New Model A project
Bayless
One of my shop partners has a '29 Model A Tudor that was a show car until it got caught in a garage fire. The car didn't actually burn but the extreme heat did it no good. I has finally decided to restore it again and I will be helping him. Here are a couple of photos. The first is everything except the chassis loaded in my trailer and headed for the sand blaster to remove all the burnt paint and rust. The second is a couple of weeks later after many hours of sanding, a few hours of straightening, some more time welding and finally with two coats of epoxy primer on everything except the body and doors. It currently occupies our makeshift paint booth which is also where my Sprite lives. So the Sprite has been on hold until we can get everything primed for rust protection.
Deleted member 8987
I had a 29 Tudor. Twin side mounts. Tan body, black fenders, yellow wheels. Mechanical brakes. All done (with "trunk") except upholstery.
"Massacree" is what we named it. Date code stamped in the firewall was Valentine's Day, 1929.
Fun old car.
Everybody needs to do a Model A at some point.
I even hand propped it once to say I did it.
Bayless
Bayless
I'm slow getting back but yours must have been the deluxe model. This one is the cheaper Tudor with the spare mounted on the rear instead of the side mount and no trunk. It was an October build. We finally have everything sand blasted, sanded and in epoxy primer. Well, everything but the wheels. Still trying to decide whether to powder coat them. One of these photos shows the body in primer. The other shows how we got to the bottom for sanding and primer. A should add, my paint supplier suggested Southern Polyurethanes epoxy primer as they cater more to restoration shops than production shops. I'm glad he did. This stuff is great to use. It is 1:1 mix and required no thinning with my 2.0 gun tip. Unlike most epoxy, it allows for top coating without additional sanding within 7 days. I was a little concerned about temperature in the high 80s for the first application. I texted their tech line about maximum temp and humidity. Within 10 minutes I got this answer back: "No maximums. 100 degrees and raining is fine." I love it.
JPSmit
looks great!
waltesefalcon
Bayless, nice work. I should drive up sometime and look over your shoulder.
Bayless
Bayless
Thanks Walt but I don't recommend myself as instructor. I'm not really a slow body man but I'm certainly not a fast body man either. I guess I would be classified as a half-fast body man.:wink-new:
On another note though, I got primer on all the trim pieces and a couple of others we missed earlier. Everything is now in primer and no longer susceptible to rust so maybe I can take a little time to work on my Sprite or Prefect for a while.
Bayless
Bayless
Made a little more progress. All the major (really not that bad) body work done, including bondo as necessary, and everything is now in epoxy primer. Last pieces were the doors and the hood parts. So, yesterday was my first experience with polyester primer. I put 2 or 3 coats of Slick Sand on those parts as they were still in the paint booth area. Today we will start sanding and find out how good (or bad) our prior work was. Based on how much paint those few parts took, I don't think a gallon will be enough for the car.
SaxMan
I bumped into a beautiful Model A Cabriolet when taking Baby Blue out for some gas. The guy at the register came out to see both cars, and all the other folks filling gas came over to check the cars out. It was like a mini-car show.
JPSmit
nice though a somewhat unfortunate description :smile:
Bayless
Bayless
Well I had a disappointment today. The first experience with Slick Sand was great. It shot nice and sanded easily. Easy with a long board to get everything flat. I decided at the last minute yesterday to do the next batch. This morning it is still too soft to sand. I'm sure I put the right amount of hardener so my best guess so far is that I let it get too cool too soon. I left the heat on for tonight but if it's not hard by tomorrow it looks like I will have to find a way to take it all off. Fortunately I do have a solid epoxy base under it.
JPSmit
I know it is supposed to be science and others say it is easy, but I swear it is all magic and voodoo and the phase of the moon getting those mixtures right.
waltesefalcon
With the weather we have been having it is not entirely surprising that you got different results. With this cold and wet weather I'd definitely leave the heat on it all night after shooting.
Bayless
Bayless
You're probably right Walt. And thanks JP. After reading your last comment and choking down my second cup of coffee, it suddenly hit me. It was not the temperature. I have used a little more than a quart so far and there are 4 tubes of hardener for the gallon. Each tube mixes into a quart and I still have about a fourth of the first tube left. I remember very carefully calculating how much hardener for that last batch then just as carefully adding a little less than half what I should have.
Today we took most of it off with lacquer thinner and a lot of scrubbing. Fortunately I did have a solid base of epoxy primer under it that the thinner didn't hurt. I am now back to where I was last Friday. Oh well, another lesson learned. The hard way, of course. I think it was Mark Twain said "Some people learn just by reading. A few more by watching. The rest of us have to pee on the electric fence ourselves."
