TR5/TR250 TR250 question [Not asking for a friend]
KarlHB
I hold my hands up and confess my mistake; long story including bad weather, bad temper and little time cut short; I managed to put my new battery the wrong way round, fixed the negative pole to the positive cable, laid the negative cable on the positive pole, went to get a spanner and came back just a few seconds later noticing smoke coming from the alternator. Immediately removed the cable, obviously. Turned the battery around the proper way, cursed a bit, connected it and sat inside the car to try and start it. Noticed smoke inside the car as well. And the car was completely dead.
No lights, no light in the alternator light in the dashboard, but no blown fuses and (hey!) the horn works.
I have replaced the start solenoid and alternator. Is the ignition switch the next thing to suspect? Is there any way of checking this to make sure before I order a new one? Or is there any other culprit part to investigate first?
Alright - I'm ready to take some punches, but also some good advice :smile:
Thanks in advance,
Karl
STeve 1958
I did that 45 years ago and only melted a wire to the ignition. Also check your fusses. In general, reversing the polarity won't hurt much.
Sarastro
Might have fried the ammeter or a connection to it, or one of the wires connected to it. But we can only guess. I think you'll need to get a voltmeter or test light and probe around a bit to find where you are losing power; the source of the problem will then become obvious. I also doubt that there is much damage beyond the alternator and perhaps some wiring. The standard electrical parts, except the alternator, are not polarity-sensitive.
TR3driver
Great Pumpkin - R.I.P
+1 on systematic troubleshooting, rather than replacing the entire electrical system.
Ammeter is most likely IMO, but by no means the only possibility.
K
KarlHB
Thank you, guys - for advice and not telling me off :smile: I have ordered a new ignition switch and hopefully that does the trick. The next thing to obtain might then be an ammeter. The weather is such a mess in Norway at the moment, I wouldn't be taking the car for a spin, anyway (I keep telling myself).
bammons
Don't beat yourself up. I just did the same thing on my tractor even though I looked at the terminals to get it right. Us men and our attention span. Somewhere in moving it into the compartment I got it turned around. I bet you have some beautiful places to drive so I hope you the best.
K
KarlHB
Hello, fellow Triumph enthusiast. Just to keep you posted; I received the new ignition switch, but that didn't solve the issue, either. So, now I have ordered a new ammeter (which will take a loooong time before it reaches me). Good thing autumn is here, with gloomy don't-take-your-TR250-out-for-a-spin-days ;)
CJD
If ammeter doesn’t fix it, then I’d look at the alternator and the wires to it next. Without turning the car on, that’s the main part that actually saw the negative voltage. The ignition switch should have protected everything else..
TR3driver
Power to the lights and ignition doesn't go through the alternator, so it's not likely to be the culprit. You could actually take the alternator off entirely, and the electrical system would work (until the battery ran down).
Sarastro
Well, I just dropped a container with about a gallon of dilute hydrochloric acid on the garage floor this morning, so I'm in no position to criticize anyone...
CJD
And the lights don’t see any current when nothing was switched on. I think it’ll be a wire that fried. The alt is the only thing I can think of that could absorb the reverse current when everything else was turned off...the only item that actually had a “loop” and no fuse.
The ammeter would only blow after reverse polarity if there was excessive current flow. The question becomes, “where was the current able to flow with nothing switched on?” My money is the alternator and it’s associated wiring. All it would take is a bad diode. As I work through it...I guess it could be the voltage regulator...is that integral or separate on the 250?
TR3driver
Reverse voltage guarantees heavy current flow through the main alternator diodes; they form a fairly direct short with reverse voltage applied. Offhand, I can't think of anything else on a stock TR250 that would care, let alone draw too much current because of reverse voltage. Lights, heater, ignition, wipers etc would just go on working (if turned on, which they apparently weren't).
So there's a good chance the alternator is fried as well. My point was just that having the alternator fried would not stop lights and ignition from working.
Could well be a fried wire, but the fault current would also flow through the ammeter (it being between the alternator and battery) and it has smaller diameter wire inside it. Essentially forms a fusible link to the harness wires around it.
