Results 1 to 14 of 14
Thread: tr4 pops out of second gear on deceleration
  1. #1
    Join Date
    May 2018
    Location
    San Fernando Valley CA
    Posts
    3
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Smile tr4 pops out of second gear on deceleration
    My tr4 pops out of second gear under deceleration.
    Everything else is good with the transmission.
    Thanks for the help
  2. #2
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    2,584
    Thanks Thanks Given
    12
    35
    Thanked in
    Re: tr4 pops out of second gear on deceleration
    Mine does the same thing.
    It has been suggested that it is either the "Top Hat Bronze bush" that is worn or the synchro rings are worn. Either way fixing that would require the gear box to be removed.
    I have found an OD transmission and plan a winter install.
    David
    TR3A TS75524L
  3. #3
    Jedi Knight mgedit's Avatar
    Join Date
    Jan 2009
    Location
    Kemptville, Canada
    Posts
    835
    Thanks Thanks Given
    1
    Thanked in
    What fluid are you using? When I used Redline in mine I had a similar issue. Switching to 30 nondetergent motor oil cured my problem (was a newly rebuilt J-type OD). This was several years ago. Cheers, Mike
    Webmaster Ottawa Valley Triumph Club (www.ovtc.net)
    1956 TR3 - TS11537 (www.triumphowners.com/to-car/tr3-9/)
  4. #4
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    217
    Thanks Thanks Given
    2
    3
    Thanked in
    It could be the selector fork or a problem with the detent ball on the shaft or one of the springs and balls in the gear slider has broken and fallen out. If the problem is in the selectors you can fix it with the box in if the problem is in the gear slider you will have to take the box out.
    Graham
    [SIGPIC][/SIGPIC]
  5. #5
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,685
    Thanks Thanks Given
    7
    11
    Thanked in
    Quote Originally Posted by Graham H View Post
    Graham
    If it's in the selector, you can sometimes hold it in gear with the shift lever. If it's the top hat, you can't. Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  6. #6
    Yoda TR4nut's Avatar
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,875
    Thanks Thanks Given
    3
    Thanked in
    I had that same issue, was convinced it was the 2nd gear bush as I had seen several broken previously and I didn’t test per Toms suggestion. All mine was was was a weak spring on the selector shaft.
    Randy
    70 TR6 - running
    59 TR3A - slumbering
    64 TR4 - got another one!
  7. #7
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,253
    Thanks Thanks Given
    27
    Thanked in
    I have gone back and forth with same kind of issue for 20 years on this one trans. Does anyone know how tight to make those 3 springs and balls deal on the back of the shifting tower or are you taking about the ball that goes in on its side in the tower between the 2 shafts? In addition, I remember a post where the discussion was about the O rings on the shafts and how they are difficult to seal and the correct O rings had to be improvised somehow. Mine pops out going downhill only and leaks, something like tightening up or replacing the spring and ball would not surprise me for a fix-- plus I have the trans cover off so now would be a good time.
    steve
  8. #8
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,875
    Thanks Thanks Given
    3
    Thanked in
    I adjusted the ones on the end - easy to do in my case because I had the screw in plug style. I didn’t get fancy with measuring any kind of release tension, just tightened down more and tried it out.
    Randy
    70 TR6 - running
  9. #9
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,253
    Thanks Thanks Given
    27
    Thanked in
    Does the “screw in plug style” mean that you have access to the screw with the shifting tower on the car and in place? On my tr3 I need to pull the tower off and flip it over and then are 3 screws in the back that can be screw down to put more pressure on the shaft.
  10. #10
    Join Date
    Jan 2006
    Location
    Nacogdoches Texas
    Posts
    3,875
    Thanks Thanks Given
    3
    Thanked in
    No you still have to pull the cover - later covers, I think later TR6 had small freeze plug style plugs instead of the screw in plugs which seem to me to be more of a pain to deal with.
    Randy
    70 TR6 - running
  11. #11
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,685
    Thanks Thanks Given
    7
    11
    Thanked in
    Quote Originally Posted by sp53 View Post
    Interesting, I've never tried to "adjust" those screws, instead I've left them very slightly lower than the surface, as they seemed to be when I took them out. I also find no mention of adjustment in the Service Manual. I suppose there is no harm in screwing them in more to put more tension on the springs but there's really nothing to hold them in place (loctite maybe). But from my experience, they should work properly just below the surface and will be held in place by the mating surface on the transmission. But if screwing them in tighter works, that might at least prolong the required rebuild, which would be a good thing.
    From what I gather, the newer style plugs are best replaced by tapping the housing and using the threaded type. Also kind of fun to remove or so I'm told.
    Tom
  12. #12
    Join Date
    May 2018
    Location
    Posts
    3
    Thanks Thanks Given
    Thanked in
    Thank you mgedit. It's my brother in law's car and will ask him what fluid he is using.
  13. #13
    Jedi Trainee Joe Schlosser's Avatar
    Join Date
    Jul 2015
    Location
    Chester NY
    Posts
    341
    Thanks Thanks Given
    7
    Thanked in
    Any time I have had poping out of 2nd (not truimph) it was worn synchros.
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  14. #14
    Join Date
    Feb 2018
    Location
    Posts
    217
    Thanks Thanks Given
    2
    3
    Thanked in
    It's the synchro hub with it's spring loaded balls that hold the gears in mesh, the box would have to be well worn for that to be the problem but still possible
    Graham.
    [SIGPIC][/SIGPIC]
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
