TR6 Rust on the floorboards
Rudy1974
Hi All. First time posting on this forum. I bought a 1974 TR6 a few months ago and really enjoy driving it and learning about the car. The brake master cylinder had been leaking brake fluid onto the driver's side floor and the floor is very rusty now. Still very solid but covered in rust. Any suggestions on what to put on the floor to prevent the rust from eating my floor away?
poolboy
You should thoroughly rinse those areas with water, making sure all the brake fluid is out of there before treating the area. When the rinse water remains clear you've done a pretty good job of flushing out the brake fluid.
You'll find rust treatment products at retail auto parts stores...
RJCOX
Let me note, replacing a floor pan is a pain in the butt. Take care of it ASAP. Leave no rust behind.
Dad has been using Rust Reformer (Wal-Mart, believe it or not). It's rattle-can variety and is said to convert rust back to metal or turn it into some form of primer. I used a can on the inside of a rough fender to keep it from getting worse until I could really get to it. The primer it turns into isn't exactly sandable, but it seemed to do the trick.
I've heard loads of good stuff about POR-15. It bonds to rusty metal and stops the rust in it's tracks (if the reviews and website are to be believed). It does smell bad, is a bear to clean up, and hates UV.
Regardless, get rid of the rust, paint it up, keep it dry, or get it dry if it gets wet inside.
My 60 was left wet. One seat frame and springs, one floor pan, one sill and the prop shaft tunnel, all had to be cut away and replaced. Now, the damage didn't happen overnight, but it did happen.
Just my $.02
Ron
Sarastro
I wasn't aware that just water would clean up spilled brake fluid. If it were me, I'd wash it well with a strong detergent, anyway, to get rid of any dirt or oil that is there, as well. Then, after drying it thoroughly, apply any of the usual products: POR15, Eastwood rust encapsulator are two I know of. Also, I use a lot of rust-converting primers, available various places. Eastwood is one. If you use the rust converting primer, the surface should also get a coat of paint; Rustoleum is fine. That should stop any rust progression.
Also, take a look at the passenger side. If the driver side is rusting, the passenger side also probably is.
Finally, maybe before doing all this, fix the master cylinder. Leaking brake fluid is a mess, and you really shouldn't drive a car with a faulty brake MC.
STeve 1958
Definitely fix the brakes first as the brake fluid will strip the paint right off. You might also put down a layer of KilMat to quiet the car down and insulate against heat.
TRMark
Bronze
Stab the forward outer corner of the floor pan with a screwdriver to check how advanced the rust is. Found to be very informative on my TR4.
frankenstang57 rust in the floorboards... Triumph 0
5 BJ7 Boot Rust-Through Austin Healey 13
E Rustproofing and Rust Austin Healey 2
1 General Tech Rust Proofing Triumph 7
ROARRR For Sale 1930-40's AUSTIN 10 SALOON! straight, good glass, no through rust, very complete Austin Healey Classifieds 0
D TR6 Rust and hesitation 71 TR6 6 Triumph 9
D Removing the last rust from pitted steel Restoration & Tools 11
algot1901 My Prefect in her B-Day Suit and playing with rust-Flash! Other British Cars 19
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
SteveTheBrewer Spitfire More rust repair Triumph 1
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
R Rust in Block? Help needed! Austin Healey 6
F TR2/3/3A Rust under flanges Triumph 7
D MGB Stopping rust under patch panels MG 1
P BJ8 Frame Rust Options? Austin Healey 14
Rut TR4/4A Rust for sale Triumph 2
S TR2/3/3A door blistering with rust Triumph 4
J TR2/3/3A inner sill rust prevention Triumph 1
Chuck9482912 Rust in new fuel filler neck Austin Healey 4
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
Rut TR4/4A Rust bucket, save, sell, or part out Triumph 15
D General TR Fluid Film Rust and Corrosion Inhibitor Triumph 8
J TR2/3/3A Flash Rust Triumph 21
E For Sale 1955 Austin Healey 100 /4 rust free project car Austin Healey Classifieds 3
Lukens Outer rocker showing "rust" Restoration & Tools 11
R TR2/3/3A Good Rust Remover Triumph 14
Rut TR4/4A Rust free TRs Triumph 4
69MGC MGC Cut out the Rust! MG 9
KVH General Tech New Camshaft Has Rust Triumph 7
JimLaney Engine rebuild - how critical is rust? Spridgets 3
B 1960 TR3 With rust in cylinders Triumph 7
Rut TR4/4A Rust removal by Electrolysis Triumph 9
H Bugeye seat pan rust and possible repair Spridgets 2
Popeye TR4/4A Seat frame - rust "repair"? Triumph 1
Keoke Cars keft behind turned to rust by mother nature Austin Healey 8
bugedd Rust advice Spridgets 24
Sopwith_Camel Compressed rust Jaguar 1
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
C TR6 New rust discovered Triumph 10
S Rust treatment recommendation? Austin Healey 5
maxwedge5281 who buys rust buckets? Austin Healey 16
nevets "RUST The longest War" Austin Healey 5
bugedd Why the rust? Spridgets 15
catfood Self tapping screws an rust prevention Austin Healey 10
Chuck9482912 Rust holes in engine of Austin Healey 3000 Mk II BJ7 Austin Healey 22
S Rust Bubbles Spridgets 17
G Rust repair needed for 66 AH 3000 Restoration & Tools 4
B MGB-GT Best rust repair person/shop on the East Coast? MG 2
T Sprite rust Austin Healey 10
MG Lily Best way to safely remove minor surface rust? Restoration & Tools 5
