 5w-30 for 3 years with no issues, and plan to try 0w-20 at the next oil change. Using 20w-50 was started to extend the life of long worn-out engines, with excessive bearing clearances and low pressure as a result. Since most of our cars are over 50 years old, and well worn, most are using 20w-50.
20 PSI at idle is fine.
TomMull
I've never been too fussy about engine oil and have had little success at raising oil pressure with heavier oil. I do however try lately to use ZDDP(Zinc dialkyldithiophosphate) oils as the evidence for its use seems quite compelling. I'm using Lucas Hot Rod Oil, 10-40 right now, mainly because it was available locally and only slightly outrageous in price.
The Castrol cans would look better on my shelf so I looked into that. The Castrol Classic XL 20x/50 is $29.85 per gallon right now from Rimmers but if you happen to have a Fiat Dino, that same gallon of Castrol Classic XL 20x/50 is $109.00 https://www.ebay.com/i/312366566221...MIh6jo-5_u5AIVVeWGCh3AkAS9EAkYBSABEgJEZfD_BwE. I'll bet if you have a Ferrari it is even more.
I sure am glad I have have British cars.
Tom
poolboy
......... Using 20w-50 was started to extend the life of long worn-out engines,..........
Is that so ? The part about the 20w-50..I thought that recommendation was for new engines as well. I know that viscosity is a common recommendation in the TR6 owners handbook. New TR3 engines had different requirements or recommendations in their manuals ?
TomMull
The manual for the TR2/TR3 is of little help although there may have been a service bulletin on recommended oils at some point. There were no multi viscosity oils at the time and I think the viscosity rating systems have changed too. I do remember putting 50w in mine in my youth when the idle pressure bounced on zero and the bearings started to complain audibly but for what it's worth here's what the FSM says about SAE rating:
Temp F. SAE
>70.....................40
40 to 70.............30
10 to 40.............20
-10 to 10.............10
<-10.....................5
If I followed the book, I'd have to change the oil several times a day here on New England.
Tom
CJD
I’ve rebuilt a lot of cars on quite a few forums. It’s predictable...while the cars are still new, the recommendations are straight out of the manual, but in threads about vintage (read old) cars, everyone is using 20w-50, as it’s the thickest you can easily find. Not just a Triumph thing...more of an old car thing. I figure the majority of owners will tackle a few minor repairs, but the number willing to rebuild an entire engine is actually very few in the big picture. It’s so much easier to use a thicker oil than to replace all the bearings.
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G High Oil Pressure Austin Healey 2
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
A MGB Oil pressure MG 9
K TR2/3/3A Oil pressure readings Triumph 10
J Oil Pressure Relief Valve Austin Healey 3
L Oil Pressure Gauge Austin Healey 5
LAW75 Oil Pressure Austin Healey 4
D TR2/3/3A oil pressure line venting? Triumph 4
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
R Bugeye oil pressure line Spridgets 9
K TR2/3/3A Oil pressure readings Triumph 3
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
S TR6 Oil Pressure Light Triumph 2
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
Kurtis No oil pressure Spridgets 5
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
V Braking Oil Pressure Austin Healey 16
N Suspected disaster - but it went well. Oil pressure restored. Austin Healey 1
S TR2/3/3A Oil pressure gauge removal Triumph 11
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
JFS TR6 No oil pressure Triumph 2
Simmo TR2/3/3A High Oil pressure Triumph 11
D TR5/TR250 High oil pressure Triumph 5
T TR6 Low Oil Pressure Light Triumph 3
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
K Time to build oil pressure Austin Healey 23
M TR2/3/3A Oil Pressure Gauge Line Fitting Triumph 8
D BT7 oil pressure relief valve Austin Healey 19
D BT7 oil pressure relief valve Austin Healey 2
J Zero oil pressure at 4000 RPM Austin Healey 24
D TR2/3/3A oil pressure Triumph 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
S An oil volume question and an oil pressure question Austin Healey 5
L Wanted WANTED: good Working Oil Pressure GAUGE Triumph Classifieds 0
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
K TR4/4A Oil pressure gauge Line? Triumph 5
B TR2/3/3A normal oil pressure in TR3 Triumph 6
Gliderman8 TR6 Stainless oil pressure line install HELP! Triumph 8
L 100 spin on oil filter part number, no oil pressure after replacement Austin Healey 8
G Need Help: Oil leak/crankcase pressure Spridgets 18
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
6 General Tech Installing New Oil Pressure Gauge MG 5
6 Installing Oil Pressure Gauge Spridgets 2
