Results 1 to 12 of 12
Thread: Positive Ground to Negative Ground Power Inverter
  1. #1
    Join Date
    Jul 2002
    Location
    Tucson, AZ
    Posts
    351
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I have decided to install a Retrosound radio in my BJ8. However, the radio requires a 10 AMP minimum power supply. My power inverter changing positive ground to negative ground power only provides 3 AMPs. I searched on the internet but have not been able to find a power inverter converting positive 12V to negative ground 12V power. Do any of you know where I can find one of these inverters?
    Stever
  2. #2
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,917
    Thanks Thanks Given
    16
    49
    Thanked in
    Re: Positive Ground to Negative Ground Power Inverter
    Unless you're doing concours, why not just convert to negative ground? Easy enough to do and no one will ever know unless you look at the battery.
    Rick
  3. #3
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,646
    Thanks Thanks Given
    9
    Thanked in
    a
    Well I second Ricks comment, additionaly the converter will add additional problems.
    Yes I know Where U can find one but I do not remember where in my shop I put the cotton picken thing
    U guys down there close to the MTN gonna be warm today----
    NEG GND GO for it OK
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  4. #4
    Join Date
    Jul 2002
    Location
    Tucson, AZ
    Posts
    351
    Thanks Thanks Given
    Thanked in
    I installed a Petronix ignition years ago. I seem to recall the Petronix is for positive ground and if I convert to negative ground I would have to change out the Petronix ignition. Do you know if that is true?
    Stever
  5. #5
    Jedi Warrior red57's Avatar
    Join Date
    Apr 2008
    Location
    Washington, USA
    Posts
    553
    Thanks Thanks Given
    8
    19
    Thanked in
    Yes, you would have to change the Pertronics but that would be simpler (and probably cheaper) than going the inverter route.
    However, as Rick & Keoke said, if you are going concours the inverter may well be the way to go.
    Dave
  6. #6
    Join Date
    Jul 2002
    Location
    Tucson, AZ
    Posts
    351
    Thanks Thanks Given
    Thanked in
    I am definitely not concours oriented. However, for whatever reason I have found the conversion to negative ground to be "scary".
    Stever
  7. #7
    Join Date
    Sep 2018
    Location
    St. Johns Florida
    Posts
    20
    Thanks Thanks Given
    7
    Thanked in
    I would be a lot more nervous with a 10 amp DC voltage inverter which is actually may be a voltage doubler creating 24 volts positive to float above the 12 volts positive chassis ground. This device used to be used in the early CB radio days so as to be able to "ground" the antenna to the radio frame and chassis. It created a 12 volt DC differential between the radio input and the radio frame. Radio Shack sold it under the Archer brand I recall. Converting to negative ground is very easy and works well. You will need to change the Pertronix and convert the electronic tachometer to negative ground operation. Lots of good articles written on this subject.
    Bill Young
    sjahc.com
  8. #8
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,917
    Thanks Thanks Given
    16
    49
    Thanked in
    Here's a negative ground conversion article. Note the tachometer wiring change needed for a BJ8: https://www.carolinasahc.com/Tech%20...iveGround.html
    Rick
  9. #9
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,646
    Thanks Thanks Given
    9
    Thanked in
    Quote Originally Posted by stever View Post
    Yes that is true:
    However, the negative ground version of the pertronix which has been available for some time is again a simpler installation compared to the negative ground item model,
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  10. #10
    Join Date
    Jul 2002
    Location
    Tucson, AZ
    Posts
    351
    Thanks Thanks Given
    Thanked in
    I just remembered I am in the process of installing a new positive ground electronic fuel pump, too,,,......ugh. What I would really like to do is install an original radio to the car. I never listen to the radio, anyway, just the exhaust! But, a new style radio in the dash just doesn't look right to me. Anyone have a working "original style" positive ground radio?
    Stever
  11. #11
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,646
    Thanks Thanks Given
    9
    Thanked in
    Just a note: stever
    An original style radio may include a switch that makes it compatible with either positive or negative ground systems.
    1985 XJ6 Saloon
    1973 Volvo P1800ES
  12. #12
    Join Date
    Mar 2009
    Location
    ky
    Posts
    153
    Thanks Thanks Given
    2
    Thanked in
    You won't be happy with the Retrosound anyway. At least I'm not. Doesn't pick up stations very well.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
