Front shocks
nicko
Hi all,
I recently had my two front shocks rebuilt. They came back good as new, see pics. Unfortunately after a couple of weeks or so it went back to bouncing along the road ! Upon closer inspection it seems like a washer or a seal has come out of both shocks, see middle picture. Also the oil has come out , I assume. My question is
a: Is it easy to repair the shocks? Then refill with oil, if so what oil.
b: Or should I just exchange them for reconditioned ones?
I would prefer to keep the ones I have as they are original to the car.
Any advice would be much appreciated.
Many thanks,
Nicko
nicko
nicko
Hi. Thanks for your replies. The guy who did the shocks did it as a favour, so I can't send it back. The question is could I repair it easily myself or is it a specialist job. See pics of the inside as sent to me at the time of the rebuild
Healey Nut
As the saying goes “pay me now or pay me later”
Do yourself a favour bite the bullet send them to apple hydraulics and get them done right ....the first time .
Rob Glasgow
I also recommend World Wide. I couldn't believe the improvements in ride and handling after having them rebuilt. Drove like a brand new car.
twas_brillig
Depending on your interests (keep it completely original, or 'tasteful' upgrades) and budget, consider Putzke's 'Fahrspass' Bilstein shock conversion. We have them on our BJ7 and - according to the shop I was madly transferring pay chequest to a couple of years back - it road/handled better than any other Healey they'd one. Doug
twas_brillig
Worldwide did some shocks for our Bugeye. Complete satisfaction. Doug
jman15
Nicko, its probably not worth it to send to US for you but as others have noted Worldwide in Madison Wisconsin does a great job. When the rebuild them for you they also replace the seals so they will not leak in the future. They also ask you whether you want your original back and whether you want to keep the original bolts to retain the stocks originality. Had mine done by them and very satisfied. If you are going to go to the trouble of having yours redone locally be sure to ask them the fix the seals as that is the main point of failure. Once completed you can't tell the difference from the originals; they just work a lot better.
nicko
nicko
Thanks for all your help on this subject.In the end I decided to exchange my shocks for a re-conditioned pair at AH spares in the uk. The problem was that the"washers" on the outside of the shocks had come out and needed a press to re-install it which i didn't have .In the end the new shock works as good as new and I have my old car back. Thanks to all Nicko
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J Midget front shocks Spridgets 4
W Best source for Bugeye front shocks Spridgets 3
Z Front Shocks Austin Healey 19
P TR6 New front shocks & air in clutch Triumph 15
A Front Shocks Bushing Replacement Austin Healey 2
P TR6 Front shocks Triumph 11
M Replacing front shocks, torque setting? Spridgets 2
B Front Shocks Austin Healey 6
RJS TR4/4A Replacement Front Shocks Triumph 4
D front shocks 100 m Austin Healey 12
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
AUSMHLY BJ8 replacement front Lever Shocks keeps leaking Austin Healey 40
S Spitfire Question front shocks and springs for 73 spitfire Triumph 5
N Hillman Imp front shocks wanted Other British Cars 2
tomshobby front shocks, about time I think. Triumph 6
J Front shocks Austin Healey 5
PAUL161 T-Series TF Front Shocks-[Backwards]? MG 5
J Replacing front shocks. Austin Healey 3
AUSMHLY Front shocks: guaranteed not to leak ? Austin Healey 6
R Bugeye front shocks Spridgets 3
mrsprite front lever shocks for sale Spridgets 2
BOBBYR BJ8 FRONT SHOCKS Austin Healey 10
bighealeysource Removing front shocks on a 100 -4 Austin Healey 12
S BJ8 Shocks and Front End Austin Healey 15
19_again front shocks filler location MG 4
Shinsen774 Install Front Lever Shocks-What's the secret? MG 3
F TR2/3/3A TR3A front shocks Triumph 2
bluemiata90 TR6 TR-6 front shocks in a TR3?? Triumph 2
B front shocks MG 33
zimmy changing front lever arm shocks Spridgets 4
Morris New Front Shocks! Spridgets 2
kodanja TR6 TR6 FRONT SHOCKS? Triumph 24
D Front Shocks. Spridgets 19
mrv8q TR2/3/3A TR3 Front shocks Triumph 4
jscott TR2/3/3A TR3A front shocks Triumph 1
M Front shocks MG 8
M Front shocks MG 4
Basil Front shocks installed tonight! Jaguar 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
