TR2/3/3A Carburetors again, and again, and again
STeve 1958
I found that I was pushing the button on the SUH6 too far, giving me a false lean reading. When I only push it a 64th of an inch I get a rich reading. Am I right that a 64th is far enough?
Now the real question... Has anyone bought a color-tune and was it a good investment at $31.00
charleyf
I have had a Colortune for many years. It is very easy to diagnosis rich or lean conditions without the Colortune. I found that the Colortune is difficult to read ,but admit that I used the Colortune to solve a problem I had on my car. It is just another way to determine the rich / lean status of each individual cylinder.
CJD
I always push the whole button?!?
Honestly, I always thought of the button as a cutesy little "gimmick" on SU's. With all carbs, all engines, if the engine runs roughly and gradually slows down at idle...you are rich. If the idle is smooth, but surges so you can't get a sustained steady idle speed, then you are lean.
S
STeve 1958
John..method not much help with twin carbs., where one might be rich and the other lean. I get dieseling at shut off indicating lean, and black suit on plugs indicating rich. When I push the whole button it says it's lean, when I push half the button it says rich. Car runs great but idles rough due to a suspected cam. Car also runs great in the morning but not as well in the afternoon which would indicate rich.
Maybe time for a color-tune
CJD
Back to basics...my method works on all carbs, all cars. With multi's you must first start at a base with equal draw from both carbs and identical mixture flats set. Adjust them equally together and all will go well. At the very end, when you have gotten the best mixture with equal adjustments on the multi's, ONLY THEN try to improve a tad by individual adjustments, and even then only a flat at most difference. As my master taught me..."you must feel the engine, Grasshopper. It talks and you must listen to understand it's needs". Rough is rich...always. Surge is lean...always. This applies to both Cox TD.049 model engines and 4,000HP Donovans, and everything in between. The button is a mere gimmick to aide the unenlightened or unobservant.
If you keep getting conflicting results as you adjust equally, then you have another issue afoot. Loose butterfly shaft, vacuum leak, bad float setting, worn jet, worn needle, worn diaphragm piston, bad cylinder rings, burned valve, blown head gasket, etc. If you go off on a tangent with a single carb, you will invariably result in one carb providing the air and the other providing the fuel, and the diagnostics conflicting with themselves.
Now, go forth and tune young Luke...or Steve, I mean!?!
poolboy
Your spark plugs will give you a pretty good indication of mixture....If the plugs are old go for a 30 mile drive; try to avoid stop and go and prolonged idling, keep the rpms up, use lower gears find a place to pull over and remove at least one plug being served by a carb.
CJD
Remember there is more than one mixture. Idle and high speed. Above I am talking idle...and the plug reading doesn’t tell idle mixture. Plug reading is helpful for high speed mixture. While idle mixture in SU’s has a small affect on high speed, the primary high mixture is controlled by the needle number and jet size...along with the piston springs. Then there is transition mixture, controlled by the dashpot oil and piston springs. You can see...there is overlap in all the mixtures, with a primary control, but the others are affected when any one is changed.
But, get the idle set and most of the other mixtures fall in line...so long as you jets and needles are good.
Edit...Oh, with the carbs off you should be able to see the fuel level just below the top of the jets with the pistons lifted. If you do, and it’s not so high that fuel is spilling out, then your floats are set well. They should be as close to the same level as possible.
poolboy
A lot of thought went into creating needle profiles to give proper mixture throughout the range of rpms and load....at least with ZS carbs so you'd think SU's as well....but if you must make a choice as to where to set the jet, set it where the mixture is best for what conditions you drive the most.
If you spend most of your time sitting around letting the engine idle, set it there if you will; but if you drive the car, that's where you set your mixture to handle those conditions.
S
STeve 1958
I started over from scratch and got a much better tune up. Goes like a bat out of **** and even idles smoother.
Still not perfect but close. Thanks for all the help.
sp53
Sounds like you got it—I would add the distributor plays a big part in performance. The spark needs to advance and return smooth. Or you can get surges and fowled plugs and all kinds of things.
