Results 1 to 9 of 9
Thread: Oil Catch Can TR3a
Discussions of Triumph motor cars
  1. #1
    Join Date
    Jul 2016
    Location
    Rochester,NY
    Posts
    7
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Oil Catch Can TR3a
    Hey anyone have any tips on installing an oil catch can on the breather tube for a TR 3a? ChefJim
  2. #2
    Join Date
    Mar 2002
    Location
    Sacramento, CA
    Posts
    1,809
    Thanks Thanks Given
    1
    Thanked in
    Re: Oil Catch Can TR3a
    I put one on my TR3. I restricted the intake off the manifold to about 1/4 inch. Otherwise it was pulling too much air from the valve cover and that included lots of oil. This installation did eliminate the smoke coming out the exhaust when starting in first gear.
    Jerry
  3. #3
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,233
    Thanks Thanks Given
    27
    Thanked in
    I do not have any actual experience with modifying the breather pipe; I let the breather pipe do what it does. A while back someone mentioned something about the breather pipe and its function. I was surprised that the breather pipe was so highly engineered and shorting the pipe or modifying the pipe could be a problem with air flow and engine breathing. When I was in high school, most the cars had a breather pipe and the cars were called ---open crank case ventilation cars.
    I see what you mean about trying to catch the drip the pipe makes. I bought a non- running tr3 years and the pipe was cut short. I do not know the effects of that, but I would think if someone tried to catch the drip and the system plugged the outcome would not be good.
  4. #4
    Jedi Trainee Andy Blackley's Avatar
    Join Date
    Aug 2003
    Location
    Chardon, Ohio
    Posts
    311
    Thanks Thanks Given
    Thanked in
    There is a recent discussion thread on this topic on the TR Register TR4 forum: https://www.tr-register.co.uk/forums...-like-a-sieve/
    Some TR4 owners prefer the old draft tube, others the TR4A PCV setup. Either way you need a vacuum source to pull the fumes from the crank case and provision to let air into the engine. On the stock TR3 the draft tube pulls the vacuum from the venturi effect under the car while moving down the road. Make-up air in drawn into the engine through the wire gauze inside the oil filler cap. Later TRs use manifold vacuum.
    Racetorations in the UK has a setup for racing TR3s as I believe you must have a catch can for track use: http://www.racetorations.co.uk/trium...ather-kit-p143
    Andy Blackley
    1967 TR4A CT77156L
    2015 Mini Cooper S
    Fear God and Dreadnought
  5. #5
    Join Date
    Jul 2016
    Location
    Rochester,NY
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Jerry View Post
    Jerry
    Thanks for the insight. Think I'll live with my car making"deposits" for awhile more while I research. ChefJim
  6. #6
    Join Date
    Jul 2016
    Location
    Rochester,NY
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Thanks Jedi. Not sure what to do but it drives great anyway. ChefJim
  7. #7
    Join Date
    Jul 2016
    Location
    Rochester,NY
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Jerry
    Thanks. Still getting used to the ins and outs of the car. ChefJim
  8. #8
    Jedi Trainee BillyB62's Avatar
    Join Date
    Oct 2011
    Location
    Moosup, CT
    Posts
    359
    Thanks Thanks Given
    Thanked in
    ChefJim,
    They mark their territory!!!
    Bill
    '59 Triumph TR3A TS63273L
  9. #9
    Join Date
    Jul 2016
    Location
    Rochester,NY
    Posts
    7
    Thanks Thanks Given
    Thanked in
    Yes they do.
    '59 Triumph TR3a TS59989L
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
