TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A?
karls59tr
Reason I ask is that my TR3 fuel gauge has an open circuit but I have a good TR4A fuel gauge. Is this swap doable or what what would I need to do to make it work? Also was there a difference between the TR4 gauge and the 4A gauge?
TR3driver
Great Pumpkin - R.I.P
You would need a voltage stabilizer, and a tr4 sending unit. I'm not sure offhand, but ISTR the 4A gauges each had their own bulb for illumination, so you would probably want to wire that into the existing dash lights.
Otherwise, I think it would work. Might need to tweak the calibration a bit for different fuel tanks, but it would probably ly be OK as-is.
Early TR4 fuel gauge looked different than the later ones (curved glass vs flat plus the shroud over the needle pivot). Seems like maybe there was a further cosmetic change for the 4A, but not certain offhand.
K
karls59tr
In regard to 4 and 4A gauges in terms of internal electrical they would likely be the same. Correct? Could the TR3A sending unit be modified to work with the 4A gauge? I have a friend that is very good at everything electrical working on the conversion but he is not familiar with these Brit gauges. Is there a big difference in the resistance of the two sending units?
Sarastro
You might try taking your TR3 gauge apart and seeing what's wrong with it. If it's like the TR4 gauge, it's easy to disassemble and it uses a heated bimetallic strip, not a conventional meter movement. It might just be that the wire has come loose from a terminal.
Yes, the TR4 gauges have individual lamps.
TR3driver
Tr3 gauge is completely different inside than Tr4. Still might be repairable, though. Two electromagnets, wound with very fine copper wire and a big resistor.
Barney Gaylord put up some very nice pages on testing and repairing an MGA fuel gauge (which is very similar but slightly different resistances). Sorry, I don't have the link handy. Search for "MGA with attitude".
TR3driver
Yes, that's the one I meant.
Thanks, David.
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
KVH TR4/4A Fuel Gauge TR4A Triumph 18
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
D TR4/4A TR4A clogged fuel filter Triumph 13
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
R TR4/4A Tr4a fuel cap o'ring Triumph 7
R TR4/4A Corbin clamps of fuel lines Tr4a Triumph 5
R TR4/4A restored my tr4a fuel tank Triumph 1
T TR4/4A Close up pics of your TR4a fuel lines Triumph 5
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
Stinger TR4/4A TR4A Fuel Pump Question Triumph 2
RJS TR4/4A TR4A Fuel Pump Removal Triumph 9
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
Stinger TR4/4A TR4A Fuel Pump Leak Triumph 6
R TR4/4A TR4a fuel line, new Triumph 6
P TR4/4A TR4A Electric Fuel Pump Installation Triumph 7
T TR4/4A TR4A Fuel Starvation problem: Dry float bowls Triumph 8
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
KVH TR4/4A TR4A Fuel Pump Problem? Triumph 4
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
W TR4/4A TR4A fuel starvation. Triumph 4
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