On a TR250 (according to several diagrams I checked), the horns get power before the ammeter. So a blown ammeter would disable everything except the horns. Seems like an exact fit to the symptoms described.
mctriumph
Not to beat up on the most obvious question HAVE YOU TURNED IN THE LOSS TO YOUR INS CARRIER?
It is a covered loss.....
Mad dog
K
KarlHB
Mad dog
Thanks for the advice - I might do that, although my excess is $450, and I am still not there yet with my expenses due to my mistake.
sp53
Long shot here, but could have the battery itself internally shorted and broke contact inside causing totally failure.
TR3driver
Batteries can certainly fail in interesting ways, but he said the horns still work. If the battery can supply enough juice to run the horns, I would expect at least something from the lights.
A short inside the battery is very rare, which is good because the likely result would be an explosion.
K
KarlHB
Hi, folks. Thank you for all the input. The reason for the car not starting etc. was the ammeter. I became impatient waiting for a new ammeter, so I disconnected the wires to the meter and joined them. Voilá - except now the wipers are on all the time. I'll try and figure out that one after installing the new ammeter when that arrives - at least I have been able do drive the car again :smile:
H TR5/TR250 TR250 rebuild question Triumph 3
PatGalvin TR5/TR250 TR250 Ignition Key Question Triumph 4
glemon TR5/TR250 Triumph TR250 Trivia, Side Molding Question Triumph 7
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
Got_All_4 TR5/TR250 Annoying turn signal relay question Tr250 Triumph 7
glemon TR6 TR250/TR6 Engine Rebuild Question Triumph 7
glemon TR5/TR250 TR250 Oil Pump Question Triumph 2
Got_All_4 TR5/TR250 TR250 WIPER SWITCH PROBLEMS/ QUESTION Triumph 3
MadRiver TR5/TR250 Silly TR250 Vent/Blower Question Triumph 1
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
glemon Wanted TR250 Wheels Triumph Classifieds 1
conan69 TR5/TR250 TR250 seats Triumph 1
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
angelfj1 TR5/TR250 Starting a TR250 that's been sitting for 10 years Triumph 12
angelfj1 For Sale TR3, 3A and TR250 Parts for Sale Triumph Classifieds 6
Retired2020 TR250 steering column bushing Triumph 2
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
S TR5/TR250 "New" TR250 on the horizon Triumph 0
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
DocDup1 General TR TR6/TR250 Steel Wheels Triumph 3
DocDup1 For Sale TR250/TR6 Steel Wheels Triumph Classifieds 5
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
C TR5/TR250 Tr250 registry Triumph 6
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
oldbagpipe For Sale '69 TR6/TR250 Seats now available Triumph Classifieds 0
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S For Sale Triumph TR250 Factory Workshop Service Manual on CD/ROM – 1968 Models Triumph Classifieds 0
T TR5/TR250 TR250 wiper switch and motor Triumph 1
T TR5/TR250 What lubricant for TR250 wiper box and cable? Triumph 2
glemon General TR TR250 Steering Wheel Options Triumph 6
P Wanted WANTED To Buy a TR4 or TR250 Triumph Classifieds 3
T For Sale TR4 TR250 Rear Fenders Triumph Classifieds 2
T TR4/4A TR4A/TR250 what are they worth Triumph 8
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
M Wanted WANTED TR4A or TR250 fendet Other British Classifieds 0
busybrit Wanted TR4, TR4A, TR250 Rear light WANTED Triumph Classifieds 0
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
J For Sale Triumph tr6 tr250, tr5 parking brake improvement kit Triumph Classifieds 1
R Wanted TR4A / TR250 Center Console Triumph Classifieds 1
B TR5/TR250 Registry for TR250's? Triumph 1
brgrmyster TR5/TR250 1968 TR250 original emissions lines Triumph 0
RobT For Sale Triumph TR250 - $32K Triumph Classifieds 2
TRopic6 For Sale Flywheel for TR250/'69 TR6 Triumph Classifieds 0
B Wanted TR250 passenger seat Triumph Classifieds 0
