Grinding when shifting into first
mikeamondo
1960 Bugeye, 1275, 4 speed.... "Otto". I had a rear axle sheer off as a result of a diff. failure. It's all back together and runs fine..... however, something new started happening. Sitting still and shifting in first gear at a light, there is a grinding, as I shift. After that it all shifts fine. Shifting into reverse is fine... no grind. I've read a few posts that this is fairly normal and proper procedure is to shift first into second to stop the gears and then quickly shift into first. I have not tried this yet...
Does it make sense that I've never had to do this before and just now find it necessary? Is there likely another problem lurking, or can I just not worry about this if the 2nd to 1st shift works?
Thanks!
Mike
Jim_Gruber
Just do it. Shift into second and then you will find when sitting still it will just slide easily into First Gear. What oil are you using in the tranny. Recommended is 30W Non Detergent oil and others use 20W/50W same as the engine.
M
mikeamondo
Well... here's a fun thing. I've never even looked at the oil in the tranny, let alone changed it. Could be low for all I know.... better check on that. If I don't know what's in it, or how long it's been there, I'm guessing I should do an oil change? Good to know the grind is normal.... after checking the oil level, I'll try the second-into-first method and see if that works.
Thanks!
Joe Schlosser
Not normal at all. At Idle and not moving you should go into first easily. Never have done the second gear thing.
Yes, check trans oil but it is difficult to do. Best just drain and replace. Straight 30 weight or Redline trans oil (much more expensive )
M
mikeamondo
You know, I had the same feeling about it being 'normal'. Although, even 'Bugeye Guy' has a video explaining how to shift into second prior to first. But... my car hadn't required that at all before the diff and axle failure.
I'll check / change the oil, but we're traveling this week... likely will be a couple weeks before I can get the job done.... If I get a chance to take him out this week, I'll test the second into first method.
Thanks!
Mike
SaxMan
For the 2 1/2 quarts that the tranny takes, you might as well just change the oil. Refilling is a bit of a pain. A funnel with a flexible hose makes life a bit easier. I put a little bit of Seafoam into the tranny when I changed out the oil. It may be completely psychosomatic, but it sure feels like the transmission is shifting smoother.
JPSmit
saw this on another forum
Joe Schlosser
2 1/2 Pints. Just a little over a quart. Been adding a straight US Quart to trans since forever with no issues.
longbridgehealey gears grinding when shifting Spridgets 11
J Clutch and Grinding Gear Austin Healey 12
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
C TR2/3/3A Gears grinding on first startup..... Triumph 14
T TR6 grinding right rear wheel Triumph 22
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
bighealeysource Mysterious grinding [ouch] noise on BN2 Austin Healey 7
J Transmission grinding! Austin Healey 15
Jim_Stevens Grinding wheel removal Triumph 15
zimmy grinding noise.... Spridgets 50
martx-5 Cam Grinding Triumph 4
S Grinding into first Spridgets 20
R Gears are grinding Spridgets 7
NutmegCT Starter grinding noise caused by a broken housing. Triumph 28
NutmegCT starter grinding Triumph 17
D grinding noise on 91 xjs v12 Jaguar 5
K Second gear grinding Triumph 17
S Gear Grinding in my BJ8 Austin Healey 2
K TR6 Extreme difficulty in shifting into Reverse? Triumph 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
AUSMHLY BJ8 Gear Shifting Austin Healey 5
L TR2/3/3A Shifting problems Triumph 4
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
EWD TR6 74 TR6 - Transmission / Shifting gears Triumph 5
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A drilling out shifting tower for a dip stick Triumph 10
1 MGB 1966 MGB hard shifting into 3rd MG 1
Jim_Gruber Clunk in the rear when shifting Spridgets 26
K TR2/3/3A Shifting back from Reverse to First... Triumph 3
pkmh BJ8 Tranny Issue - Slightly hitting gears when shifting Austin Healey 13
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
C Shifting problem? Triumph 15
F Missing pieces- centershift 3000- vague shifting Austin Healey 4
J Difficult Shifting Triumph 8
britndablood Side shift tranny with shifting issues Austin Healey 10
J TR4/4A Hard Shifting TR4 Triumph 2
B Down shifting problems, check my thinking? MG 1
P Shifting a J2 MG 9
stretchit2 Side Shifting Tri Carp Austin Healey 14
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
R difficulty shifting/downshifting-BJ-7 Austin Healey 7
jaegzie Close Tranny shifting pattern Spridgets 0
R 1500 gearbox, trouble shifting into first from neu Spridgets 20
thechileman TR4/4A TR4 Shifting problem Triumph 3
R trouble shifting, getting into gear &stuck in gear Spridgets 22
I TR6 tr6 shifting problems Triumph 12
eschneider T-Series Clutch - shifting problems - help? MG 19
Bruce_B Shifting Triumph 3
