Results 1 to 3 of 3
Thread: I'm stuck... alternator/wiring/starting/?
  1. #1
    Join Date
    Jul 2019
    Location
    Westford, MA
    Posts
    2
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Question I'm stuck... alternator/wiring/starting/?
    Note: I did cross-post this to Triumph Experience as well but I'm out of ideas...
    I'll add pictures later tonight.
    2 things I did:
    1.) Moss Alternator replacement for the generator
    2.) Wizard Radiator/Fan combo
    I've removed the fan electric from consideration right now to focus on the core problem.
    first:
    switched from positive to negative ground.
    new positive terminal to starter solenoid lead. pretty easy swap. just flipped the battery around. have verified with a battery tester (Black and Decker charging) that the battery is at full charge.
    second:
    generator to alternator replacement. all good here and I DID NOT replace the generator wiring ends on the alternator side (moss provides a spade + plastic box kit)
    third:
    i followed the direction explicitly. I've removed the replacement lucas terminal and have the following wires:
    green/blue, green/yellow, and yellow --> all connected to the same terminal post (easiest way to test connections)
    original ground (black) is disconnected and now off to the side and not attached to anything
    yellow/red (16/18awg?) is butt-connected back to the yellow lead.
    Wiring.JPG is current state.
    test wiring.JPG was using a press in connector for testing.
    first test:
    when i FIRST tried to test, the dash ignition light came on and the starter button worked. there was a SPARK from the positive terminal. engine did not turn over.
    second test:
    I forgot to change the leads over on the ignition coil so, I did that, made sure all the wiring connections were solid and...no light, nothing.
    I'm stumped.
    any ideas how to test? I do have a Fluke 80 that I can use to test wiring though, at this point, I'm really unsure as to what I'm going to be testing...I'm stumped.
    HELP!!!!I'll add pictures later tonight.
    2 things I did:
    first:
    second:
    third:
    first test:
    second test:
    I'm stumped.
    HELP!!!!
  2. #2
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,685
    Thanks Thanks Given
    7
    11
    Thanked in
    Re: I'm stuck... alternator/wiring/starting/?
    Did you switch the leads on the ammeter? I think that is polarity dependent.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  3. #3
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,257
    Thanks Thanks Given
    7
    105
    Thanked in
    I think I read on TTE that you got this problem resolved.
    Randall
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
