Results 1 to 12 of 12
Thread: TR6 turn signal puzzle
  1. #1
    Jedi Warrior TR3TR6's Avatar
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    Thanks Thanks Received
    2
    Thanked in
    My left turn signal on my 76 TR6 quite working. The right turn signal flashes, but the left one just lights up but no flashing. When I turn on my hazard lights, all four lamps flash. Looking at Dan Masters schematics for the 76 TR6 it shows the signal flasher as the source for both the right and left lamps. After studying the schematic, it appears to me that the problem has to be in the turn signal switch. I don't want to invest in parts I don't need; has anybody else run into this problem? Thanks.
    Terry
    76 TR6
  2. #2
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,337
    Thanks Thanks Given
    8
    111
    Thanked in
    Re: TR6 turn signal puzzle
    Do the lights come on as well, when you select left turn? If so, it's more likely to be a poor connection somewhere, or even a corroded wire.
    The turn flasher is deliberately sensitive to current through the lamps, so you can tell from the driver's seat if one is burned out. If it sees less current than it expects (but more than a burned out bulb), it may do strange things like not flash (or sometimes flash very quickly).
    The hazard flasher is not load-sensitive, so doesn't suffer the same problem.
    The poor connection could be in the switch, but I wouldn't replace it just on that.
    Randall
  3. #3
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    Randall:
    I was thinking a poor connection in the switch, but I didn't know whether the lights would still light up. When it gets darker, I will check the turn signal lights and see if one side is dimmer then the other. All of my lights are pretty dim at night. The dash lights are hard to see and I use the headlight brights to see the road. I checked the alternator and it's putting out the required voltage. The good old Prince of Darkness!
    Terry
    76 TR6
  4. #4
    Join Date
    Oct 2013
    Location
    Omaha, NE
    Posts
    120
    Thanks Thanks Given
    3
    Thanked in
    If one or more of the signal lights come on, but just don't flash, it probably isn't the switch.
    If one or more signal lamps doesn't come on at all, start there. Check bulb, socket, and ground, and wiring in that order.
    Ed
    For just a little more, you can do it yourself!
  5. #5
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    Ed:
    I ruled that out because all four lights come on and flash when I turn on the hazard switch.
    Terry
    76 TR6
  6. #6
    Luke Skywalker mrv8q's Avatar
    Join Date
    Jan 2005
    Location
    Los Angeles, CA USA
    Posts
    1,760
    Thanks Thanks Given
    4
    1
    Thanked in
    1 Post
    Disassembling and cleaning the TR6 fuse box did a world of wonders for my long-slumbering ‘74 TR6...
    eliminated many electrical gremlins.
    Best, Kevin Browne
    '59 TR3A #TS58370L
    Look for Ancient Aliens on The History Channel
  7. #7
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    I'll give that try Kevin; now neither side of the turn signals are working, but they all work with the hazard switch. Love these British cars.
    Terry
    76 TR6
  8. #8
    Yoda poolboy's Avatar
    Join Date
    Oct 2007
    Location
    S.W. Mississippi
    Posts
    3,740
    Thanks Thanks Given
    19
    15
    Thanked in
    You didn't substitute LED's for the regular filament bulbs in any of those sockets, did you ?
    DRIVE 'EM IF YOU GOT 'EM
  9. #9
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    No, I didn't, Since the turn signals don't work at all now and the turn signal relay and switch both look like the originals, it's probably time for some new parts.
    Terry
    76 TR6
  10. #10
    Jedi Trainee TRopic6's Avatar
    Join Date
    Jan 2007
    Location
    Irmo, SC
    Posts
    337
    Thanks Thanks Given
    1
    6
    Thanked in
    Terry, The Turn Signal Flasher gets power from the hazard switch when it is pushed in (or 'off'). Cycle it a few times and see if the light green/grey wire at the flasher has 12v. Old flasher units get flakey - you can bypass it by connecting the two light green wires together for testing the turn switch and circuits.
    Do you have a test meter or light? There's lots of wiring connections that can cause problems. The switches can be cleaned up and usually made to work. The flasher units seem to get more erratic when messed with, but the metal cover can be carefully removed if you want to have a go. I've got spares of all those parts if you need.
    Jeff
  11. #11
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    Thanks for the info Jeff, I have started to go through the troubleshooting sections in Dan Masters Electrical Maintenance Handbook. He covers the the TR6 pretty good.
    Terry
    76 TR6
  12. #12
    Join Date
    May 2010
    Location
    Derby, Kansas
    Posts
    404
    Thanks Thanks Given
    1
    2
    Thanked in
    Update: Yesterday the turn signals didn't work, the fuel, voltage and temp gauges quite working and I was thinking of ordering parts. This morning I started troubleshooting the fuse box. All I did was check for voltage at the three fuses and they all checked out. I went and started up the car and all the electrical worked. Took it out for a spin and everything was still working. All I did was put my test probe on each side of the fuses. I'm going to clean up the fuse box and see what happens. Very frustrating.
    Terry
    76 TR6
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
