Vented Battery
HealeyRick
While swapping the battery out of the trunk of my Chrysler 300C SRT8 to use temporarily in the Healey (long story), it struck me the Chrysler battery is vented to the outside of the car. With many folks doing safety upgrades to their Healeys over the years, I've never heard anyone mention venting their battery outside the trunk. Anyone doing it?
Keoke
RICK :
I see no reasn to vent when sealed batteries are readily available
RAC68
Hi Rick,
Keoke has the point, non-water based batteries like the Optima are both sealed and can even be mounted upside down with no issues. What seems odd is that the Healey originally had a water-based battery secured inside a closed boot with no extra consideration for escaping liquid from overfill or overcharge. Although many of us did install a battery tray, it was not a standard part as was the soft vinyl cover that was placed on top of the battery.
I must assume they saw little need for venting as the battery was quite separated from the car's major heat source (engine) and the enimic generators back then posed less of a potential for overcharging.
Just thoughts,
Ray(64BJ8P1)
Rob Glasgow
On my BT7, the trunk area is not really sealed. There are openings on both sides of the rear bulkhead that would acts as a vent from the trunk to the rear seat area. I was never sure why they left the gap there but maybe it was to vent the trunk.
RAC68
Rob,
Yes, I forgot about those openings and never saw a functional purpose for them ... other then some assemblo or construction reason. I have them on my BJ8 so they are probably present in all big Healeys. Assuming that the amount of battery vapor is small, these openings could be sufficient to allow the evaporation and clearing of any battery moisture.
Good point,
Ray(64BJ8P1)
British_Recovery
Bronze
The Bakelite battery trays are pictured in the factory parts books as standard, but since they were fragile, few survived in good shape. Most often replaced at the time with a board !
RAC68
Hi Bob,
They were not standard on BJ8 but may have been on earler models. I know this as one who purchased his BJ8 new and purchased the tray some years later.
Hi Bob,
One interesting thing about the battery mount is its length and width. When initially replacing my original battery with a new wet cell, the battery was shorter and I needed to install a piece of wood between the angle brackets to support the battery. Over the years, batteries continued to reduce in size and I created a battery box with cover to satisfy the purpose and present a more consistent image with the original look.
Ray(64BJ8P1)
AUSMHLY SU Damper Cap Vented vs Non-Vented Austin Healey 25
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
T vented gas caps? Spridgets 8
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
J Vented cap on damper piston on top of BJ8 carbs. Austin Healey 13
B Need vented gas cap? Austin Healey 9
Nunyas Sealing a vented oil fill cap MG 6
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
