Filling Steering Gearbox with Castrol Hypoy Process
stever
I am getting ready to fill my steering gearbox with Castrol Hypoy grease as specified in the manual. My car is a BJ8. The gearbox is in the car and the filler hole is hard to get at and is small in diameter. What is the best way to fill the gearbox?
Thanks in advance!
steveg
You can get a syringe or suction gun (Amazon) with a hose which will reach the bottom of the box.
Turn the steering wheel to left lock; this will allow your tube to reach the bottom of the box. Fill from bottom up until it overflows. Withdrawing tube, operate the steering side to side a couple of times to remove any air pockets.
With a large syringe, you can pull the piston out and pour the oil into the syringe, then push it in with the piston.
Warming the oil in the sun or a bucket of hot water helps thin it.
If you haven't yet bought the Hypoy there are "00" greases such as Stens, which would be less likely to leak. Lots of discussion in the archives here about John Deere Corn Head gun grease.
vette
Yes use the process Steve has suggested but I bought my syringe at a local kitchen accessory store. I use a 00 grease or equivalent and the syringe just sucks it out of the bottle then inject it into the steering box.
RAC68
Hi All,
More then a year ago, when we first discussed replacement for the leaking steering fluid, I purchased (2) tubes of John Deere Corn Head grease thinking my steering box was leaking. When ready to install the grease, I found the steering box to be full of fluid, leaving me in the dark as to the origin of the film of oil on the bottom of the box. Needless to say, I replaced the cap and put the tubes of grease back on the shelf. However, in an examination last week, I noticed oil on the bottom of my steering box and I am guessing the time to go for the John Deere Corn Head grease in fast approaching.
As I remember, the John Deere grease is in tubes, similar to those for chassis grease, and it may be possible clean out my grease gun and use it to inject the John Deere grease into the steering box. Has any tried this approach? Also, since I am under the impression the John Deere is compatible with steering box fluid and it might be possible to extract most of the fluid with the remaining being displaced by the injection of its grease replacement. Has anyone tried this?
Ray(64BJ8P1)
Healey Nut
Ray your way way way overthinking this .
Crack the lower two bolts on the steering box and let it drain over a few days .
Put the tube of corn head grease in the gun , remove the grease nipple coupling bit .
Now pump away into the box until shes full , let it settle by cranking the steering and waiting . Remember corn head grease is a semi solid it will settle and level on its own in a reasonable temperature given time .
Top it up till shes full .
Drive and enjoy .
steveg
I like this for injecting Corn Head Grease from the bottom up inside the box:
RAC68
Hi All,
Healey Nut, you are very astute. Overthinking is not a new practice for me and usually expose issues, often with the participation of the Forum, by the time I address the task.
Steve, thank you. I have a similar terminal at the end of one of my grease guns that I had planned to use.
I am also wondering if anyone has filled the idler with Corn Head Grease as well as the steering box?
Ray(64BJ8P1)
RDKeysor
My '60 BN7 dumped its steering box contents overnight several years ago. I read up on the issue, bought a tube of the Deere Corn Head grease, unscrewed and removed the coupling on my grease gun and pumped virtually the entire tube in the box. I didn't know enough to lift the front end and turn the steering wheel back and forth to insure that the box was full, but I kept my eye on the box and added a bit after some driving. I didn't attempt to evacuate the remaining original oil from the box, so I had a little residue leaking out over time. I'm also interested in the idler question posed by Ray. The content of mine seems stable and I have left it as found. Also, I recently adjusted the steering box on my car via the adjustment atop the box (with a Whitworth wrench and a screw driver). After I broke the nut free I probably tightened the screw less than a quarter turn. Upon driving it the steering felt a little heaver. I then lifted the front end and swung the steering back and forth, finally returning the set screw to the original setting. My goal was to attempt to remove just a bit of highway wander on my car. Unfortunately, I wasn't able to really feel whether the adjustment tried initially improved the steering feel with the wheel lifted off the garage floor, and I didn't like the little extra drag I thought I felt after the very slight turning of that screw. Anyone else with experience with this adjustment?
T filling/flushing steering rack Spridgets 7
CCURTISS TR2/3/3A Filling TR3 Steering Box Triumph 10
Obtong Filling Steering Rack/Boots MG 6
D Filling Holes Austin Healey 21
steveg TR6 Cooling system filling Triumph 7
maxwedge5281 sxplash or overflow when filling healey gas tank Austin Healey 6
T Filling an Armstrong Lever Arm Shock Spridgets 0
T Filling for an Armstrong shock Spridgets 1
Gearhead_Garage Fuel backup while filling Austin Healey 24
D Location of gearbox/transmission filling area Spridgets 12
N Filling holes??? Spridgets 16
H TR6 Filling up the TR6, overflow? Triumph 6
T Revised fuel tank filling strategy - re ethonal Triumph 5
TRMark TR4/4A Shorten the radiator filling neck on a TR4? Triumph 7
T over-filling the gas tank Austin Healey 30
R Filling overdrive oil on BJ-7 Austin Healey 5
BOBBYR Filling my O/D transmission Austin Healey 8
B Filling SU Dampers? Spridgets 20
A Filling Coolant Spridgets 6
G Checking & filling shock absorber fluid Spridgets 9
Johnny Filling differential Austin Healey 4
DerekJ Gearbox oil level and over-filling Austin Healey 11
L Filling shocks MG 16
T Filling rear Bugeye shocks - any tips? Spridgets 7
G Filling a completely dry cooling system.... Triumph 13
M Filling up with Gas MG 11
R question on filling rear shock....[armstrong] MG 3
K Filling a grease gun Restoration & Tools 9
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T TR6 Steering Wheel Lock Triumph 2
D Removing the steering wheel hub Spridgets 12
J MGB 1970 MGB Steering Lubrication MG 1
C Steering Arm Castle Nut Torque Austin Healey 5
PAUL161 T-Series TF Steering Rack MG 0
G Steering Disconnected Austin Healey 2
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
K 1968 Midget Steering wheel Spridgets 1
olarson TR2/3/3A Steering Column Bracket Triumph 2
Guido36 Electric Power Steering Austin Healey 2
Rut MGB 62-67 upper MGB steering shaft MG 3
Editor_Reid Wrapped Steering Wheel Austin Healey 9
E TR6 Strange Steering Rack Cap Triumph 3
B TR4/4A Steering Wheel Hub Issues Triumph 0
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
S TR6 Steering question you will not hear every day Triumph 1
T "Flashpower" Steering Wheels Austin Healey 3
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
S SOLD!! Mike Lempert 15" slotted Derrington Steering Wheel Austin Healey Classifieds 1
M Midget steering column Spridgets 3
