The Panhard Rod is Supposed to be Straight, Right?
John Turney
Looks like I've been too aggressive in right-hand turns:
Anyone have any ideas on how to make a stronger one without paying DWM prices?
red57
Wow, this is a new one for me, I don't think I've ever seen a bent one before.
I could be way wrong but I doubt it is from aggressive driving, I raced mine for a lot of years and never bent one (I regularly confirmed it was straight when servicing the car), nor have I heard of any other racers bending one.
Be interesting to hear from others, maybe this is more common than I know?
It looks like you have HDPE/synthetic bushings of some kind which may be causing a strain when the axle is moving up & down? I always ran the stock rubber bushings which are usually a bit softer.
Dave
John Turney
John Turney
It was straight when I put it in. Yes, those are poly bushings that were on the anti-sway bar. I put black ones
in front and moved these to the back so they wouldn’t show.
I also broke the axle axle mounting tab.
Joe Schlosser
The thig that makes the bar strong is the material the diameter and wall thickness.
If you want to keep the same diameter go with a thicker wall tube or to one of the stronger chrome molly steels.
However, as mentioned above it appears that your attachment points may be too strong for the vertical travel of the wheel.
I don't know how the bar attaches in an AH but the bar should not bind in vertical movement.
I always preferred Heim joints as they do not bind.
John Turney
John Turney
Vertical movement of the rear axle is not one of a Big Healey's strong points. Total is about 7", IIRC.
Stock OD is 5/8", ID appears to be 3/8".
dougie
I impoved the panrod on my racer when I hit the track about 15 years ago. Reinforced the welds on both axle mounts and the chassis, in addition to replacing the stock rod with a heavier grade unit and mounting hardware. Never had any issues ......
Joe Schlosser
5/8 inch sounds a bit small. If it was me I would go with at least 7/8 diameter.
Bars are available with pretapped ends from many circle track shops at a reasonable price.
Healey Nut BT7 Panhard Rod Austin Healey 28
T Need advice for installing a Winner's Circle Panhard rod on a BE Spridgets 4
John Turney Panhard Rod Austin Healey 14
steveg Is a Panhard Rod Necessary? Austin Healey 34
Simmo TR2/3/3A Panhard Rod Triumph 9
N Panhard Rod Mounting???? Spridgets 9
K Panhard Rod on a TR3 Racing 3
J Do I have a panhard rod problem? Austin Healey 12
H Panhard rod Austin Healey 1
aeronca65t Panhard Rod for Sprite Spridgets 0
DanLewis Panhard Bar Kit from Mini Mania Spridgets 0
DanLewis Would a Panhard bar fix this problem? Spridgets 11
Nelson Panhard Bar vs Watt's linkage Spridgets 17
K TR2/3/3A Panhard or Rear Sway Bar on aTR3? Triumph 10
Trevor Jessie Panhard Bar Spridgets 29
R Panhard Bar Kit Spridgets 3
T panhard bar for tr4-where to locate & mount Racing 20
T TR4/4A looking for pictures-tr4 with panhard bar Triumph 7
GB1 Panhard Mounts Spridgets 7
GB1 1/4 elliptical Panhard & Sway Bar Spridgets 1
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
