TR2/3/3A TR3 with Ground Conversion
scotdail
Hi Folks:
New here, so kindly direct me to the appropriate discussion if needed. I understand that a popular topic may be negative ground conversion :tennis:
I just purchased a 1960 TR3A that has been converted to negative ground. I restore old Brit bikes also, and always remain positive there!
Some folks in the local Triumph club have mentioned that there are feelings that a negative ground conversion is a good thing on a TR3. I am having electrical ailments on this one however that appear grounding related. It starts and runs great, wipers work fine, ammeter appears to work, but headlights and signals appear to have grounding issues, horns don't work. Headlights have the red wire in the main harness connected to the red/blue, high beams non-functional, park lamps not working except for signals. This doesn't seem like a correct ground conversion? It also has the original generator and a Pertronix ignition installed.
So, keep the grounding the way it is, or better to convert back?
Cheers,
Scot
Joe Schlosser
Generally to convert to negative ground you just switch the Battery wires and repolarize the generator. That is about it.Many descriptions for doing this on the forum
Cars of this age do not have a lot of other electrics that need to be changed. Tack is manual, if electric fuel pump then check if it needt to be changed (many work either way)
Petronix only runs one way. They make units be both pos and neg ground.
It sounds like you have a general ground corrosion issue with the car or someone just improperly did weird wireing over the years.
CJD
Yes...these are very easy to convert one way and/or back again! The negative conversion merely makes it much easier if you plan to add a bunch of updates, like an alternator, cooling fan, radio, cell chargers, etc. So it's pretty much what you prefer...assuming you don't already have an alternator??
S
scotdail
An alternator came in the trunk, but the generator is still in the car. Not sure if the generator is for Pos or Neg though. Still in the original box, so sure I can find out!
Also came with a set of Strombergs in the trunk :joyous:
CJD
Actually, the generator can be either. It only depends how you jump it on installation. It sounds like the PO had plans to switch to the alternator, which requires the negative ground. The advantage to an alternator is it produces much more power. The original generator is pretty maxed out with the headlights and heater running. If you plan to add fans, radios, or much else, then the alternator conversion is prudent, and therefor, negative ground with it.
TR3driver
Great Pumpkin - R.I.P
Just to amplify what others have said: Your various problems don't appear to have anything to do with the polarity conversion. So whether to take the extra step of switching back, or not, is up to you and what you like. To convert (assuming the car is original otherwise), you just swap connections at the battery, coil and ammeter; then repolarize the generator and you should be good to go. If you should have a factory or dealer radio installed, there will be a switch or plug that you move to change it's polarity. The Pertronix will have to be removed or replaced with a positive ground unit (which also gets wired differently, check the Pertronix instructions for it).
The headlights and front turn/marker lights should have separate ground wires, that run from the bulb holders back to ground clips just behind the horns on each side. Those clips often break and/or corrode until they no longer function, so that's one of the first places I would check. Remove the screw and make sure there is clean metal underneath, a spot of Vaseline or silicone grease will help prevent future corrosion. Paint does not conduct well!
Red/blue is not an original color AFAIK; perhaps it is red/green? Normally, one of the red wires would be linked to the RG by an in-line fuse holder, which should be clipped to the inside of the dash just below the instrument panel.
Likely you've noticed by now, the wiring diagrams given in many places (including the factory workshop manual and Bentley reprint) do not correspond well with the later cars. This is the best diagram I know of, but still has some shortcomings (mostly not showing many of the ground connections)
S
scotdail
Sorry, I meant alternator. :smile: My understanding is you can buy them in either configuration.
S
scotdail
Good info Randall, thanks. At 20 and 16, you see UR (blue/red) and UW (blue/white). Those are the wires I am referring to. In my car, the UR is currently connected to the R (red) wire going to 37.
I like that diagram much better than my Advance Auto Wire version! Can you also share the legend that goes with it?
TR3driver
Try this link, should give you the owner's manual in PDF. I can post the image later, but can't do it just now
https://drive.google.com/open?id=0B2H2NJt34OffNjQ4MTkyNjItZTVmYi00M2U2LWJhYWUtMjEyZDgxMzUyNzUw
Positive ground alternators do exist, but tend to be rare and expensive. I'd have to say that seems the least attractive alternative, to me. The stock generator actually isn't all that bad, treated with a bit of understanding and without adding any power-hungry accessories (like electric radiator fan). I drove that way even with an electric fan (and with the earlier 19 amp generator) for several years.
