alternator eater
Sopwith_Camel
well Shaggy ate two alternator in two days. i have been having starting issues, and i did have an issue a few weeks ago where the radio flicked off on each of the 12 speed bumps to get to my house.
please advise
the long story. big summer rally 8 hours away. I had a breakdown where the point closed up and the brown wires under the dash were hot to the touch. i re ran new white wires out to the coil because im trying to get the tach to work.
first day of the rally full tank gas bright sun car was very wet and it was hesitant to start the starter moter, ran well maybe need the points adjusted a little. about a half hour out i lost power pulled in to a gas station checked the points, the gap was good. the car started so i decide to press on it ran smooth till south of trondheim. i got rattled going through some construction. and the radio cut out. and the gas gauge started to move down quickly. so I pulled off for gas but it only took 16 liters but then it wouldn't start nothing to the starter sylinoid. so I push started it and turned for home. but got about a half mile. when i lost all power. called the tow truck. took the car to a mechanic who diagnosed the alternator. so i hoped on the train home. (five hour wait) got in at 23:15 and realized i had no tools to pull the alternator out of the mgb. texted my buddy down the street and he showed up at 8:00 with a full set of imperial tools.
I pulled the alternator out of the B gaither a selection of imperial nuts and blots. and hoped on the 10:30, i got back to Shaggy at 14:40 and popped in the alternator after swapping the pullys. about a 2 miilamiter offset. but it put out about 11.8 so I headed for home, shaggy ran strong. but at the wait for the construction site it started bucking . but stayed running, long down hill till i found a site to pull over. but the engine lookd to be running smooth the belt looked ok. had the road to my self heading in to trondheim passing along traffic jam heading south. but just north of Trondheim heading up a fast hill i lost power and that was it. flat bedded home.
nomad
If you are burning up wires you have a short. If things just stop you might have just a bad connection. Ice pick continuity testers are cheap.
Kurt
Sopwith_Camel
Sopwith_Camel
i ordered a new wireing harness. after 50 years its pretty bad under the dash. I have too many replaced wires.
Bayless
Probably a wise decision.
Sopwith_Camel
Sopwith_Camel
just too many wrong coloured wires. patched in. and i think my skill set is up enough to handle it.
dklawson
I agree with Kurt that your car has to have a short somewhere. The brown wires shouldn't get hot in normal use.
11.8V out of an alternator says it is not charging. Does the red charge warning light on the dash work? The warning light is more than just an indicator, it is a part of the charging circuit.
Sopwith_Camel
Sopwith_Camel
ahhhhh. I forgot that mine is North american car and has a different harness on this side of the pond. what is the big plastic block under the dash with a big connector. its on the fire wall. the new harness dosent have any thing for it. I recognizes the rest of the harness. and ive been labeling all morning.
Sopwith_Camel
Sopwith_Camel
thanks yes i have colourd it in photoshop and printed it.
dklawson
In the picture some text can be seen behind your fingers. What does that say?
I also see a bunch of (as many as 9?) colored wires going into the plug on the box. Can you list the colors? You may need to clean them a bit to confirm there are no secondary colored stripes on the wires.
Sopwith_Camel
Sopwith_Camel
not much time tonight ill try again tomorrow.
dklawson
When you get a chance, do try for a picture where the text on the box is not obscured and one that shows each of the wire colors going into the plug.
Your signature says that this car is a '70 Spridget. I have looked at the diagrams in the PDF I linked earlier. I did not see anything like what is shown in your picture. I was also surprised by all the yellow wires in your picture. Yellow wires are not common. I have usually seen them on schematics where the car has an overdrive which would not be the case with a Spridget. The box's plug also appears to have a purple/black wire. Purple/black is for the horn circuit. That further confuses me.
Sopwith_Camel
Sopwith_Camel
what i know of the car is it has a 67 dash and gauges. the tach is a 72 in the larger can of the 67. the engine is from my 72 but it might not have been original in that since that car had race paint when i bought it.
when i bought my mgb finaly a car that left the factory together wow was i wrong. back to the spridget Im thinking just putting in the european harness and patching to the rear harness. i wish it was june this is not a project for september. ahh with good sunlight and time to do the task, the box says "Pektron"IMG_7514.jpg
dklawson
...the box says "Pektron"
Perfect! I was able to Google Pektron and MG and found the thread linked below. In the link, read post #4 by Norm Kerr
https://www.mgexp.com/forum/mg-midget-forum.3/pektron.2059173/
Succinctly, it sounds like you need to change Shaggy's real birthday to 1974 or at least add '74 to his mixed pedigree for the body/wiring.
It appears the Pektron box was also used on the '74 MGB (probably others as well).
I like your idea to use the European harness and splice it into your existing harness as necessary. It doesn't sound like the Pektron unit is something I would want to get operational but that's just me.
EDIT: I also found a BL tech bulletin about the box. If you are really into originality (Shaggy doesn't sound like it! ) you might be able to get the Pektron box working again using the info in the PDF linked below.
https://www.triumphexp.com/article/mgb/TSB/TSB 14 Pektron Seat Belt Interlock.pdf
Bayless
Good work Doug. 1974 was a bad year. Wife's '74 VW had a similar device that had failed when we got it. Fortunately I was able to completely bypass it by moving a single wire on the fuse box. Hope a similar fix works for Shaggy.
Sopwith_Camel
Sopwith_Camel
wow thanks.
yeah i think i should pull it out and put in the simpler european harness.
its going to be a tough weekend.
my next car has to be a matching numbers car.
steve
Sopwith_Camel
Sopwith_Camel
it lives!! ok its running. i can get it to winter storage.
i did a test drive last weekend and made it 30 meters and the wire to the fuel pump died. i hated the speed bumps on my street before now i realy hate them.
ok so I have one speed of winsheilde wipers. and i have no brake lights because the switch is bad......again. and I think the issue with the revers light is at the switch too.
I put the raido on the switch for the dash lights and the light switchs are some jaguar ones i had lying around.
the left right marker reperters . idont know how to hook up they need little cylinders on the back to the dash to clip into. and the dash lightes (leds) arent realy working.
the funny starting issue turned out to be a bad ground strap. engne to body.
yes im done for the season snow is on the mountain on the far side of the fjord.
steve
dklawson
Great !
Hopefully your winter storage space is heated so you can sort out the wiring issues over the winter.
Sopwith_Camel
Sopwith_Camel
nope its just a barn. i stick it in in the fall and I get it out in the spring.
steve
Sopwith_Camel
Sopwith_Camel
steve
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
J MGC Lucas alternator/regulator MG 3
K TR2/3/3A Revington alternator heat shield. Triumph 0
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
