Spark plug wires
What ignition wires are you all using for a ‘57 bn4?
Side entry cap.
Thanks!
(My question of the week)
Larry
Keoke
I prefer Hf performance stranded copper wire operating in conjunction with either / or suppressed spark plug connector suppressor plugs
longbridgehealey
John, are you having any problems fitting the caps onto the wires, as in do they fit snugly?
longbridgehealey
Ok, thanks. I need new wires, and I’m unsure which way to go. I read some older threads which were talking about the bumblebees being too thin to get a good tight crimp on them. Thanks for the info,
larry
I've never had much luck crimping stranded copper wires, bumblebee or black (bumblebees look cool, but I've never understood how one set of stranded copper wires could be 'high performance' and another not; I think they're more of a marketing gimmick). If you have an original type distributor cap the pointed terminals screw into the wire, and at the plug end the resistance plug caps others have mentioned do the same (there's a prong that looks like a sheet metal screw inside). I recommend you put some silicone/dielectric grease in both the distributor cap holes and the plug cap holes to help prevent corrosion. AFAIK, the wires are all 7mm, which was a de facto standard for cars of all makes up until, oh, the seventies or so when there began to be issues with the radios more people were putting in their cars and we went to 'suppression' wires. I use resistance plug caps and resistor plugs, totaling about 30Kohms.
Healey Nut
Im with Bob here , wire is wire is wire the only difference is the insulation and if you have a basic point/condenser system then so called “high performance “ wires dont do nothing IMHO.
The better insulation was introduced to prevent radio interference and that annoying buzz over the radio .
I dont listen to the radio in my Healey its the original BMC single bezel speaker so its useless anyway .
if the car runs well save your money , its like snake oil “its going to produce more HP if you use it “ Yeah right !!!!
Keoke
HI ALL:Just a thought
Well in the above case :
The gauge and number of those strand wires will dictate its flexibility and usefu llife
Similarly:
The insulated coverings rarely supply any real electromagnetic radiation suppression
;this is usually provided by under lying supprt designs.
The French required shielded igntion systems o the imported Healey cars to address this.
noisy power converters used combined with inadequate filtering caused much of the problems in early designs
[SUB][/SUB]
K TR2/3/3A Testing spark plug wires..... Triumph 11
AUSMHLY Spark plug wires 7mm or 8mm Austin Healey 21
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
M Restoring proper order to spark plug wires Triumph 36
Musicman Spark Plug Wires Triumph 10
L Spark Plug Wires Triumph 12
AUSMHLY Spark plug wires affecting tachometer? Austin Healey 16
1 Spark plug wires gone 'haywire' Spridgets 16
tosoutherncars Q - spark plug wires Spridgets 3
Got_All_4 TR2/3/3A TR3A Spark Plug Wires Any Good Ones Out There? Triumph 11
K Best spark plug wires with Pertonix:what to use? Racing 1
K "Bumblebee" spark plug wires....... Triumph 10
AUSMHLY Spark plug wires Austin Healey 8
danielnorton Spark plug wires Spridgets 6
Woodie spark plug wires Spridgets 2
Woodie bosch spark plug wires Spridgets 5
C Spark plug wires MG 14
T Cut/Splice Spark Plug Wires?? Triumph 13
W Replacing spark plug wires Restoration & Tools 1
tahoe healey spark plug wires Austin Healey 11
CARSINC Spark plug thread size Spridgets 2
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
K TR2/3/3A Spark plug inspection Triumph 5
PAUL161 T-Series Odd spark plug encounter! MG 10
G Opinion on spark plug color Austin Healey 15
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Spark Plug Gap? Triumph 4
K Numbered Spark Plug Boots? Austin Healey 27
B Spark Plug Wire Caps Austin Healey 16
B TR6 Spark plug gap Triumph 5
toysrrus TR6 Spark plug question Triumph 23
K TR2/3/3A Spark Plug cuts and diagnosing? Triumph 13
G Correct spark plug ends - early BJ7 Austin Healey 1
R BJ7 spark plug threads Austin Healey 17
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
steveg Accidentally deleted Spark Plug Issue thread Austin Healey 2
steveg Spark Plug Issue Austin Healey 54
S TR2/3/3A Spark plug threads Triumph 10
R '60 3000 Spark Plug recommendations Austin Healey 6
D TR6 Spark Plug Triumph 8
dcoplan Spark plug and oil change question Spridgets 9
H BJ8 spark plug reach Austin Healey 32
Jer chasing spark plug threads on head? Spridgets 8
R Spark plug thread Triumph 2
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
D Spark Plug Gap Austin Healey 10
W Source for spark plug terminals Spridgets 9
af3683 TR2/3/3A TR3 Spark Plug Wire Question Triumph 11
JPSmit Quick Spark plug question Spridgets 10
Got_All_4 TR2/3/3A TR3 spark plug wire problems Triumph 3