JPSmit
Glad you figured it out (I hate it when it's obvious :whistle: AND Twain also had Tom Sawyer get someone else to do the painting - just sayin' :grin:
Bayless
Bayless
Dang, it looks like that's what my shop partner (the car owner) did to me.
waltesefalcon
Happy you figured it out. Good luck with it moving forward.
Bayless
Bayless
Better luck today. It finally got warm enough outside that our shop heater could get everything up to 75 degrees and hold it there. I mixed up another batch with the right amount of hardener this time and re-shot the pieces. It actually got hard this time. Sometimes it just pays to think about what you are about to do even when it is a last minute decision.
waltesefalcon
Good to hear.
Bayless
Bayless
Latest project was getting the engine on the stand instead of the hoist.Dick found, cut up and drilled this monster piece of angle iron and I welded it together. Now I'm not really a welder so I was a little concerned about it. We left it still attached to the hoist with the chain slack overnight just in case. His reason for mounting it this way is so the gearbox can be mounted to it.
Bayless
Bayless
Since the last post, we have hand-lapped and adjusted the valves, replaced all the gaskets, painted and reassembled the engine the engine. Ford painted the engine before assembly so judges don't want to see any engine paint on any of the gaskets. All the body parts are now in primer and ready for final painting. The main body is and exception and a slight disappointment though. I shot 4 coats of Slick Sand, which should be about 12 - 15 mils, then a guide coat and started block sanding only to find that the body work was not as good as I thought. There were a few low spots on those slab sides that wouldn't quite sand out. It looks like some glazing putty and another coat of Polyester will be required. I'll get photos later. The next thing the is the chassis. It is in pretty good shape, just needing a paint touch up coat. Meanwhile we are still waiting and hoping to get single stage paint for it. Here is the engine ready to reinstall but waiting for the frame to be painted.
PAUL161 Photo: What Model of Healey? Austin Healey 7
Boink 3D Sprite Model Spridgets 3
V MGB Replace late intake manifold angled breather with early model straight? MG 1
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
D Sprite Model Identification Austin Healey 2
Bayless Model A Update Other Cars 8
B BE vs. Later Model Gas tanks Spridgets 2
E Alpine radio for a US Model Db7 Volante Other British Classifieds 0
N TR6 Triumph Diff which model??? Triumph 1
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
L Healey model and year Austin Healey 22
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
aero3113 1/5 Model of a 100S Austin Healey 2
Boink 1924 Bentley 3 liter "Speed" model Other British Cars 12
Tim Tucker TR4/4A BENDIX Radio Model: 5SMTR manual? Triumph 2
TomMull Wanted Triumph 10 any model, condition 3 at least Triumph Classifieds 8
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
55modified Model year based upon 11/18/54 manufacturer date? Austin Healey 13
J Morris Model 8 1939 Other British Cars 1
L Tinplate Austin Healey 100 model Austin Healey 3
Scotsman GT6 GT6 early vs later model differences / upgrades Triumph 13
eschneider Any late-model Mercedes owners willing to review new brake pads/ rotors? Other Cars 4
B BN2 First right hand drive model car number 16 Austin Healey 4
Basil 1931? Model A Coupe Spotted 11
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
P T-Series Model TD MG 2
aeronca65t Model A Christmas Other Cars 2
DanLewis Rear brake backing plate differences: Bugeye vs. later model MG Midget Spridgets 12
B TR6 Is the "separation tank" in late model TR6's necessary? Triumph 5
G Late model head light circuit Spridgets 3
B Spitfire How do you replace U Joint on late model Spitfire OD Prop/Drive shaft? Triumph 7
DNK Model ? Spotted 3
Brinkerhoff Front fender RH BN2 model needed Austin Healey 2
aeronca65t Olsmobile + Model A Spotted 3
PatGalvin TR2/3/3A Late model TR3 Fuel Tank Straps available to a nice home Triumph 0
Nunyas Tesla Model S Other Cars 5
Boink Nifty Sprite Model for sale on eBay... Spridgets 4
T MG Midget 1:18 diecast model Spridgets 1
bcliff Ford Model Y English for sale Other British Cars 1
Mickey Richaud Model Builders Out There MG 2
JPSmit Model A Spotted 0
D MG's and The Model Garage MG 1
regularman Year model confusion Spridgets 2
D Model "A" Ford Coupe Spotted 3
ekamm TR2/3/3A TRF Tr3 model feature Triumph 1
middie Late model dashboard Spridgets 3
hondo402000 TR6 hazard flasher unit for 69 70 71 TR6 model Triumph 22
AngliaGT DM - Lotus Elan S2 Plastic Model Lotus 1