I did finally do the conversion, after the original generator finally died. This one was $50 at Rockauto :smile:
S
scotdail
.... and that is the one manual I had NOT been able to find online for free yet. You guys are great!
Scot
M_Pied_Lourd
Your pertronix ignition would have to be negative ground as well if the conversion has been done.
Edit...I see that Randall has already pointed that out! Doh!
Cheers
Tush
S
scotdail
Cheers
Tush
No worries! I see one of your flock is a relatively distant cousin to mine (TS65477)
TR3driver
Scot
You might want to browse through here, there may be a few others that would be at least entertaining:
https://drive.google.com/open?id=0B2H2NJt34OffMDVmOTZlZWItYTcyMy00ZDhkLTliOWEtOWU1OWRhNDZhYmRl
And I still have a huge pile of stuff to scan. Bought another one just yesterday, to add to the pile.
BTW, I'm still looking for the first page of the June 1964 amendment to the Spare Parts Catalogue. If anyone has it, please let me know.
S
scotdail
Update - I have sorted the headlights, and have them working properly now. There are too many black wires coming out of the front end, and one was a power hooked to ground for the headlights. Still trying to sort the front turn signals and horn. Rear signals work, front do not. Getting closer! Breaking out the ohm meter.
SU carbs are running rough at idle, but good once warmed up. The car came with a rebuild kit. Thinking of rebuilding them or the Strombergs in the boot!
CJD
All those non-working items are grounded to the same little grouding blocks (2) on the lower, inside fenders. I’d start with those grounding blocks...
S
scotdail
Yes, the grounds are good, I cleaned them all up. I suspect it just may not be connected properly now...
STeve 1958
I fixed most of the same problems you have by simply tightening up all the plugs under the hood.
If you want to have a modern radio you will want neg. ground. That and the electronic ignition.
"Triumph with electrical issues" is a redundant statement as is "Triumph with oil leak".
STeve 1958
Randall
I see that your float bowl is completely dry and there is a hose on the second tube. (overflow I guess)
I don't have that hose and my float bowls are always a little moist. Where does that hose go?
TR3driver
Randall
That second tube is the float bowl vent. Originally, it had a short length of rubber line and a 90 degree bend in hard line, with the other end of the hard line butted up against the mesh in the air filter.
Since I'm running paper element air filters from a TR4A (which IMO offer MUCH better filtration than the original wire mesh rock catchers), I just put some long rubber tubes on both bowl vents, and routed them down near the RH frame rail. Hopefully, that is keeping too much dirt from getting into the bowls through the vents, and if I do have a problem with a bowl overflowing, the overflow will get routed down away from the exhaust manifold.
One of my "back burner" projects is to make some housings to accept modern paper element filters, and add a fitting for the vent (so it gets clean air from inside the filter). So far, I've got a pile of parts in a bin :smile:
RedTR3 TR2/3/3A TR3 Ground conversion question Triumph 4
jfarris TR2/3/3A Ground location for center panel lights 56 TR3 Triumph 5
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
S TR2/3/3A ground strap on a tr3 Triumph 21
jfarris TR2/3/3A 56 TR3 - Convert to Neg Ground or Leave As Is Triumph 18
F TR2/3/3A Horn Button TR3 Trafficator; Bad ground? Triumph 4
NutmegCT TR2/3/3A TR3 battery ground cable Triumph 8
O TR2/3/3A TR3 Ground Strap Triumph 6
T TR2/3/3A TR3 engine ground Triumph 9
S TR2/3/3A tr3 relative ground hight Triumph 5
S TR2/3/3A tr3 ground clips Triumph 9
martx-5 TR2/3/3A TR3 Engine Ground Strap Triumph 12
S TR2/3/3A tr3 battery with positive ground Triumph 8
S TR2/3/3A chassis ground on a tr3 Triumph 9
R TR2/3/3A TR3 rack and pinion kit problem... Triumph 11
