Results 1 to 4 of 4
Thread: Rebuilding Tiger window regulator question
For Sunbeam Tiger, Alpine, etc.
  1. #1
    Join Date
    Aug 2019
    Location
    Madison, Wi
    Posts
    4
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    I’m rebuilding the drivers side window regulator on a 66 Tiger. Have the regulator repair kit from Sunbeam Specialties. The question I have is about how the torsion spring in the window crank housing holds the “star gear” to the plate on the shaft that the window handles slides onto. When I drilled out the rivets and removed the shaft housing I could hear the spring unwind. Other regulators I have worked with just have the window handle directly attach to the small gear on the regulator.
    I’m looking for some guidance on how to hook that spring back up. The directions provided by Sunbeam Specialties does not mention this at all.
    Thanks in advance!
  2. #2
    Jedi Knight Bob Claffie's Avatar
    Join Date
    Feb 2003
    Location
    Dalton Mass
    Posts
    958
    Thanks Thanks Given
    3
    Thanked in
    Re: Rebuilding Tiger window regulator question
    A few years ago when i was playing with some Tiger doors the instructions I had was adamant about "DO NOT LET THE SPRING UNWIND". You may just be out of luck.
    Thank goodness the MG is finally gone, replaced by another Corvette
  3. #3
    Join Date
    Aug 2019
    Location
    Madison, Wi
    Posts
    4
    Thanks Thanks Given
    Thanked in
    Thanks, for the reply. Saw a different thread, I believe in the triumph forum, where they just put it back together without bothering to wind the spring. Did that and it seems to work fine when out of the car. Will see if it works when I install it in the door.
  4. #4
    Join Date
    May 2013
    Location
    southwest Ohio
    Posts
    1,508
    Thanks Thanks Given
    25
    Thanked in
    Try putting the winder in the full up position and hooking backup, then it should rewind as lowered. It's there to take some of the window weight so the crank operates easier.
Tags for this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
