Rear ended pumpkin color
metropolisman
I have a question concerning the proper color of the rear end pumpkin. I see in some restorations that they are left in there natural
Aluminum cast finish. Is this a concours correct finish? Additionally the Armstrong shocks front and rear have this same finish. Is that the correct finish? Thanks for your responses in advance.
John Turney
According to Anderson & Moment, the pumpkin should be painted black along with the axle housing, the front & rear Armstrong shock bodies are unpainted and the arms are black.
Deleted member 8987
Rear ended pumpkins are generally the same color they were before rear ending.
Opinion.
Editor_Reid
Platinum
steveg
Also bear in mind that the Anderson/Moment book is essentially a very outdated version of the Concours Guidelines available from the Concours Registry.
I bought the Concours Guidelines - Anderson Moment has a lot more pictures. Not that it's an option for anyone who didn't buy it when it was in print.
Healey Nut
Suggestions :highly_amused::glee::encouragement::cool:
R Wanted Rear-ended repair items Triumph Classifieds 3
B TR6 Rear-ended today and my beautiful TR6 is smashed.. Triumph 18
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
drooartz Bugeye jack points to remove rear axle Spridgets 18
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
