Results 1 to 16 of 16
Thread: Does this sound like fuel pump problem?
  1. #1
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    672
    Thanks Thanks Given
    Thanks Thanks Received
    6
    Thanked in
    I have not been able to drive my TR3 for about a month. Today I tried to start it and it would not start. I pumped the fuel pump lever a bunch of times but I could not feel any pressure. I have about 1/2 tank of gas. I then took the filters off and squirted gas into both carbs. It would start immediately and run for several seconds and then stop. I did that about 4 times, fully chocking it each time. Each time I put gas in the carbs it would start but then die. I put on a new fuel pump some time in 2012. I have been using both non-ethanol and ethanol gas. I am thinking the fuel pump has failed. Agreement, or could the problem be something else? Thank you!
  2. #2
    Join Date
    Nov 2014
    Location
    Biggsville,IL
    Posts
    96
    Blog Entries
    2
    Thanks Thanks Given
    4
    Thanked in
    Re: Does this sound like fuel pump problem?
    I just had the same problem. Found out the 6 screws holding diaphram down are loose Get lucky fast, I hope. LeT
  3. #3
    Join Date
    Jun 2008
    Location
    Floe Ice, Antarctica
    Posts
    6,418
    Thanks Thanks Given
    28
    Thanked in
    Could be. Maybe. Possibly.
    Might just be the coil (joke).
    However, rotten rubber hose in the line from tank to pump.
    Rotten metal pipe in same area.
    Pickup tube plugged or rotted.
    But, yeah, after all that it could be the pump (or the coil).
    You need to have almost perfect suction. Even small holes in lines, loose clamps on old hardened rubber hoses, and loose diaphragm screws. Link to diaphragm broken.
    Disconnect both sides of the pump. Drop a hose from suction side to gas can. Pump manual prime lever, see what comes out the pressure side.
    Then work back towards the tank.
  4. #4
    Great Pumpkin - R.I.P TR3driver's Avatar
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    You also get no pressure at the manual lever if the feed to the float bowls is blocked. That's the first thing I would check, as I've seen it several times. Some gas seems to form a hard deposit when it dries (instead of the old varnish), which can glue the float valves shut.
    Randall
  5. #5
    Join Date
    Jun 2008
    Location
    Posts
    6,418
    Thanks Thanks Given
    28
    Thanked in
    Quote Originally Posted by TR3driver View Post
    Except:
    " I then took the filters off and squirted gas into both carbs. It would start immediately and run for several seconds and then stop. I did that about 4 times,"
    We do know the inlets to the carbs aren't blocked.
    We also know there is fuel in the tank:
    "I have about 1/2 tank of gas."
    So, both carbs are blocked, both floats stuck "up", both needles bad......hard to figure.
  6. #6
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    672
    Thanks Thanks Given
    6
    Thanked in
    I took the fuel line off right in front of the carbs and pumped the fuel pump lever and no gas came out of the gas line. BTW, the sediment bowl on the fuel pump is clean, no sediment. I did see a bit of sediment in the gas when I took the metal fuel filter off and poured the gas out of the "in" outlet of the fuel filter. The gas coming out of the "out" outlet of the filter did not have any sediment. I put a new fuel filter on anyway but it did not help.
  7. #7
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Quote Originally Posted by TOC View Post
    Except:
    I interpreted that to mean he squirted gas into the air intake (throats) rather than into the float bowls. If so, the test, while very informative, doesn't prove there is fuel in the bowls or that it is getting through the jets into the throats.
    Not really relevant, just a humorous story: the other day, a friend decided the fuel pump in his pickup must be bad. Cut a hole in the bed rather than deal with dropping the tank (fuel pump lives in the tank on that model, like most modern cars & trucks). Replaced the fuel pump; still wouldn't run. Took the new pump back out, and finally noticed that it was bone dry!
    Problem all along was a stuck fuel sender. Rather than the 3/4 shown on the gauge, the tank was dry. Added some fuel, started right up.
    Randall
  8. #8
    Join Date
    Oct 2014
    Location
    australia
    Posts
    452
    Thanks Thanks Given
    3
    Thanked in
    Have you checked to see if fuel is reaching the fuel pump from the tank?
    You could also make up a small, temporary fuel supply attached to the pump and check that the pump is OK.
  9. #9
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,735
    Thanks Thanks Given
    6
    55
    Thanked in
    Disconnect the fuel line to the tank right before the pump. If fuel runs out, then chances are the pump is bad. If no fuel runs out, you have a blocked line to the tank.
    John
    1955 TR2
  10. #10
    Join Date
    Jan 2011
    Location
    stamford, CT
    Posts
    2,743
    Thanks Thanks Given
    35
    Thanked in
    It could also be that old problem of something in the tank blocking the outlet.
  11. #11
    Jedi Trainee Graham H's Avatar
    Join Date
    Feb 2018
    Location
    Perth Western Australia
    Posts
    337
    Thanks Thanks Given
    3
    10
    Thanked in
    Have you got the fuel tap turned on?
    Graham
    [SIGPIC][/SIGPIC]
  12. #12
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    672
    Thanks Thanks Given
    6
    Thanked in
    I have a fuel shutoff valve right before the fuel filter then a short hose runs from the filter to the pipe going to the fuel pump. When I disconnected the fuel filter at the "IN" end and turned on the shutoff valve, the gas flowed freely out of the pipe coming from the fuel tank. Thanks for all the suggestions!
  13. #13
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,735
    Thanks Thanks Given
    6
    55
    Thanked in
    I think you’ve got it! Fuel pump.
    John
    1955 TR2
  14. #14
    Join Date
    Apr 2012
    Location
    Raleigh, NC, USA
    Posts
    672
    Thanks Thanks Given
    6
    Thanked in
    Thanks John. I agree...fuel pump. When I was looking for a replacement fuel filter in my stuff I ran across the "emergency" electric fuel pump that I bought off the internet at least a year ago. I think it was Geo Hahn who posted the recomendation back then. I had forgotten I had that. So today I hooked it up and sure enough, the car started right up and ran good. I only bypassed the fuel pump, nothing else. I would not want to drive very much with it since I've attached it to electric with aligator clips. At least I can run the engine until I can get a new mechanical fuel pump and get it installed. I appreciate the help and ideas from everyone!!!
  15. #15
    Join Date
    Oct 2014
    Location
    australia
    Posts
    452
    Thanks Thanks Given
    3
    Thanked in
    Buy a pump that has a manual pump lever...makes easier priming when car has sat for some time.
  16. #16
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,735
    Thanks Thanks Given
    6
    55
    Thanked in
    Quote Originally Posted by malbaby View Post
    Saves wear and tear on the starter and crank bearings too!
    John
    1955 TR2
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
