TR2/3/3A Noise from clutch area?
Deleted member 8987
why would the type of lubricant inside the transmission show up as a noise when the clutch pedal is depressed?
Carbon T/O bearing still?
Starts as soon as you press the pedal and take the free-play out, or does it start when pedal is almost fully depressed?
T/O for first, pilot for second.
Generally.
Speakers on this Toshiba not qualified to discern the subject of the link.
S
Snowkilts
Did you change the fluid in your tranny recently?
Nope. TBH I'm not sure I've ever changed it. I check it once in a while.
But the noise happens when I step on the clutch, so the trans is not moving. No noise when I let the clutch out.
Also, it doesn't matter if the car is moving or not. The video was with the car not moving.
S
Snowkilts
I just changed the permissions on the video file if anybody had trouble accessing it. Hopefully you can see it now. Sorry about that.
CJD
Definitely the throwout bearing. In the early stages the noise may come and go. Towards the end it will get constant and louder. If it were mine, I’d put it on my long term “to do” list. It could go for a year or more before getting serious.
Graham H
Definitely need to change the T.O bearing, I wouldn't go too far from home until you do.
sp53
The question now is do you want pull the trany out from the top or pull the engine and trany together. Kinda depends on how nice the car is if you want to remove the apron or the seats. The car looks nice from what I can see, and then I would probably pull the seats. That bearing sound wore out. If it only made a little noise in neutral sitting, I would wait, but that is heavy metal.
steve
STeve 1958
If you can get some lub. to it it might last a year longer.
Dumb comment...."your tach is on the right, mine is on the left." Was that intentional ?
S
Snowkilts
Would pretty much have to pull it to get lube to it, wouldn't I?
Tach is where it was when I got the vehicle. No idea which is correct. Don't trust the PO further than I can throw him though.
Edit: for fun I just looked at Bill Piggots book. He says the speedo is "usually" on the left, but sometimes they were reversed. So I guess both are correct.
TomMull
steve
The seats usually come out without protest. If the 3 screws on the bottom of the rails won't come out, take the bottom cushions out and unscrew the nuts that go on the studs that come up through the pans. IMO the transmission comes out easily this way and goes back in with some difficulty but usually not too much. And that's if it doesn't have an overdrive. If it does, I'd look for a strong helper or consider the engine/transmission option. (I've seen some engine cranes modified to lift the thing in the confined space under the dash)
The front apron is not difficult to remove as long as the bolts and nuts are not rusty but it's a challenge to remove and replace the apron without scratching or bending something. And you also have the exhaust, electrical, fuel and cooling systems to deal with. Far better if you can get it out through the inside.
Tom
S
Snowkilts
Tom
I agree. I will go at it from the inside. I've had the apron off twice but it's a job.
My big worry is the condition of the floorpans and rockers when I get the carpet out. The PO did a rather slapdash "restoration" which I have been turning a blind eye to in order to keep it on the road. I know there's some fiberglass in there. And some wood. :nightmare:
sp53
I can dig that--- honesty is great thing. I am going to put some por 15 down on this one because it is an all-weather driver.
DavidApp
Having just acquired an OD transmission I am faced with the decision change from inside or out the front. Being on my own I will probable go out the front.
David
Graham H
David,
I changed my gearbox on my own using my lifting bar but you may need to take the steering wheel off I don't have that problem because all the controls are on the right-hand side of my car. If you go from inside don't forget to tie the clutch lever forward to the bell housing because it tends to get caught on the floor turn up when putting the box back in.
Graham
upside down again
TomMull
Clever arrangement Graham. I flipped the image below:
CJD
For just the throwout bearing I found going from the inside to be the lesser work. The tunnel is easier to remove than the apron.
The early speedos were on the left in the US. Later they moved the speedo right so the navigater could see it in road rallying.
sp53
I have pulled them and reinstalled them myself from the top. I used simple come- a –long from the rafter as close to balance point of the trans as I could it and that took up a lot of the weight, no od. Sometimes you will need to unhook the exhaust at the engine to let engine down some in the back and naturally support the engine somehow. I would not trust a hydraulic jack long, so I use a scissor jack to lower and raise the engine in the back.
Today I would get some help probably, but back in day I would crawl under the car and lift and fettle with most the tail shaft looped and balanced at the come-a- long. Or make one of those cool deals like Graham has, but did not about that then.
N TR6 Diagnose noise from clutch area Triumph 13
P TR6 Clutch pedal click noise Triumph 2
P TR6 Clutch pedal noise Triumph 2
R Clutch Throwout Bearing Noise? Austin Healey 2
G Rattling Noise while Clutch is Partially Engaged Clutch Austin Healey 20
H TR6 1974 TR6 clutch noise when pedal is depressed Triumph 3
Michael Oritt Clutch-related noise Austin Healey 14
Q Clutch Noise!! Triumph 6
M Clutch pedal noise Triumph 16
B clutch noise? Austin Healey 4
electric TR6 clutch whistle noise - 74 tr6 Triumph 9
F TR6 TR6 clutch noise Triumph 15
Stewart T-Series Clutch and transmission whirrling noise Q? MG 1
Brosky TR6 TR6 Clutch knocking noise problem [not mine] *DELETED* Triumph 2
D Strange clutch noise Triumph 3
Paulus TR6 TR6 Transmission noise when clutch engaged. Triumph 7
johnrip Wedge TR7 Clutch Throw out noise? Triumph 1
NutmegCT T-Series clutch pedal vibration & noise MG 2
A Why is my car making this noise? Other Cars 5
Popeye TR4/4A Transmission noise - intermittent Triumph 22
AUSMHLY Transmission Noise Austin Healey 11
Gliderman8 TR6 Lever shock noise Triumph 18
LAW75 High-Pitched Noise Austin Healey 13
B High-Torque Starter Rattling Noise Austin Healey 3
nicko Strange Engine Noise Austin Healey 7
Sarastro TR4/4A Identifying the source of gear noise. Triumph 15
Martinld123 Steering Idler Noise Austin Healey 21
I T-Series air cleaner/ noise suppressor MG 1
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
P TR6 Clunking noise in rear continuing Triumph 39
Gliderman8 TR6 What's that knocking noise? Triumph 6
Kleykamp TR2/3/3A Engine noise Triumph 4
SherpaPilot Strange Noise While Cornering in TR6 Racing 3
F TR2/3/3A Strange Loud Noise Triumph 11
B An expensive sounding noise possibly the transmission Austin Healey 7
M TR2/3/3A Annoying Vibrating noise?? Triumph 11
M TR2/3/3A Grinding noise when trying to start sometimes? Triumph 10
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
G Tappet Noise Austin Healey 8
TulsaFred Generator or water pump noise? Spridgets 20
S Disconcerting engine noise, please help if you can. Austin Healey 56
2billydavies TR2/3/3A rattling noise on TR3a Triumph 12
J MGB Project car done; front end clunk noise while braking MG 4
P MGB MGB overheating with a squealing noise from the engine MG 11
RAC68 Loud Trans Scrapping Noise Austin Healey 9
J Fan Type Noise on Ignition Switch in Accessory Austin Healey 9
K TR2/3/3A Gearbox noise.... Triumph 8
P TR6 Rear suspension noise Triumph 3
D Ticking noise when driving Austin Healey 8
bugedd Rear end noise [insert joke] Spridgets 11
