Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Master cylinder packing pieces (shims)
  1. #21
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,748
    Thanks Thanks Given
    90
    Thanks Thanks Received
    142
    Thanked in
    Re: Master cylinder packing pieces (shims)
    Dave -
    Just checked and the most of the play (clutch) seems to be wear between the clevis pin and the pedal bellcrank. Then when I feel the pushrod move against the piston there seems to be a little more light travel before I'm pushing against the clutch itself - perhaps that's in the Toyota clutch operating lever.
    FWIW my clutch pedal is about 1/4" higher than the brake pedal.
    Will need to tighten the clutch clevis up a little.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  2. #22
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,789
    Thanks Thanks Given
    16
    36
    Thanked in
    Looked in my BJ7/BJ8 Service Parts Manual. It shows 2 packing pieces required for both the clutch and brake master cylinders for all the non-servo BJ7s and BJ8s. BUT, the master cylinder on the BJ8 cars with servos is of a different design. It has an adjustable pushrod and the manual lists no packing pieces for that cylinder. Feel free to hypothesize further, gentlemen.
    Rick
  3. #23
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,709
    Thanks Thanks Given
    13
    Thanked in
    Red57, In reviewing your pics i will have to say that it seems that adding shims will effect the height of the pedal, but I honestly don't remember that being the case. Also as seen in your pics the pedals will swing an inordinate amount of distance to the rear if not connected to anything. then it follows that what stops their rearward swing is the rod hitting the back/inside of the washer/spring clips in the bores of the master cylinders. But this rearward travel is not what I believe is the larger concern. I am still concerned that the shims are there to control the forward travel/insertion of the
    piston irregardless of the height of the pedal. I have read generically about master cylinders and the cups on the pistons usually must travel in a very specific zone. Outside that specific zone you will either destroy the cups or the MC just won't work. Your study of the geometry of the layout is admirable but I don't have any idea why they did what they did, but then......the angle and distances of those short operating levers that attach to the clevis' were engineered, they weren't random. Here's another intrig. Don't be so sure that those pedals didn't come from another car.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  4. #24
    Join Date
    Nov 2011
    Location
    Martinsville NJ
    Posts
    492
    Thanks Thanks Given
    2
    Thanked in
    Regardless of why they are used, the design of the packing pieces suggests they could be installed without totally removing the master cylinder. The two-piece design, plus the open slot to go around the bolt, suggests a retro-fit. Some early illustrations show the two-piece shims without slotted holes for the bolts. I have never actually seen those on the cars I have taken apart, but have plenty of the slotted ones.
  5. #25
    Jedi Knight Lin's Avatar
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    945
    Thanks Thanks Given
    5
    4
    Thanked in
    I put the new clutch and brake master cylinders in last week. My previous set-up had shims on the brake master and no shims on the clutch master. The brake pedal sat higher than the clutch pedal. With the new set-up, I installed shims on both the clutch and brake master. The pedals are now just about even. The shim definitely moves pedal height. I am not disputing Vette’s Theory about the degree of piston travel in the master cylinder, but I am of the opinion that the shims are all about setting a functional and comfortable pedal height. You need to have the brake pedal position properly relative to the accelerator pedal, and then you need to adjust the height of the clutch pedal to make it about the same height of the brake pedal. Just my thought - all theory. Sure wish the Healey men were around to respond to some of the esoteric discussions that we often find ourselves in.
    Lin
    1959 AN5 Bugeye - now with my son 😀
    1960 BT7 3000 MKI
    1987 Alfa Romeo Spider Quadrifoglio
  6. #26
    Darth Vader Marvin Gruber's Avatar
    Join Date
    Jan 2003
    Location
    Florence, Al
    Posts
    2,996
    Thanks Thanks Given
    1
    3
    Thanked in
    Never seen or heard of shims or spacers on the master cyl before. Must Have been a PO thing. With new parts nowaday who knows what we are getting.
    Marv
  7. #27
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,973
    Thanks Thanks Given
    5
    51
    Thanked in
    Quote Originally Posted by Lin View Post
    ... you need to adjust the height of the clutch pedal to make it about the same height of the brake pedal. Just my thought - all theory ...
    Offhand, I can't think of a solid reason why they have to be the same height; maybe a matter of personal preference? The last time I worked on my BJ8's clutch I forgot to install the shim that was in there when I bought it, but never gave it a thought one way or another. FWIW, my '19 Mustang's clutch pedal sits a good half-inch higher than the brake pedal, and I never thought much about that either (until now ). Any of you racers know a good reason to adjust clutch and brake pedal heights (besides personal preference?).
  8. #28
    Join Date
    Apr 2006
    Location
    Fleming Island, Florida
    Posts
    304
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    I know I have encountered one or two shims while replacing my brake and clutch cylinders, and I have seen both adjustable and non adjustable versions. Not much that I would add to the discussion, but . . . . I posted a recent blab on this forum about my clutch function going away, i.e. the clutch locked out of contact, the pedal impossible to compress. When I loosened the hydraulic line at the slave, the clutch arm released the clutch into engagement. I determined that this event occurred because of what might have been an overly aggressive clutch push on my part. The slave piston was pushed so far out that it hung on some corrosion or buildup of unwanted material in the slave's bore, holding the clutch out of contact. I had an earlier experience of this happening briefly while underway but didn't recognize the issue. So clutch cylinder and slave motions can produce some little-recognized issues. My event occurred with a Smitty Toyota conversion, so the match of the slave cylinder and a non-factory bell housing, etc, was probably sort of trial an error when that system was being created. Though we aren't purists, I think most of us with these conversions find them pretty successful.
    Owner of a 1960 BN7 with Toyota 5 speed and a '92 Porsche 968 coupe. Former owner '62 Jaguar MK2, MG-TF brought back from military service in Italy 1958, '61 Healey BT7, pre-A Porsche 356, and a Porsche 944.
  9. #29
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,973
    Thanks Thanks Given
    5
    51
    Thanked in
    I've had a couple cars with manual transmissions whose owner's manuals admonished drivers to be sure to push the clutch pedal all the way to the floor when shifting. I assumed this was to prevent grinding of gears and/or slipping the clutch but, presumably, the fluid volumes and piston volumes were carefully calibrated by the engineers.
  10. #30
    Join Date
    Nov 2011
    Location
    Martinsville NJ
    Posts
    492
    Thanks Thanks Given
    2
    Thanked in
    As far as even heights for the pedals, I have always added an extension to the clutch pedal, since it must travel more than the brake ( hopefully ). For a shorter person, this can be more comfortable. There even was a commercially made, one piece, aluminum pedal assembly to replace the original. It had a grooved, cross-hatch surface for grip instead of taking a rubber pedal pad. It was probably left on a car that got sold.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
