TR4/4A 3rd/top gear syncro hub
bammons
Well this is a little embarrassing but somehow I managed to not mark the direction the 3rd/top gear syncro hub goes on the mainshaft of the transmission. One side of the hub is more extended than the other side. There is a flat "contact" area on the less extended area. In looking at it I think it goes on with the more extended hub facing the rear (or 1st gear) and the "flat" area facing the input shaft but I want to be sure. I know most of you don't have a opened transmission laying around but if anyone knows I would appreciate some input. Most items I can tell from either the Haynes manual or the factory manual but I really can't tell by the pictures in them.
titanic
I underlined this from the Haynes manual, page 115 #19 that pertains to the reassembly of the mainshaft and the 3rd/4th gear synchro hub. "The protruding end of the hub must face the front of the mainshaft".
Berry
B
bammons
Now I am really embarrassed. I am actually using a TR250-6 Haynes manual but it is same page and item number. I don't know how I missed it but Thanks Berry problem solved.
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
S TR2/3/3A getting the circlip off 3rd gear Triumph 9
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
Joe Reed MGB Dropping out of 3rd gear... MG 2
R TR6 Gearbox slips out of 3rd gear Triumph 14
RAC68 Third *[3rd] Brake Light Austin Healey 11
K TR2/3/3A 3rd brake light question Triumph 3
Gray_Cat Socal Norton Owners Club Annual Meet, Ride & Show November 3rd, 2019 British Motorbikes 0
TRclassic3 TR4/4A A type OD working in 3rd but not in 4th Triumph 5
1 MGB 1966 MGB hard shifting into 3rd MG 1
T 3rd brake light again! Austin Healey 29
T TR2/3/3A 3rd. brake light set up Triumph 12
T 3rd brake light or LED's Austin Healey 28
D license plate lights, trunk and 3rd stoplight out Jaguar 4
Johnny Bad 3rd member for an OD transmission. Austin Healey 0
A TR4/4A TR4 Slips out of 3rd gear Triumph 5
T Hail Mary on 3rd gear syncro Spridgets 3
K Up-date on Blinking 3rd Brake Light Triumph 1
8 Lost 3rd & 4th Gear ?? Triumph 18
T BJ7 -lost reverse, then 3rd/4th - advice please! Austin Healey 10
Johnny 3rd and 4th gear baulk/rings Austin Healey 16
R gear shift stick movement in 3rd gear question Spridgets 46
Michael Oritt Lime Rock Park July 3rd Racing 4
G 3rd time is a charm Spridgets 0
J Downshifting from 3rd to 2nd Austin Healey 7
T I like 3rd gear!! Triumph 29
bcbennett Heater Assembly 3rd bolt Triumph 1
MadRiver No O/D in 3rd Austin Healey 6
tahoe healey in 4th and 3rd/OD Austin Healey 3
PAUL161 MGB-GT Britts at the Battleship, Wilmington, NC Nov.3rd MG 8
roofman 3rd brakelight installed whatcha think? Triumph 45
S 3rd gear grind Triumph 7
TR4 June 3rd British Car Show in Perrysburg, Ohio Triumph 5
B Cheap 12 light LED 3rd brake light Triumph 3
H 3rd Brake Light Austin Healey 8
kcbugeye1275 3rd brake light Spridgets 12
ChrisS What not to do at 6800 RPM in 3rd gear... Spridgets 31
tony barnhill theAutoist 3rd Annual Christmas Sale Sunbeam (Rootes) 0
ChrisS 3rd Gear Assembly Spridgets 6
zimmy sticks in neutral?....3rd gear slip....... Spridgets 3
Brosky 3rd Brake light - windscreen ideas for roll bar?? Triumph 25
tony barnhill Banjo 3rd Member MG 5
W Well I still have 3rd & 4th gear anyway! Triumph 3
D Mainshaft 3rd gear end float MG 0
jerrybny RPMs in 3rd Triumph 1
tahoe healey 3rd gear screamming Austin Healey 9
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