S
STeve 1958
This morning "She" didn't run so good and needed a lot more choke. Maybe that's because she was too rich before and now is more correct. Or maybe too hot when I tuned her up before.
Anyway once I got the choke idle down to a reasonable level all is well. "She" is a temperamental B....
S
STeve 1958
Problem solved. After resetting the mixture to neutral and retuning the other day, the jet got slightly off center. This was hanging up the damper causing a lean mixture. When I pulled the choke the damper would drop and sometimes stay down, until the next time it hung up.
Totally intermittent but easy to find once I took the air cleaners back off. We'll see how it goes tomorrow.
S
STeve 1958
Well I went on a 40 mile trip today and made it 35 miles before losing half my power. I figured the throttle linkage had come loose between the carbs. So I pulled over and found the I hadn't tightened up the air cleaners very well. One bolt vibrated out and the air cleaner dropped, blocking the intake. Felt stupid but great to get back on the road so easy. The bolt was even still there waiting for me. All in all a very fun trip from Livermore Ca. to Danville all on country back roads.
TomMull Weber Carburetors Lotus 18
B For Sale TR6 Carburetors Triumph Classifieds 0
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
steveg Mikuni HSR Carburetors Austin Healey 3
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
J Carburetors for a 1275cc Engine Spridgets 11
T TR4/4A TR4 Carburetors/Idling Triumph 3
F How to restore screws, springs and fixings on SU HD6 Carburetors? Austin Healey 7
KVH General Tech Carburetors Backfiring Triumph 6
P TR6 Caffeine & carburetors Triumph 4
Tom74TR6 Off Topic Caffeine and Carburetors - Sunday Oct 18 - New Canaan CT - Last one of the year Triumph 1
P Cobra with 8 carburetors? Spotted 4
P General TR Caffeine & carburetors Triumph 2
P BT7 Fuel pipe and carburetors Question Austin Healey 2
U Wedge Help Removing Carburetors Triumph 6
60TR3A Should My '63 BJ7's Carburetors Have Brass Caps or Black Plastic? Austin Healey 3
N BJ8 restoring carburetors Austin Healey 13
toysrrus "FISH CARBURETORS": Who needs a pair? Racing 3
S SU Carburetors Austin Healey 2
TomMull carburetors not pretty, cleaning suggestions neede Triumph 13
deadair Initial adjustments of SU H6 Carburetors Triumph 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
Luke_Healey Pros and cons of various carburetors? Spridgets 54
C TR6 Triumph TR6 Carburetors Triumph 31
A carburetors Austin Healey 6
OZ_BN1 More on SU Carburetors Austin Healey 13
Michael Oritt SU carburetors Austin Healey 5
M Gas, hot days, carburetors and emission control... Spridgets 19
M carburetors rebuilding Triumph 13
F TR6 Carburetors 1975 TR6 Triumph 33
R Carburetors Overflow Austin Healey 4
P Synchronizing SU carburetors? British Motor Corp 2
R Setting up HD8 carburetors Austin Healey 6
Hegg Wedge I can't get my SU carburetors running right [TR7] Triumph 7
H Carburetors - Loose Screws Austin Healey 19
R Carburetors- Weber vs. Twin SU's MG 8
M SU Carburetors Austin Healey 3
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
G MGB ugh.....the fuel gauge went to *** again! MG 8
L T-Series Spark plugs again ? MG 2
G Really nice to see some people are posting here again! TVR 8
K TR2/3/3A Wing mirror replacement again... Triumph 0
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
A Drum Brakes Again Austin Healey 18
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Editor_Reid Chagrinned Again Spridgets 23
waltesefalcon The Miata rides again Other Cars 11
TomMull Copper nickel lines again Restoration & Tools 0
B TR2/3/3A It runs, again Triumph 3
JPSmit Ms Triss is home again. Spridgets 12
