TR6 Starting
sundown
Hi I need some help trouble shooting a starting problem. The car was running fine. Now it turns over but will not start. It is getting gas to the carbs. How can I check if it's getting spark. Thanks
dklawson
You said you have gas to the carbs but it may not be getting into the carbs.
Your first test should be to spray a shot of starting fluid into each carb throat and try again to start the engine. If the engine fires, runs very briefly, then stops... you have a fuel problem. If the engine does not fire on starter fluid there may be an ignition problem.
TR3driver
Great Pumpkin - R.I.P
One test for spark is to remove one spark plug, put the wire back on it, then lay or hold it against the cylinder head so the metal shell is touching the metal of the engine. Then get someone else to crank the engine while you watch the plug gap for spark.
Not a 100% test, but a good start. If you don't have a helper available, rig up a remote starter switch so you can crank the engine from under the hood. They're pretty simple, I built my own back in high school; but also not too expensive to buy even if you only need it once.
https://www.harborfreight.com/12-volt-remote-starter-switch-35448.html
https://www.ebay.com/itm/12V-Push-B...925630&hash=item4432534cd9:g:lAQAAOSwjwZcLsUd
TR3driver
Don't hold the wire at all; hold the metal shell of the spark plug firmly against the engine head or block and you won't get shocked.
poolboy
You said "The car was running fine". What did you do between then and now ?
sundown
sundown
It was running fine last fall but started to smoke like crazy,. I removed the head and had it rebuilt. The valve guides were shot about .015-.020 slop. Then I decided to replace the rings and connecting rod bearing while the head was being rebuilt. What I'm getting at is I never disturbed the carb settings or points. I put new plugs in and now it just keeps cranking. THANKS
poolboy
Assuming the carbs weren't flooding or dripping fuel when you tried starting the engine go ahead and do the 'starting fluid' thing and let us know what happens. The next step in trouble shooting depends on those results.
poolboy
With our carbs you'll need to lift the air valve a bit when you spray so that the starting fluid gets to where it needs to.
sundown
sundown
Hi I just went out and tried the starting fluid.i did lift the air valve and sprayed. It did not even cough like it wanted to start?
dklawson
You took the head off and put it back on? Did you remember to adjust the valves. On pushrod engines the valve lash has to be set after a new head gasket is installed because not all head gaskets will have the same installed thickness.
poolboy
Now see if you have spark...Put a spark plug, ANY spark plug from ANY type engine will do, (including one for the TR6 engine) into one of your engine's spark plug wires as previously described and see if you have spark.
No need for new points as long as they are still gaped at about .015"
If you don't have spark, you'll have to troubleshoot a bit more to find out why...but first see if you have it or not.
sundown
sundown
Ok Poolboy, I am going to try that I'll definitely get back with the findings. Thanks for helping me trying to figure this out.
trrdster2000
Have a look at the condenser and wire from the coil to make sure they are under the plastic sleeve and not on top of the stud.
dklawson
You can also test the low-tension side of the ignition system.
Make up a test light. Connect one if its leads to coil (+), the other to coil (-). Crank the engine. The test lamp should flash on and off if the low-tension side of the ignition system is working.
H Advice asked on Healey not starting Austin Healey 1
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 13
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
S TR2/3/3A TR3 Hard Starting Triumph 4
H MGB Starting Problems MG 3
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
T TR6 Continuous Starting and Ignition Issues Triumph 6
M TR6 Just starting out… Triumph 16
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
P Wedge Starting problems TR8 Triumph 3
K TR6 tr6 not starting Triumph 11
Jim_Stevens TR2/3/3A Intermittent starting Triumph 14
R TR2/3/3A Starting car for 1st time after rebuild. Triumph 13
F TR2/3/3A starting scuttle repair Triumph 27
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
R TR2/3/3A Starting TR-2 for first time after restoration Triumph 58
D Wanted TR3A starting handle Triumph Classifieds 0
D Starting After Carbs Rebuilt Austin Healey 30
Got_All_4 TR6 Starting my frame restoration Triumph 32
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
F TR2/3/3A 1960 TR3A starting chassis work Triumph 81
J TR2/3/3A Starting my TR3 A restoration Triumph 8
F TR2/3/3A Starting Triumph 4
N Hesitant starting Austin Healey 16
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G TR4/4A Starting without Transmission attached Triumph 9
P BN4 Hesitates on Starting Austin Healey 12
D Hard Starting Austin Healey 14
mgedit TR2/3/3A 56 TR3 Starting Issue Triumph 9
M Starting from cold Austin Healey 2
R Very Difficult cold weather starting problems! Austin Healey 21
R TR4/4A Starting TR4A after 30 years Triumph 12
R winter hard starting BJ7 Austin Healey 16
P Jump starting a positive ground BJ8 Austin Healey 4
W starting motor Jaguar 0
D TR2/3/3A Starting my Bodywork journey. Triumph 166
P TR6 Quick starting Triumph 2
Joe Reed General Tech Starting a screw in a tight location... MG 9
P TR6 TR6 hard starting Triumph 24
Q Just Starting Restoration Of 1967 E Type Jaguar OTS Jaguar 13
stretchit2 Starting Issue Austin Healey 6
M TR6 Intermittant starting problems Triumph 4
Willie_P TR4/4A Starting long dormant TR engine..start up procedures? Triumph 10
S Hard starting on Webers from cold Austin Healey 12
T TR4/4A Weird starting issue with my TR-4 Triumph 15
