Results 1 to 5 of 5
Thread: Spark Plug Gap?
  1. #1
    Join Date
    Jan 2007
    Location
    Winnipeg ,Manitoba,Canada
    Posts
    1,928
    Thanks Thanks Given
    23
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Spark Plug Gap?
    Why is the TR3 plug gap .032 and the 4/4A gap .025? .....and if mods are added like using the the longer 4A intake manifold and exhaust header, does that change which gap to use or is it just a matter of experimenting?
    Also...I think I read somewhere that the motor would perform better if the timing was set at 3/8" before BTDC? Is that 4 degrees BTDC or 8 degrees? OR is there a sweet spot in regard to timing for performance or are there just to many variables to say?
  2. #2
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Arlington, TX, USA
    Posts
    5,220
    Thanks Thanks Given
    4
    25
    Thanked in
    Re: Spark Plug Gap?
    My TR2 and TR3A are/were gapped at .025. The gap is based on the power available from the coil. 3/8” is roughly 4degrees. But final timing should be determined by road testing.
    John
    1955 TR2
  3. #3
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,669
    Thanks Thanks Given
    6
    10
    Thanked in
    Re: Spark Plug Gap?
    The TR2/3 manual does say .032. I wonder if there was a service bulletin at some point. I've always used .025 also but I don't remember where I got the number. Perhaps from the plug manufacturer's guide.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  4. #4
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,152
    Thanks Thanks Given
    6
    94
    Thanked in
    Re: Spark Plug Gap?
    Yes, there was a service bulletin, fairly early. I've posted it before (but maybe not on this forum), I'll see if I can find a copy.
    .025" is in the owner's manuals.
    Here it is, Feb 1956
    PS, 3/8 translates to roughly 8 BTDC. Whether you can run that much without knock depends on a great many variables, even things like altitude and climate. Whether more is better is another question with no clear answer; I've seen tests on some engines that show better power without running on the edge of knock.
    There's also the chance that you might not hear the knock under some circumstances; like high speed cruise. I never heard this one knock:
    So it seems to me that backing off a bit is probably a good idea, overall. Assuming you want the engine to last, anyway; racing would be a different matter.
    Randall
  5. #5
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    121
    Thanks Thanks Given
    6
    Thanked in
    Re: Spark Plug Gap?
    My book said 4 degree BTDC so I started there. Then I advanced it 2 more degrees and it ran better, so I advanced it 2 more degrees and it runs great.
    No noticeable knock. I might try 2 more degrees some day.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
