Results 1 to 11 of 11
Thread: Grinding when shifting into first
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Apr 2017
    Location
    Morgantown, WV
    Posts
    162
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    1960 Bugeye, 1275, 4 speed.... "Otto". I had a rear axle sheer off as a result of a diff. failure. It's all back together and runs fine..... however, something new started happening. Sitting still and shifting in first gear at a light, there is a grinding, as I shift. After that it all shifts fine. Shifting into reverse is fine... no grind. I've read a few posts that this is fairly normal and proper procedure is to shift first into second to stop the gears and then quickly shift into first. I have not tried this yet...
    Does it make sense that I've never had to do this before and just now find it necessary? Is there likely another problem lurking, or can I just not worry about this if the 2nd to 1st shift works?
    Thanks!
    Mike
  2. #2
    Yoda Jim_Gruber's Avatar
    Join Date
    Dec 2006
    Location
    Apollo Beach, FL
    Posts
    5,443
    Blog Entries
    2
    Thanks Thanks Given
    3
    Thanked in
    Re: Grinding when shifting into first
    Just do it. Shift into second and then you will find when sitting still it will just slide easily into First Gear. What oil are you using in the tranny. Recommended is 30W Non Detergent oil and others use 20W/50W same as the engine.
    Jim Gruber - Apollo Beach, FL
    Bugsy I - '68 Sprite w BE Bonnet - Gone but not forgotten
    Bugsy IV - '60 Bugeye - 1,275+.040 and a 5-Speed - CA Car - 2nd Owner from new - 10/12 Painting done, reassembly, cutting, and buffing in progress.
  3. #3
    Join Date
    Apr 2017
    Location
    Morgantown, WV
    Posts
    162
    Thanks Thanks Given
    Thanked in
    Well... here's a fun thing. I've never even looked at the oil in the tranny, let alone changed it. Could be low for all I know.... better check on that. If I don't know what's in it, or how long it's been there, I'm guessing I should do an oil change? Good to know the grind is normal.... after checking the oil level, I'll try the second-into-first method and see if that works.
    Thanks!
  4. #4
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    342
    Thanks Thanks Given
    7
    Thanked in
    Not normal at all. At Idle and not moving you should go into first easily. Never have done the second gear thing.
    Yes, check trans oil but it is difficult to do. Best just drain and replace. Straight 30 weight or Redline trans oil (much more expensive )
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  5. #5
    Join Date
    Apr 2017
    Location
    Morgantown, WV
    Posts
    162
    Thanks Thanks Given
    Thanked in
    You know, I had the same feeling about it being 'normal'. Although, even 'Bugeye Guy' has a video explaining how to shift into second prior to first. But... my car hadn't required that at all before the diff and axle failure.
    I'll check / change the oil, but we're traveling this week... likely will be a couple weeks before I can get the job done.... If I get a chance to take him out this week, I'll test the second into first method.
    Thanks!
    Mike
  6. #6
    Join Date
    Feb 2019
    Location
    Bellefonte, PA
    Posts
    31
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Clutch drag could cause that problem.
  7. #7
    Join Date
    Aug 2013
    Location
    Damascus, MD
    Posts
    2,025
    Thanks Thanks Given
    2
    10
    Thanked in
    For the 2 1/2 quarts that the tranny takes, you might as well just change the oil. Refilling is a bit of a pain. A funnel with a flexible hose makes life a bit easier. I put a little bit of Seafoam into the tranny when I changed out the oil. It may be completely psychosomatic, but it sure feels like the transmission is shifting smoother.
  8. #8
    Join Date
    Mar 2018
    Location
    NSW, Australia
    Posts
    7
    Thanks Thanks Given
    Thanked in
    I believe you can fill with less mess by removing the shifter and filling through the shifter hole.
  9. #9
    Great Pumpkin JPSmit's Avatar
    Join Date
    Nov 2004
    Location
    Toronto, ON
    Posts
    18,461
    Thanks Thanks Given
    51
    Thanked in
    John-Peter Smit
    1976 MG Midget
    1969 Vauxhall Viva GT
    1958 Fiat Multipla (Barn art)
  10. #10
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    342
    Thanks Thanks Given
    7
    Thanked in
    2 1/2 Pints. Just a little over a quart. Been adding a straight US Quart to trans since forever with no issues.
    Joe Schlosser
  11. #11
    Great Pumpkin NutmegCT's Avatar
    Join Date
    Jul 2004
    Location
    Connecticut USA
    Posts
    11,039
    Blog Entries
    1
    Thanks Thanks Given
    43
    98
    Thanked in
    Quote Originally Posted by Stan Kowznofski View Post
    Bingo!
    If you're stopped, clutch disengaged, and the engine is idling, the gears shouldn't be turning.
    Mac & Phyllis Take a Trip: http://nutmegflyer.com/trip-details-daily-updates/
    History: 1976 MGB, 1959 Triumph TR3A, 1960 Mercedes-Benz 190b, 1958 Rambler American.
    Current: 1953 MG TD27318.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
