Results 1 to 13 of 13
Thread: Horn question follow up
  1. #1
    Obi Wan longbridgehealey's Avatar
    Join Date
    Apr 2006
    Location
    The Villages, Florida
    Posts
    2,476
    Thanks Thanks Given
    2
    Thanks Thanks Received
    2
    Thanked in
    Why use a relay for horn? I have installed a Charlie Hart seven fuse unit, with one fuse dedicated to the horns. Is there any reason to install a relay unit in the horn wiring? My new horns came with one, but Iím not sure I need it.
    Once again, many thanks!
    Larry (again)
    Never tease an old dog, he might have one bite left.
    Ignorance is curable, stupid is forever.
    Women and cats will do as they please, and men and dogs should relax and get used to the idea.
  2. #2
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,706
    Thanks Thanks Given
    86
    139
    Thanked in
    Re: Horn question follow up
    Quote Originally Posted by longbridgehealey View Post
    Why use a relay for horn? I have installed a Charlie Hart seven fuse unit, with one fuse dedicated to the horns. Is there any reason to install a relay unit in the horn wiring? My new horns came with one, but I’m not sure I need it.
    Larry (again)
    Sounds like needless complexity.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  3. #3
    Join Date
    Apr 2006
    Location
    Posts
    2,476
    Thanks Thanks Given
    2
    2
    Thanked in
    It did to me too, and I was hoping you would agree👌. And you were right, there was a bare wire grounding the system on the horn circuit, which was not in the trafficator.
  4. #4
    Yoda Michael Oritt's Avatar
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,238
    Thanks Thanks Given
    6
    23
    Thanked in
    Not using a relay means that every part of the circuit(s) must carry the full amperage load, from the power lead to the horn button all the way to the horn itself. i don't know what kind of horns you are using but loads of 5 to 15 amps per horn are common, and wire to carry that load is relatively heavy--I'm guessing that 14 to 16 AWG is probably what would be specified.
    OTOH using a relay allows the use of lighter wires on the circuit that activates the relay as that wire will only carry the load required to actully activate and hold the relay closed, which might be only a couple of amps. And if the relay is located close to the horn(s) the run for the heavy wires can be kept short.
    Best--Michael Oritt
    1954 Austin-Healey 100 Le Mans
    1958 Elva Courier (FOR SALE)
    1959 Elva MK IV Sports Racer
    1961 Ginetta G4
  5. #5
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,706
    Thanks Thanks Given
    86
    139
    Thanked in
    One could argue, in the case of the horns, the wires are used very seldom, and for a very short interval - too short to heat up.
    Also there's a separate wire for each horn. Mine mainly get used when I tilt the driver's seat forward.
    Steve Gerow
    Altadena, CA, USA
  6. #6
    Yoda GregW's Avatar
    Join Date
    Jan 2005
    Location
    Santa Monica, CA
    Posts
    7,690
    Thanks Thanks Given
    20
    Thanked in
    Quote Originally Posted by Michael Oritt View Post
    The fused wire for the horn is as short as it can be going from the fuse straight to the horn. putting a relay in that line makes no sense. The horn button on the steering wheel is for the ground wire.
  7. #7
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,238
    Thanks Thanks Given
    6
    23
    Thanked in
    It doesn't matter whether it is the ground or the hot wire--if current flows through it the considerations are the same.
    Best--Michael Oritt
    1961 Ginetta G4
  8. #8
    Join Date
    Mar 2009
    Location
    ky
    Posts
    145
    Thanks Thanks Given
    Thanked in
    Use a slow blow fuse.
  9. #9
    Join Date
    Jun 2001
    Location
    Lusby, MD, USA
    Posts
    3,238
    Thanks Thanks Given
    6
    23
    Thanked in
    Or use this--nothing needed at all:
    Best--Michael Oritt
    1961 Ginetta G4
  10. #10
    Jedi Warrior healeyblue's Avatar
    Join Date
    Apr 2012
    Location
    Lafayette, LA
    Posts
    738
    Thanks Thanks Given
    2
    5
    Thanked in
    I agree with Michael. If the horn did not use a relay then the wire for the button would have to be a larger gauge (even if it is on the ground side) and there is limited room for the wires to run up the traficator tube as it is. Adding girth for a larger wire only worsens the situation.
  11. #11
    Great Pumpkin Keoke's Avatar
    Join Date
    Apr 2004
    Location
    LosAngeles Calif.
    Posts
    12,598
    Thanks Thanks Given
    9
    Thanked in
    OTOH using a relay allows the use of lighter wires on the circuit that activates the relay as that wire will carry only the load required to actually activate and hold the relay closed, which might be only a couple of amps. And if the relay is located close to the horn(s), the run for the heavy wires can be kept short.
    True statement !
    Last edited by Editor_Reid; 08-14-2019 at 01:12 AM. Reason: No need to thank me. Just doing my job.
    1966 Daimler V8 Saloon; Safely Fast, Built to Last & and; Smooth as Glass.
    1966 BJ8 [ 2 ] Lil Red & Miss bLU
    1985 XJ6 Saloon
    1948 & 70 Lincoln continentals
    1973 Volvo P1800ES
  12. #12
    Yoda John Turney's Avatar
    Join Date
    May 2002
    Location
    Concord, CA
    Posts
    3,594
    Thanks Thanks Given
    43
    30
    Thanked in
    Quote Originally Posted by steveg View Post
    Same here. The wire sizes shown in charts assume the wire is in continuous operation, such as running a motor. Operating for short intervals allows smaller wires. For example, until engineers figured out that the starter would operate for only short intervals, the wire sizes suggested by the charts made starters too bulky.
    John, BN4
  13. #13
    Obi Wan RAC68's Avatar
    Join Date
    May 2010
    Location
    NJ Shore
    Posts
    2,023
    Thanks Thanks Given
    16
    Thanked in
    Keoke,
    Your statement presents why I installed relays on my upgraded head and driving lights. The relays are fed by a higher gauge line and connected to the main power line from the battery/starter/alternator-generator. Although I do agree that my low use of the horn (averaging less then once a year) and since the circuit is separate (hones alone) and fused, I see little reason to further complexify the horn circuit.
    My thoughts,
    Ray(64BJ8P1)
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
