Results 1 to 6 of 6
Thread: Valve cover breather cap?
  1. #1
    Join Date
    Jan 2007
    Location
    Winnipeg ,Manitoba,Canada
    Posts
    2,094
    Thanks Thanks Given
    97
    Thanks Thanks Received
    2
    Thanked in
    It occurs to me that I have never cleaned out the breather cap. Looks like wire mesh of some sort. What's the best way to clean it out...soak in solvent?
  2. #2
    Great Pumpkin - R.I.P TR3driver's Avatar
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,552
    Thanks Thanks Given
    8
    138
    Thanked in
    Re: Valve cover breather cap?
    Randall
  3. #3
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,780
    Thanks Thanks Given
    11
    18
    Thanked in
    I think the book does say to rinse it in gasoline but I don't see why most solvents wouldn't do as well. Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  4. #4
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,656
    Thanks Thanks Given
    6
    51
    Thanked in
    Nothing wrong with using high-test gasoline for cleaning...or is there?!?
    John
    1955 TR2
  5. #5
    Obi Wan LarryK's Avatar
    Join Date
    Mar 2007
    Location
    Millstadt, IL
    Posts
    2,129
    Thanks Thanks Given
    27
    Thanked in
    Some solvent residue will cause damage if breather isn't totally dry. Fuel is fine, drys quick.
    Larry K
    58 Jag 3.4 MK 1 auto under restoration, 57 Jag 3.4 MK1 manual (parts car),
    03 Cooper S, 2011 Cooper S Countryman, 2011 Land Rover LR4 HSE LUX, 1964 Valiant V200
    Also had , 68 Cortina 1600E, 64 Spit 4 & 80 1500, 73 GT6 3, 71 XJ6, 79 XJ6, 86 XJS V-12, 53 XK120 OTS.
  6. #6
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,780
    Thanks Thanks Given
    11
    18
    Thanked in
    Quote Originally Posted by CJD View Post
    Probably not since they took the lead out. There was a time when it was so commonly used that mechanics were getting lead poisoning. I quit using it 50 years ago and find odorless mineral spirits a more pleasant and perhaps safer substitute. Granted it doesn't dry as quickly but I don't see that as a problem.
    Tom
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
