Door hinge repair
AngusSaunders
Seems I hit a snag. The lower passenger side door hinge was working stiff and somewhat odd. Well the pin was sheered and quite frozen to all the aluminum parts, not sure what was holding it together. I have soaked it in penetrant and tried to use heat to remove the pin parts but no luck so far. Has anyone had any luck repairing these hinges? There is a guy on ebay that refurbishs these hinges, has anyone used his services? A couple of more questions if I may. Are the passenger side and drive side hinges the same. Are all of the 3000 hinges the same. Thanks for listening to my tale of woe.
There are some differences between early and late models. Side to side are same. I have several spares if you need one. Probably $25 each and shipping.
Marv
John Turney
Nominally, all the hinges are the same, but that's like all the fenders are the same. There is some variation between them. I switched my lower right (hardly worn) with my upper left (the most worn), and although they "fit", some fiddling was required to get the doors to fit nicely.
M TR2/3/3A TR3 door hinge repair ??? Triumph 3
S TR2/3/3A Stubborn door hinge screws in “A” Post Triumph 6
wangdango BJ8 door hinge milling? Austin Healey 2
K Wanted W.T.B. Late 100 BN1-BN2 DOOR HINGE Austin Healey Classifieds 0
BoyRacer Door Hinge rebuild Austin Healey 3
W TR4/4A Door Hinge Triumph 8
Boggsy64 MGB Crack of doom - Door hinge question MG 3
M Jaguar LH front door hinge spring Jaguar 6
CanberraBJ8 door hinge plate Austin Healey 8
HealeyDave 100 door hinge question Austin Healey 4
wangdango BJ8 door hinge pillar plate redo Austin Healey 7
Kleykamp TR2/3/3A TR3 Door hinge hole pattern??? Triumph 12
L Door Hinge Pin Austin Healey 10
K sprite door hinge kit Spridgets 2
HealeyDave Door Hinge Question Austin Healey 4
G TR2/3/3A TR3 Door Hinge Problem Triumph 4
Jim_Gruber PosiDriv Bits for Door Hinge Screws Spridgets 11
B TR2/3/3A TR3 Door hinge removal fun! Triumph 5
D Glovebox Door Hinge Lotus 4
jerrybny Lower door hinge Triumph 2
TexBug Stripped door hinge screw removal? Spridgets 4
B Door Hinge Screws [Again] Spridgets 14
kc_doyle sagging door hinge Triumph 4
T Door Hinge Screws Help Please Spridgets 7
B Door Hinge Pin Austin Healey 2
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 5
A 100/6 BN4 Door Lock Austin Healey 15
SpeedyG TR4/4A Door window regulator spring Triumph 5
SpeedyG TR4/4A Interior door handles and escutcheons Triumph 9
AngliaGT Wanted Two inside window handles & Regulator for Driver's Door - '67 GT MG Classifieds 6
AngliaGT MGB-GT WANTED: Driver's Door Regulator + Two (2) interior handles. MG 1
D Older door panel clips Restoration & Tools 4
BoyRacer Door Skin Removal Austin Healey 6
Southwarks TR2/3/3A TR2 door help! Triumph 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
D Top Door rubber and fuzzy seal Spridgets 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
D MGB Older style door pulls MG 0
V Door Seals Austin Healey 8
Bayless Door seal question Spridgets 3
Donald1107 TR2/3/3A Door hinges Triumph 14
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
D Door Seal Fit Austin Healey 18
D For Sale BT7 interior door cards - new ! Austin Healey Classifieds 0
