Universal joints
Bugeyze
Is there a correct position for the grease nipples on prop' shaft universal joints? Should they point towards or away from the shaft?
trrdster2000
I have always done towards the shaft. A little easier to get to after install.
Bayless
Latest ones I got from Moss recently had the nipple in the end of one of the bearing cups. Seems like a logical improvement.
Stan Kowznofski
Nipple in the end of the cross not a good idea. Poor balance and road debris can break it off. Whether aimed toward the shaft or yoke is a matter of preference and access considerations but make sure it is under compression when the drive shaft is loaded.
Bugeyze
Bugeyze
Thanks for input, I will mount them toward the shaft.
Stan, I'm not sure what you mean, but make sure it is under compression when the drive shaft is loaded.
Stan Kowznofski
The driveshaft rotates in a clockwise direction when viewed from the front so be sure the nipple is being squeezed by the driving yoke against the driven yoke.
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
Foura TR4/4A Steering column Universal Joints Triumph 10
sd80mac7204 Universal Joints Triumph 3
TR4 TR4/4A Changing universal joints in a TR4???? Triumph 5
KVH General Tech Universal Joint—Driveshaft Triumph 20
C Bugeye propeller/drive shaft- universal joint Spridgets 1
T TR2/3/3A 30a 5 pin universal relay Triumph 12
Griz Universal joint let go Austin Healey 15
Foura TR4/4A Universal joint diameter Triumph 9
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
D TR2/3/3A Universal Joint Lube Question Triumph 8
R Drive shaft universal joint bear cap modification Austin Healey 7
TulsaFred Universal Joint problems Spridgets 9
JPSmit Universal Wire Harness question Restoration & Tools 3
1 Hardtop AH 100/4 Universal Laminations Austin Healey 16
1 Hardtop AH 100/4 Universal Laminations FORUM Navigation Questions 1
wkilleffer Broken universal joint MG 11
D TR4/4A TR4 inner ball joints Triumph 8
Hamish Racing TR2/3/3A Sway bar rose joints and diy brackets Triumph 4
R Moss permanently lubricated U-Joints Austin Healey 1
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
D TR6 U-joints Triumph 3
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
AngliaGT TR6 TR6 U Joints Triumph 3
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
RickB Crimped in U-joints? Spridgets 7
6TTR3A TR6 Replacing the IRS u-joints on a TR6 Triumph 15
vette Throttle Linkage Ball Joints Austin Healey 5
V Upper Ball Joints Triumph 16
RJS Greasing U-joints Triumph 13
Willie_P TR4/4A restoration - ball joints, TR4 Triumph 10
5 Steering Ball-Joints Austin Healey 3
mikecyc72usa Oh the fun of U-joints Triumph 19
SkinnedKnuckles TR6 TR6 Ball Joints Triumph 13
M Broken Ball Joints Spridgets 14
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
King_of_England Ball Joints and Mini ID British Motor Corp 7
T TR4/4A tr4 steering column-replace rubber with u-joints? Triumph 9
Popeye Welding butt joints... crack in weld after grindin Restoration & Tools 3
Tabcon Ball Joints and mushy rubber Triumph 7
Z Dive Shaft Uni Joints Austin Healey 10
I TR6 How do I grease TR6 trailing arm u-joints? Triumph 8
Dadandson My U Joints are clicking away Spridgets 14
bigjones Ball Joints - does this look right to you? Spridgets 12
mrv8q TR6 TR6 carb "ball joints" Triumph 10
N grease for rear axle sliding joints Triumph 14
svtmikey Un-joints - I don't remember them being this hard! Triumph 29
L Tightening U-joints Restoration & Tools 3
dklawson TR6 U-Joints Comparison, TR4 vs. TR6 Triumph 3
G TR5/TR250 NAPA U joints fro TR250/6 Triumph 5
