TR6 TR6 turn signal puzzle
TR3TR6
My left turn signal on my 76 TR6 quite working. The right turn signal flashes, but the left one just lights up but no flashing. When I turn on my hazard lights, all four lamps flash. Looking at Dan Masters schematics for the 76 TR6 it shows the signal flasher as the source for both the right and left lamps. After studying the schematic, it appears to me that the problem has to be in the turn signal switch. I don't want to invest in parts I don't need; has anybody else run into this problem? Thanks.
TR3driver
Great Pumpkin - R.I.P
Do the lights come on as well, when you select left turn? If so, it's more likely to be a poor connection somewhere, or even a corroded wire.
The turn flasher is deliberately sensitive to current through the lamps, so you can tell from the driver's seat if one is burned out. If it sees less current than it expects (but more than a burned out bulb), it may do strange things like not flash (or sometimes flash very quickly).
The hazard flasher is not load-sensitive, so doesn't suffer the same problem.
The poor connection could be in the switch, but I wouldn't replace it just on that.
TR3TR6
TR3TR6
Randall:
I was thinking a poor connection in the switch, but I didn't know whether the lights would still light up. When it gets darker, I will check the turn signal lights and see if one side is dimmer then the other. All of my lights are pretty dim at night. The dash lights are hard to see and I use the headlight brights to see the road. I checked the alternator and it's putting out the required voltage. The good old Prince of Darkness!
ed_h
If one or more of the signal lights come on, but just don't flash, it probably isn't the switch.
If one or more signal lamps doesn't come on at all, start there. Check bulb, socket, and ground, and wiring in that order.
Ed
TR3TR6
TR3TR6
Ed:
I ruled that out because all four lights come on and flash when I turn on the hazard switch.
mrv8q
Disassembling and cleaning the TR6 fuse box did a world of wonders for my long-slumbering ‘74 TR6...
eliminated many electrical gremlins.
TR3TR6
TR3TR6
I'll give that try Kevin; now neither side of the turn signals are working, but they all work with the hazard switch. Love these British cars.
poolboy
You didn't substitute LED's for the regular filament bulbs in any of those sockets, did you ?
TR3TR6
TR3TR6
No, I didn't, Since the turn signals don't work at all now and the turn signal relay and switch both look like the originals, it's probably time for some new parts.
TRopic6
Terry, The Turn Signal Flasher gets power from the hazard switch when it is pushed in (or 'off'). Cycle it a few times and see if the light green/grey wire at the flasher has 12v. Old flasher units get flakey - you can bypass it by connecting the two light green wires together for testing the turn switch and circuits.
Do you have a test meter or light? There's lots of wiring connections that can cause problems. The switches can be cleaned up and usually made to work. The flasher units seem to get more erratic when messed with, but the metal cover can be carefully removed if you want to have a go. I've got spares of all those parts if you need.
Jeff
TR3TR6
TR3TR6
Thanks for the info Jeff, I have started to go through the troubleshooting sections in Dan Masters Electrical Maintenance Handbook. He covers the the TR6 pretty good.
TR3TR6
TR3TR6
Update: Yesterday the turn signals didn't work, the fuel, voltage and temp gauges quite working and I was thinking of ordering parts. This morning I started troubleshooting the fuse box. All I did was check for voltage at the three fuses and they all checked out. I went and started up the car and all the electrical worked. Took it out for a spin and everything was still working. All I did was put my test probe on each side of the fuses. I'm going to clean up the fuse box and see what happens. Very frustrating.
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
H TR6 TR6 Turn Signal Cam misaligned Triumph 3
hondo402000 TR6 Turn Signal Issue on 71 TR6 Triumph 4
hondo402000 TR6 resteting the turn signal canceller TR6 Triumph 11
trbob TR6 TR6 TURN SIGNAL ISSUE Triumph 8
Steve1970 TR6 TR6 - Should turn signal work if hazard is gone? Triumph 8
tr6web TR6 TR6 Turn signal not working Triumph 4
2wrench TR6 TR6 Does not turn over. Triumph 38
S TR6 TR6 project back together- turn the key and CLICK Triumph 7
I TR6 TR6 turn indicator Triumph 1
D TR6 TR6 won't turn over -Rookie TR6 owner Triumph 12
I TR6 TR6 turn indicator not working Triumph 1
I TR6 TR6 turn indicator Triumph 2
H TR6 TR6 turn signals Triumph 15
Webb Sledge TR6 TR6 Turn Signals Triumph 4
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
