Healey model and year
Lucca
Hello,
Please indicate if you have idea the model and year of the Healey as per attached pictures.
Vin plates are missing. Is there other body location or frame to look for an id number?
Thanks in advance.
gonzo
On first pass this does not appear to be an Austin Healey. Agreed there are styling cues, but the heavy windshield frame, dash configuration, fender side vent(s), floor stamping etc. are not genuine Healey. Can you ascertain if the body is made of fiberglass? Healeys are aluminum. Intrigue though...let us know what else you find. GONZO
RAC68
Hi Lucca,
It could be a 100/6 but with many customizations. From the limits of the pictures presented, the type of side vents on the car were found on Jaguar roadsters, the dash is oviously not traditional Healey, and the chrome trim was someone's attempt to bling the sides. As far as Gonzo's comments, a plastic body would be a definite negative indicator as the Healey had steel side fenders, doors, and bonnet/boot lids with aluminum center shrouds.
All in all, it could have been a traditional Healey 100/6 from the mid to late 1950s and, if so, could be brought back with work and money.
Good luck,
Ray(64BJ8P1)
red57
The door shown is a '57 or '58 100-6, the hole in the door for the locking door handle is the clue here and only used on early 100-6 (Longbridge only, I think).
Beyond that, it is hard to know what is modified - the side vent, as Ray said, is non-stock, - possibly Jag or ?, and I agree someone was trying for 'bling' with the side chrome.
Windshield looks stock 100-6, dash is obviously a replacement. Transmission tunnel looks possibly non-stock.
I think it is a 100-6 that was heavily modified at some point in history.
Good news is that, unless filled with bondo, the sill and rear fender dog leg shown look really solid so this may be a real keeper.
Dave
L
Lucca
I received new pictures.
Please let me know besides vin plates, where can I find body or frame numbers?
healeyblue
Definitely a 57 or early 58 Longbridge car. They are the only years to have the hood prop on the left side. Not sure what engine is in that thing now. It is a serious project and based on the modifications that were unlovingly done in its past I can not imagine it is worth much as it sits. The only saving grace would be if it is fairly rust free, but not having a title would negate the value anyways.
Jim
Jerry
I don't think the VIN number is stamped on a 100 6 anywhere but on the VIN plate . Which is NOT on the firewall. It is held on by two screws, easy to remove.
John Turney
I have no idea what the engine is, but it's not a Healey engine. The left door is from a 57 or early 58 Longbridge, but the hood, even though the prop rod is on the left side, isn't. It would have a ridge down the center.
red57
I agree the hood prop is another clue indicating an early 100-6. However....
Are you sure the picture showing the engine is of the same car (or the same time era?) as the other 3 pictures? I ask because in the engine picture I see two un-painted aluminum(?) patches/repairs to the shroud at the rear hood opening - they are formed to fit the contours of the shroud hood opening with one to the rear of the right hood hinge and the other just to the left of the center of the hood opening, both appear 3-4" wide and extending 3-4" rearward from the hood opening. I cannot see any bare un-painted sections of the front shroud in the (admittedly poor) exterior body shots. Not trying to stir a controversy but it seems curious to me and, if it was considering a purchase, I would ask for lots of detailed pictures (I like date stamped pics) before I went any further.
Dave
maxwedge5281
not attempting to hijack this thread, but i have two 1959 bn6 healeys. someone mentioned the prop rod and it brought to mind a question. one of the cars has the hood prop on the left and the other has has the prop rod on the right! is there an explanation for this? appreciate any information from the healey sleuth community.
steveg
I'm wondering if it may be a jeep or other old American 4 cyl. The structure coming out the front looks like it might go with an obsolete water pump like they used to have attached to the rear of the generator.
CraigC
Engine looks Triumph TR2/3/4-ish except for the thermostat housing and manifold/carb. Perhaps out of some early Triumph sedan?
L
Lucca
Thank you Guys for the help!
Any idea what engine is installed?
Also, the find these numbers in the rear shaft 13 111 12 663 14.
bob hughes
Four cylinder engine with what looks to be a solex down draft carb. on the left hand side of the engine, with the plugs on the right, it sure is a mongrel for a Healey
Give it a miss
:cheers:
Csarneson
I have a 57 100/6 longbridge and mine has a chassis number stamped on to the right side front shock mount plate at the front. If you can find that chassis number then you might be able to find the VIN from the heritage certificate research place. Regardless, that car has been heavily modified. I think it's pretty cool except for that tiny engine.
Chris
PAUL161 Photo: What Model of Healey? Austin Healey 7
L Tinplate Austin Healey 100 model Austin Healey 3
AUSMHLY What model Healey is this...calling all Eagle Eyes Austin Healey 21
Editor_Reid Repro BOX for Healey Boat Model Austin Healey 3
soren_ak 1958 Austin Healey 100/6 rare "plain Jane" model Austin Healey 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyRick Perfect Healey Floor Jack Austin Healey 14
T Netflix Christmas Film with a Healey Austin Healey 4
W For Sale 1954 Nash-Healey Le Mans Coupe Other British Classifieds 2
N For Sale Austin Healey Frogeye Sprite Spridgets Classified 0
dougie 1960 Austin Healey 3000 Works Lightweight vs. 1962 Ferrari GTO Austin Healey 6
